Old Mar 02, 2012, 08:03 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by Ceccoz View Post
Thanks Mashton for the answer I will try to reduce it in the future!
IBcrazy what do you think I have to improve? The shape of the lobes?
Francesco
I think everything is fine on your build. I wouldn't change anything. The cloverleaf is very interesting antenna in both it's workings and tolerance to error. You will do fine with your build. Go fly it and have fun
If you really want to play around with it a bit, lower your return (closure) angles from 90 degrees to 60 degrees. This will change the radiation pattern slightly and help with the long feed gap as it makes the lobes react less. In all actuality, this is actually a slight improvement of the cloverleaf called "The AirScrew", which I never introduced because I didn't feel like creating any confusion.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 03, 2012, 01:41 AM
ScratchCrasher
sfakias's Avatar
Greece, Central Macedonia, Thessalonika
Joined Jun 2008
-Alex
Can you please post a couple of pics of the AirScrew Alex?
Thank you.
sfakias is offline Find More Posts by sfakias
Old Mar 03, 2012, 02:03 AM
San Marcos, CA
Joined Aug 2009
So I am about to get a pair of these antennas.. Does anyone know the approx range with the ImmersionRC 5.8 600W VideoTX?
flyandi is offline Find More Posts by flyandi
Old Mar 03, 2012, 02:07 AM
um.. yeah, I can make that fly
Carlos230023's Avatar
United Kingdom, Milton Keynes
Joined Jun 2007
I've done 2.3km with the immersion setup. Was pretty clear most of the way. Started to waiver at the 2.2km mark. Probibally could have pushed it to 2.5km. The beauty of these antennas is they don't just switch off when your out of range. They'll give you a good 500m heads up and your flying away that the signal is getting a bit shaky.
CJ
Carlos230023 is online now Find More Posts by Carlos230023
Old Mar 03, 2012, 02:14 AM
San Marcos, CA
Joined Aug 2009
Awesome! Thanks! My TX/RX probably will quit way before 2.3km... around 1.5km.. so I should be safe with these.. Waiting until the 600mw VideoTX is back in stock and order the hole package.
Old Mar 03, 2012, 02:26 AM
Joined Jun 2007
Good call. The immersion stuff is great. Oh and should you fancy going a little further 'a' field later on (say with a UHF TxRx setup) a helical VRx antenna will take this system to 10km. FYI a new immersion 600mw 5.8VTx is on the "soon to be released" roster. Same thing but a smaller package if space is a constraint.
CJ
Old Mar 03, 2012, 02:54 AM
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
I must not be flying enough as the CL and SPW antennas are going rusty.
The rust does not seem to effect the video but have not tried at a distance since the rust. Guess the rust would effect the range.
So I suppose the answer is clean off the rust and spray some clear coat on them?
Col
Firepower is offline Find More Posts by Firepower
Old Mar 03, 2012, 05:05 AM
No you cant fly it.
kicekilla's Avatar
United States, CA, Huntington Beach
Joined Mar 2011
Col
ibcrazy posted a ways back about soaking rusting antennas in some type of acid to chemically change the rust into a protective layer (i think haha) hopefully he sees this and can correct and add to this if im wrong.
kicekilla is offline Find More Posts by kicekilla
Old Mar 03, 2012, 05:32 AM
Still flying a desk..
ChilternFlyer's Avatar
Bucks, England
Joined Sep 2001
Originally Posted by markus123456 View Post
Not really sure wether I understand your question right or not. If by "feeder" you refer to the complete 50 ohm coax cable from tx/rx to the antenna, and if it's length is important, then the answer is "no". Ok, every real world cable has a damping, and obviousely with the very low powers we actually use you want it to be as short as practical, but it does not matter if the cable is any sort of divideable by a wave, half wave or quarter wave lenght.
"The full wafe above the ground plane".... Hmm, maybe you mean the distance of the antenna itself above other objects? Every antenna has a so called near field which is about a wave lenght around the antenna. ANY object within this range of the antenna will change it's behaviour quite a bit. It would change the radiation pattern as well as the resonant frequency. The reason is that the electormagnetic waves travel trhough the air with very close to the speed of light. Any object however will change their speed trough that matter a little bit, so also non conducting materials count. At the borders of such an object, an effect similar to light hitting the surface of water can be observed. The waves change their direction, hence the changed radiation pattern. So haveing an object in the nearfield of the antenna is a very bad idea. It's an extremly bad idea if said object is even conducting, like i.e. a transmitter or receiver housing.
