Old Jan 22, 2013, 11:03 AM
rusty case is offline
Find More Posts by rusty case
KlonWarz
Joined Dec 2012
we need a LIKE tab here on this forum!
markus +1
rusty case is offline Find More Posts by rusty case
Old Jan 22, 2013, 12:32 PM
Borister is offline
Find More Posts by Borister
Joined Nov 2012
If I am making a Cloverleaf/Skew Planar Set for 1280MHz, should I make both antenna's with the same wavelength and quarter wavelength's, or should I do it exactly like you have on your instructional pages: (Clover 1280MHz = 18.9"/479.5mm (quarter 1280MHz = 2.36"/60mm) , and Skew 1280MHz = 18.49"/469.8mm (quarter 1280MHz = 2.31"/60mm)
This is my first time attempting this, so I would like to do it right.
Thanks!
Borister is offline Find More Posts by Borister
Old Jan 23, 2013, 10:13 PM
avro-fan is offline
Find More Posts by avro-fan
Alex would it not be better to build these antennas for the middle of the band (CH4: 1080Hz, CH5: 1120Hz, CH6: 1160Hz, CH7: 1200Hz, CH8: 1240Hz, CH9: 1280Hz, CH(H): 1320Hz, CH(C): 1360Hz)
which would be 1240 so that the swr would be more even at each end of the band .Best chanel for transmitting and reciving on would be if a 1:1 swr is on 1240 and each end might be a 1: 5 to 1 at each end theoreticaly Mike
avro-fan is offline Find More Posts by avro-fan
Old Jan 24, 2013, 07:17 PM
burtgree is offline
Find More Posts by burtgree
Burt KF7ULM
United States, AZ, Phoenix
Joined May 2007
Broken
Has anyone repaired a broken antenna that looks like this.
It has worked fine for about a year, but just broke it today with a hand launch of a new plane that was way out of trim. When I got it in the air, the picture was BAD. Landed and found the problem.
Now is it worth fixing it, and has anyone else done it and have any pointers.
Burt
burtgree is offline Find More Posts by burtgree
Old Jan 25, 2013, 05:58 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Burt
If you manage to take that plastics away and resolder you should be ok. Alternatively you just take it apart, dump the cable and replace it with a new one. The lobes should be reuseable with no problem. The frequency this antenna operates on is already pretty forgiveing so the result should work ok. Amazing that you manage to break it by just tossing the plane into the air....
HTH
Markus
markus123456 is offline Find More Posts by markus123456
Old Jan 25, 2013, 09:31 AM
burtgree is offline
Burt KF7ULM
Joined May 2007
HTH
Markus
Wasn't the tose, but the nose in to the ground after.
Strange, it is a bixler2, used everything from the bixler1. Only added two servos for flaps.shouldn't have a problem.
Old Jan 26, 2013, 08:38 AM
sfakias is offline
Find More Posts by sfakias
ScratchCrasher
sfakias's Avatar
Greece, Makedonia Thraki, Thessaloniki
Joined Jun 2008
Burt
I did repaired such a broken antenna a couple of weeks ago. Actually, it was a SPW, not a CL, but it is the same thing. It actually broke when my 2,5 yeard old son was having a look at it
What markus123456 said is spot on. You just have to be very careful and have steady hands when you are doing the resoldering, in order to avoid shortcircuiting the inner wire with the outer mesh of the cable at the solder point.
Regards,
Stavros
sfakias is offline Find More Posts by sfakias
Old Jan 26, 2013, 12:21 PM
Borister is offline
Joined Nov 2012
What do you suggest to do about the thickness of the coax? When I solder the ends right up to the coax, the thickness of the coax is not precise, and changes thing significantly. Is this significant?
Old Jan 27, 2013, 02:57 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Burt
That happened with many of my earlier antenna until I switched to a thicker, sturdier cable and a nylon reinforcing bead at the feed. You can repair it and it's actually not too terribly hard once you cut the collar underneath the heatshrink tubing.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jan 28, 2013, 03:18 AM
borneobear is offline
Find More Posts by borneobear
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
I'm very late into this CL antenna. Finally overcame my laziness and go this way because of a land based 4WD FPV set up.
First off, I would like to thank Alex for the tutorial at the front of this thread.
Makes building the cloverleaf so damn easy!
I did my first 1280Hz clover leaf yesterday, and I'm blown away.
I'm really really blown away!!
Can't believe I spent all that money on a bloody antenna tracker...
Thanks again Alex. You da man.
BB
borneobear is offline Find More Posts by borneobear
Old Feb 03, 2013, 10:18 PM
Kahnx is offline
Find More Posts by Kahnx
Registered DSer
Kahnx's Avatar
Australia, VIC, Hadfield
Joined Mar 2003
Question - Bandwidth for lower frequency SPWs
I have a couple of SPW (3-blade cloverleaf) antennas that were mistakenly built for 1080Mhz.
I would like to run them on 1040MHz (Channel 4 on non-US 901MHz VTXs).
What is the bandwidth of the antennas like at these lower frequencies?
Is it worth the effort to build new antennas at 1040MHz in terms of range/signal-quality/less-heat? How much better would properly tuned antennas be?
Thanks in advance for the advice.
Roger
Kahnx is offline Find More Posts by Kahnx
Old Feb 03, 2013, 11:00 PM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
They will be fine... I use 1280 antennas on 1258 all the time!
Chris
chanyote66 is offline Find More Posts by chanyote66
Old Feb 04, 2013, 01:53 AM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
my antenna is tuned for 1280Mhz but i fly on 1320Mhz no problem at all with my 200mw did 3.5km before video was totally out
skellator is offline Find More Posts by skellator
Old Feb 04, 2013, 02:09 AM
CrashMeUp is offline
Find More Posts by CrashMeUp
Crashomatic
CrashMeUp's Avatar
United States, CA, SF
Joined May 2010
I'm wondering if anyone here is using those push-on SMA connectors instead of screw on?
I'm not sure if the CL antenna would stay in at high speed/aerobatics .. but it sure is faster to plug in.
CrashMeUp is offline Find More Posts by CrashMeUp
Old Feb 04, 2013, 07:12 AM
chanyote66's Avatar
Joined Dec 2011
I saw those and was thinking of that for a wing connection but then i decided on mounting the VTX in the wing and just using a servo connection to remove the power/ground/vid from the VTX. Less loss in the antenna without all those connections.
Chris
Mini-HowTo IBCrazy's DIY antenna tracker!!! IBCrazy FPV Equipment 439 Jan 30, 2016 11:52 AM
Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! IBCrazy FPV Equipment 2293 Jan 06, 2016 10:20 AM
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy FPV Talk 357 Dec 10, 2015 07:40 AM
Build Log IBCrazy's Minion - The ultimate FPV plane IBCrazy FPV Aircraft 151 Apr 20, 2013 12:04 AM
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 07:07 PM
