Old Mar 29, 2011, 06:25 AM
IBCrazy is online now
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by Hugeone View Post
At theta = 0, this antenna might be provocative for some...
-Hugo
I never even considered the angle. however if I adjust the element lengths about 3% I can go from a dual polarized antenna with very little if any rejection, to circularly polarized with over 15db rejection!
When I designed the above, I was manipulating a 3/2 wave turnstile using reactive vectors to correct phasing issues. Turns out I got a 100 OHM CP antenna. Use a 75 ohm 1/4 wave stub and... 50 ohms!
-Alex
IBCrazy is online now Find More Posts by IBCrazy
Old Mar 29, 2011, 11:27 PM
yzguy is offline
Find More Posts by yzguy
yzguy's Avatar
Florida
Joined Mar 2007
I saw someone ask this, but did not see the answer...
if I want to make one of these for 5.8, and I want to try to solder the ground legs directly to a connector, should the legs be the specified length from the center of the connector? or from the outside edge? (at these small sizes, that distance is likely significant )
yzguy is offline Find More Posts by yzguy
Old Mar 30, 2011, 03:38 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
I assume the modells etc. were made with an ideal situation in mind, alas the legs starting at the center. So IMHO you should compensate for the diameter.
I'm too interested to hear Alexs take on this.
Markus
markus123456 is offline Find More Posts by markus123456
Old Mar 30, 2011, 01:08 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
It doesn't matter. It is the over all length of the loop that is critical. So long as all of your legs are the correct length, where they terminate is almost irrelevant. The reason is that once the signal hits the plug, it is completed. Thus is doesn't really matter how wide it is so long as it is a little more than 1 full wavelength.
-Alex
Old Mar 30, 2011, 02:32 PM
yzguy is offline
yzguy's Avatar
Florida
Joined Mar 2007
I will make 3 individual loops, and terminate each ground leg at the outside edge of the connector, so the leg length is correct. (I'll make a temporary jig to hold it all in place)
Old Mar 30, 2011, 03:25 PM
Papat is offline
Find More Posts by Papat
Pat K
The Netherlands
Joined Dec 2010
-Alex
Do we need to account for the length that is "enclosed" in the soldering joint? I guess it is not contributing to the radiating length. Is it correct to increase the length of each loop by 2mm as 1mm per side looks "stuck" in the soldering joint?
Pat
Papat is offline Find More Posts by Papat
Old Mar 30, 2011, 09:58 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Pat
No, that really isn't necessary either. I believe you are over thinking this. Just cut and bend your wire per the equations. I think you will find it works very well.
-Alex
Old Mar 31, 2011, 02:47 AM
Papat is offline
Pat K
The Netherlands
Joined Dec 2010
-Alex
Thks Alex, I've sticked to your length recommendations for my first set of antennas: 1 cloverleaf for the Tx and one Skew Planar for the Rx as you advised. Will do my first FPV flight on saturday, if weather permits. My first flight will probably be quite disturbed by my monitor "black screen of death..." as it seems to be quite sensitive even at very short range. However, I made a test at home with my plasma screen and it never cuts the communication even walking around the house from ground floor to 2nd floor despite having many floors and walls to cross. Seems to be good sign.
Pat
Old Mar 31, 2011, 03:44 AM
Joshbb is offline
Find More Posts by Joshbb
Ironbridge (UK)
Joined Jan 2009
Pat
hi where are the designs for the skew planar? i thought one clover for the tx and one for the rx was the way to go?
thanks
Josh
Joshbb is offline Find More Posts by Joshbb
Old Mar 31, 2011, 04:33 AM
Papat is offline
Pat K
The Netherlands
Joined Dec 2010
thanks
Josh
Here it is. I recall Alex advised a skew planar at the Rx in some threads even if a cloverleaf is very good as well.
Pat
Old Mar 31, 2011, 05:11 AM
Joshbb is offline
Ironbridge (UK)
Joined Jan 2009
Pat
thanks, for that, sort of a 4 leaf clover should be fun for me with my 5.8ghz
Old Mar 31, 2011, 06:49 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
After building many of these for various people around the world, I find the 5.8GHz units the easiest to build. I bottom feed them to make it easier.
I find the cloverleaf is half as difficult as the skew-planar wheel.
-Alex
Old Mar 31, 2011, 09:24 AM
JeffY is online now
Find More Posts by JeffY
Hong Kong
Joined Jan 2006
-Alex
I got a set of CL from Alex for my 5.8Ghz and they are great. I have ground tested it, very good range. I hope to have a flight this Sun.
Thanks Alex.
JeffY
JeffY is online now Find More Posts by JeffY
Old Mar 31, 2011, 03:09 PM
nosaari is offline
Find More Posts by nosaari
Joined Feb 2011
Originally Posted by BlueAngel2000 View Post
Nosaari, i think you have to say, that you only fly with a 25mw Airwave 5,8GHz transmitter.
I get about 100m with standard whips, with these 25mw Airwave.
1000m with standard whips on the 200mW Set from Foxtech.
I will try soon the CL and SPW with 25mW and 200mW.
Even tho I do not even get near 100m with my 5.8 rubber duck whips... But I would rather say its a problem of my receiver than the antennas so I will now stop spamming this thread about problems with my receiver
nosaari,
Your coax does not seem to have a Teflon center, it may have melted and short.
-Hugo
After hearing so many success storys especially with the 5.8 clovers I guess something like this must have happened (and a crappy receiver in my fatshark goggles I will try to get new and better coax cable and plugs and resolder my two antennas and hopefully get the results these great antennas deserve!
Thanks again to alex for the great tutorial, even tho my antennas do not (yet) perform good, I sure had fun making them
nosaari is offline Find More Posts by nosaari
Last edited by nosaari; Mar 31, 2011 at 03:10 PM. Reason: Someone stole my first quote!
Old Mar 31, 2011, 08:49 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Sadly, I have found that some RX's are just not compatible with the cloverleaf. The Lawmate 1.2GHz is one of them. You might have another. It's time for you to build a 3 turn helical. Use the Hecker transformer to match it. Use a wooden dowel as the former. This will make for incredible performance.
-Alex
Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! IBCrazy FPV Equipment 2368 Apr 23, 2016 04:12 AM
Mini-HowTo IBCrazy's DIY antenna tracker!!! IBCrazy FPV Equipment 459 Mar 30, 2016 06:38 AM
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy FPV Talk 357 Dec 10, 2015 06:40 AM
Build Log IBCrazy's Minion - The ultimate FPV plane IBCrazy FPV Aircraft 151 Apr 19, 2013 11:04 PM
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