So in the context of the first part of your question, a cable should be at least one wave lenght long, but if it's a wee bit longer or quite a bit longer does not matter except for the damping effect.
Hope this answers your questions
Markus
Thanks Marcus, that cleared things up for me. It's 30 years since I last played with aerials and lengths of co-ax. I was taught the length (in multiples of velocity factor * wavelength) of the co-ax affects the performance of the antenna.
However, the minimum distance from the antenna to other objects makes a sound argument so I'll stick to keeping the antenna at least one full wave from the TX casing.
Mitch.
ChilternFlyer is offline Find More Posts by ChilternFlyer
Old Mar 03, 2012, 07:05 AM
Firepower
Firepower's Avatar
Joined Mar 2010
Thanks - Just found it.
It will be just fine. You can paint it to protect the antenna if you like. If it rusts, dip it in phosphoric acid. The phosphoric acid converts rust into iron-phosphate which is a good insulator and protector.
-Alex
Old Mar 03, 2012, 07:38 AM
H19
H19's Avatar
Joined Feb 2011
sorry for my stupidity,
Im going to start making this antenna, for 1280MHz, 1.3GHz setup,
and im a little confused about the length of the RG316 coaxial cable,
is this the quarter-wave length ?
1280MHz = 2.36"/60mm, ??
what happens if its longer? it looks alot longer in the pictures,
is it true, or false, the clover-leaf should go onto my TX/quad? im going to side solder it so i can mount it off the back side of the quad?
and the
Skew-Planer-Wheel- on my RX ?
thank you for helping my stupididty
john
H19 is offline Find More Posts by H19
Old Mar 03, 2012, 09:34 AM
vin diousse
Joined Nov 2011
hi,
I've found in my stock a nice RG316 pigtail but the only wire i could find in my stock was a 75 ohms satellite cable. As it is a 1mm diameter wire i thought it was good to give a try. I've been following IBcrazy dimensions for 1260mhz. I didn't test yet.
Is 75ohms wire OK?
GOURBI is offline Find More Posts by GOURBI
Old Mar 03, 2012, 12:45 PM
No you cant fly it.
kicekilla's Avatar
Joined Mar 2011
-Alex
Cool glad you found it!
Old Mar 03, 2012, 01:14 PM
boxhead530's Avatar
United States, CA, Chico
Joined Nov 2010
That's good question, if gold plated memory wire works as antenna, it would seem any reasonable wire would work, how about 1/64 steel braid, yes, you would have to weld it, but as a crash proof dangling antenna on a plate frame quad....
IBC's earlier statement "go fly it and see..." is the best idea, I get trapped in this "box" of looking for best, easy, quick, cheep, that I end up doing nothing...
I'm going to do some yard work, and then go fly some... Then fly some more, maybe, if I'm not tired, I'll start soldering Vtx / rtx up...he he
boxhead530 is offline Find More Posts by boxhead530
Old Mar 03, 2012, 03:02 PM
H19
H19's Avatar
Joined Feb 2011
went to home depot today,
they had the .030 Lincoln copper coated welding wire,
the .035 was not copper covered,
so i bought a roll of the .030,
can i use this for the cloverleaf, and the skew-planer wheel ?
also they had RG59 cable,,but no RG58,
can that be used??
i was afraid to waste my money buying some,
im using 1.3GHz
1280MHz
thanks
john
Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! IBCrazy Video Piloting (FPV/RPV) 1488 May 19, 2013 10:43 AM
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy Video Piloting (FPV/RPV) 293 May 13, 2013 05:03 PM
Build Log IBCrazy's Minion - The ultimate FPV plane IBCrazy Video Piloting (FPV/RPV) 151 Apr 19, 2013 11:04 PM
Mini-HowTo IBCrazy's DIY antenna tracker!!! IBCrazy Video Piloting (FPV/RPV) 242 Mar 27, 2013 11:52 AM
Build Log IBCrazy's homebrew antenna tracker IBCrazy Video Piloting (FPV/RPV) 48 Oct 25, 2012 06:07 PM
