Old Feb 17, 2013, 11:34 PM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
Originally Posted by polix View Post
really? hmmm i dusted off the 900mhz gear and popped a blue beam set on them and blew away my 5.8 set on my hex today, perhaps i should try it on my SSS, i did after all order the RHCP patch as well...
ok.. project for this coming weekend
yup... 5.8 looks all cute and small but the good-ol' lower frequencies will kick its A$$
Keep 5.8 for Multi rotor stuff... your SSS deserves more!
chanyote66 is offline Find More Posts by chanyote66
Old Feb 17, 2013, 11:35 PM
CrashAffinity is offline
Find More Posts by CrashAffinity
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, AB, Calgary
Joined Nov 2012
yeah, i thought that until i flew into a nice batch of trees and didn't lose my video signal today ... i'm just gonna have to order some extra antennas for the 900 gear
CrashAffinity is offline Find More Posts by CrashAffinity
Old Feb 21, 2013, 03:33 AM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
is there a different type of mig wire the one i got is dam hard to solder, even with my soldering station set to 500 degrees the solder just wont stick, i have to grind the mig and solder but it one chance job if failed first try need to grind it again or else the solder just flow like oil on water
skellator is offline Find More Posts by skellator
Old Feb 21, 2013, 10:30 AM
The Tellurian is offline
Find More Posts by The Tellurian
St Catharines Canada
Joined May 2002
Try a different flux. [That mig wire does have a copper coating?]
Richard
The Tellurian is offline Find More Posts by The Tellurian
Old Feb 21, 2013, 10:50 AM
9W2DLR
Joined Nov 2011
Richard
not sure about the copper, maybe it does not have copper as if i leave it overtime i see rust start tu buildup, i use to have a bottle of liquid flux but seem missing from my desk now using paste two of them, i'm electronic base so i just bought that i think should work
Description:
Description:
Description:
Old Feb 21, 2013, 03:12 PM
chanyote66's Avatar
Joined Dec 2011
I have used various flux and havent found anything that will work easy with mig wire even with my 800 and 900 degree tips. When Im making the wire i scrape the ends to remove the coating, then flux and tin them prior to building. This prevents a bunch of headaches.
Chris
Old Feb 21, 2013, 11:42 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Chris
At that temperature you burn the coating off of the wire. I personally run my iron at 550 degrees F.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Feb 22, 2013, 11:22 AM
Keddy is offline
Find More Posts by Keddy
Canada, ON, St. Catharines
Joined Jul 2012
Well I got to try out my freshly made SPW and CL antennas yesterday. All I can say is wow, I took almost no pride in making mine, just wanted to do a dry run and see if I was even capable of getting them close. Tried them out anyway and it was a world of difference over stock antenna. If you have any doubts in yourself about making the antennas, give it a shot you'll surprise yourself.
Too bad my first time using goggles was the same time I was trying out the antennas. It was cold out, they fogged up, I crashed.
Needless to say, the CL doesn't look like this anymore.
Keddy is offline Find More Posts by Keddy
Old Feb 22, 2013, 12:07 PM
magnum500sw is offline
Find More Posts by magnum500sw
Joined Sep 2012
noo pride , they look real good for no pride . i have to agree with you on the range increase . they are worth the time
magnum500sw is offline Find More Posts by magnum500sw
Old Feb 22, 2013, 12:29 PM
Keddy is offline
Joined Jul 2012
This simple jig I made helps keep things straight.
Old Feb 22, 2013, 03:21 PM
chanyote66's Avatar
Joined Dec 2011
-Alex
ya, I usually use either my 500 or 600 tip for my weller. I was just testing one of the "desoldering" tips for extra heat..
Chris
Old Feb 22, 2013, 10:38 PM
SupraGo is offline
Find More Posts by SupraGo
SupraGo's Avatar
Canada, AB, Vegreville
Joined Jun 2009
Couldn't figure out just what you were doing here till I realized it was a plexiglass base. Neat idea. Gives me some ideas
Bill
SupraGo is offline Find More Posts by SupraGo
Old Feb 23, 2013, 12:27 AM
9W2DLR
Joined Nov 2011
-Alex
i think the mig i have does not have copper coating? as solder does not stick very well, also it does not conduct heat at all, I heat up the other mig end (50mm) at 500F touch the other end does not feel a thing
Old Feb 26, 2013, 07:01 PM
redodedo is offline
Find More Posts by redodedo
HD FPV on a 4m glider
Canada, BC, Richmond
Joined Dec 2012
hi, can anyone tell me where he got the number 614035 from?? shouldnt it be the speed of light (300000000) divided by frequency (say 1.2ghz, so 1200000000) and thats the total length in meters that your antenna needs to be???
Please help
"Long Wire length in mm = 614035/f in MHz"
redodedo is offline Find More Posts by redodedo
Old Feb 26, 2013, 08:10 PM
redodedo is offline
Joined Dec 2012
anyone??? I would be happy if you could just give me the equation he used to find the length in meters required
Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! IBCrazy FPV Equipment 2402 Jul 19, 2016 11:29 PM
Mini-HowTo IBCrazy's DIY antenna tracker!!! IBCrazy FPV Equipment 460 Jul 01, 2016 06:09 PM
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy FPV Talk 359 Jun 26, 2016 02:04 PM
Build Log IBCrazy's Minion - The ultimate FPV plane IBCrazy FPV Aircraft 151 Apr 19, 2013 11:04 PM
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
