Old Feb 04, 2013, 08:06 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by Kahnx View Post
I have a couple of SPW (3-blade cloverleaf) antennas that were mistakenly built for 1080Mhz.
I would like to run them on 1040MHz (Channel 4 on non-US 901MHz VTXs).
What is the bandwidth of the antennas like at these lower frequencies?
Is it worth the effort to build new antennas at 1040MHz in terms of range/signal-quality/less-heat? How much better would properly tuned antennas be?
Thanks in advance for the advice.
Roger
You are going to suffer a loss of ~2db or so. If you need absolute range, then this is no optimal. However, chances are you aren't going to get anywhere near you max range due to other factors and this is probably ok.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Feb 04, 2013, 12:27 PM
jminardi is offline
Find More Posts by jminardi
United States, Mt, Great Falls
Joined May 2011
here it is
Thanx for the how to!
oh yeah is for 1280
going on my penguin with ibcrazy 3 turn helical
jminardi is offline Find More Posts by jminardi
Old Feb 06, 2013, 03:09 AM
BenLimeClouds is offline
Find More Posts by BenLimeClouds
I Like Clouds Made Of Limes?
BenLimeClouds's Avatar
United Kingdom
Joined Jun 2012
How are mine looking?
This is as neat as i can get them! Should be good to 1Km 200mw 5.8GHz right?
Hope they work ok!
BenLimeClouds is offline Find More Posts by BenLimeClouds
United Kingdom
Joined Jun 2012
Top side!
Old Feb 06, 2013, 04:46 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Hope they work ok!
To give range estimations is always difficult as in theory you could have made some fatal mistake somewhere, but asuming you did not, the 1km figure seems plausible.
Markus
markus123456 is offline Find More Posts by markus123456
Old Feb 06, 2013, 08:13 AM
Cid156 is online now
Find More Posts by Cid156
Cid156's Avatar
Switzerland
Joined Sep 2008
I saw people using skew planar wheel on RX and TX. Is it a big issue?
I have few of them in stock and I want to try....I do not want to reach 1km it is for internal fpv (with walls)
Cid156 is online now Find More Posts by Cid156
Old Feb 06, 2013, 08:15 AM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
it will work fine... I flew with the SPW on the plane and a CL on the ground station until i realized that was backwards
Chris
chanyote66 is offline Find More Posts by chanyote66
Old Feb 06, 2013, 08:30 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
You can mix them any way you want. I personally use two cloverleafs. Some prefer two skew wheels. Most use one of each. I found that two skew wheels did not do nearly as well as two cloverleafs. in fact, the whole reason I came up with the cloverleaf was because I flew with two skew wheels and was really disappointed.
-Alex
Old Feb 06, 2013, 08:38 AM
Cid156's Avatar
Switzerland
Joined Sep 2008
Thank for your replies, I appreciate
Old Feb 06, 2013, 10:29 PM
RANTHM is offline
Find More Posts by RANTHM
United States, CA, Santa Maria
Joined Aug 2010
I have a question. Does it matter it the transmitter antenna is mounted up, down or sideways? I want to mount one on my Quad. Thanks for any help.
RANTHM is offline Find More Posts by RANTHM
Old Feb 06, 2013, 11:17 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Upright or upside down doesn't matter. Just do not lay it on its side.
-Alex
Old Feb 07, 2013, 08:37 AM
chanyote66's Avatar
Joined Dec 2011
-Alex
It lets the RF fluid pour out
Old Feb 07, 2013, 08:39 AM
chanyote66's Avatar
Joined Dec 2011
Hey IB,
I have been testing my antennas and found that I have more interference on one side of the antenna than the other with my MM.
I checked all connections and it is good. Could this be that a wire is short, or wrong angle? any way to identify which lobe?
Chris
Old Feb 07, 2013, 09:20 AM
Registered FPVer :)
Joined Aug 2006
Originally Posted by chanyote66 View Post
Hey IB,
Chris
Whats an "MM", and was this in open space? If so, most likely the lobe closer to that side where you get more interferance would be the "bad" one.
If this was not open space, then the fact that you get more inerferance on one side would most likely tell that on the side with more interferance there are more signal reflecting obstacles.
HTH
Markus
Old Feb 07, 2013, 09:26 AM
chanyote66's Avatar
Joined Dec 2011
HTH
Markus
MM = Mad Mushroom
yes its open space... mounted 8" above the RX... and i rotated the antenna to eliminate localized interference. when i rotated the antenna 90 degrees, so did my poor reception area...
I tore the whole thing apart and started to measure the lobes. I used a jig to build the lobes so they are all +/- .25mm so I think its in the angle or something... Still building a jig for mounting lobes.
I use a magnetic jig for my CL/SPW builds...
Chris
Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! IBCrazy FPV Equipment 2402 Jul 19, 2016 11:29 PM
Mini-HowTo IBCrazy's DIY antenna tracker!!! IBCrazy FPV Equipment 460 Jul 01, 2016 06:09 PM
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy FPV Talk 359 Jun 26, 2016 02:04 PM
Build Log IBCrazy's Minion - The ultimate FPV plane IBCrazy FPV Aircraft 151 Apr 19, 2013 11:04 PM
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
