-Alex |
Latest blog entry: Project Covert Ops: Long range ground...
Japan
Joined Apr 2010
There are several wifi points underneath the flight path. Theres a couple of spots maybe 100m away off to the left of my groundstation also. More info here. Its pretty hard to get away from wifi here. When my Lawmate VRX comes I can try channel 8, 2.5ghz.
The only things I can think of are to match VRX/VTX brands, and set the VRX up and away from me as far as possible. I could also try building another antenna set to the 31mmX62mm standard. There is something wrong though if someone like Markus is getting 2+KM crystal video on a much weaker 200mw 5.8, and I can't get clear LOS on a 500mw 2.4. |
Joined Jun 2010
The sizes were provided but guess I was just looking for an easy way out of a pattern but really it is not necessary if you sit down and spend time and work it out. I guess it would be really difficult to comment on antennas, as everyone takes them at different camera angles. I just tried the CL in the park next door with a patch on the receiver and the picture was good for as far as I went. I'll try again tomorrow in the daylight and measure the distance. A simple guide for new people would be good. The more information when you are new at it makes it a lot easier. I might tonight have a go at another CL with the wire down the braid or a SPW. |
-Alex |
United States, FL, Maitland
Joined Apr 2011
I'm certain there is a very big difference between your analyzer and mine
I measured mine with a wideband sweep antenna with no input attenuation.Set your analyzer to frequency sweep and take snapshots. You will notice significantly higher readings. There is one great thing abut interference from WiFi: it will never completely block you out. The other nice thing is that houses and buidings are great Faraday cages. Not much signal leaves the house. -Alex |
I measured the leads with a caliper to be as exactly to the length for each let as I could get it. After I'd gotten the mig wire soldered to the three portions of the shield, they were a little loose. So, I wove a single strand of a stranded wire (around 30ga?) around the coax, going over leg 1, under leg 2, over leg 3, under leg 1, over leg 2... and then soldered it to help reinforce things a little.
I thought if anything, the extra reinforcement was forming a bit of a ground plane around the end of the shield to each of the legs. Planes have far lower impedance than wires, so I thought if anything, I was effectively shortening the loop which should have raised the frequency above the target, if anything. Maybe I just got the gap between the shield and the top of the 3 arms too much shorter than "typical". There a gap of about 1mm there. I only bring these things up because I'm trying to understand what little changes might affect the resonance of these things as some of the other circularly polarized antennas are supposed to be more sensitive to build than the Cloverleaf. Is there anything I can do to tweak this thing as it is now? I know it isn't terrible, but 6% low in frequency isn't all that good. (I was aiming for 2.44GHz.) |
Joined Apr 2011
how thick should the copper wire be for 1280mhz? millimeters please
![]() I have 24 feet of #16 copper wire, i assume it is 16 gauge. I will stretch it to shrink the diameter. it looks like it is exactly 1mm wide so a 20% stretch will get it to around .8mm. |
| Thread Tools | |
| Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! | IBCrazy | Video Piloting (FPV/RPV) | 1490 | Yesterday 09:22 AM |
| Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna | IBCrazy | Video Piloting (FPV/RPV) | 293 | May 13, 2013 05:03 PM |
| Build Log IBCrazy's Minion - The ultimate FPV plane | IBCrazy | Video Piloting (FPV/RPV) | 151 | Apr 19, 2013 11:04 PM |
| Mini-HowTo IBCrazy's DIY antenna tracker!!! | IBCrazy | Video Piloting (FPV/RPV) | 242 | Mar 27, 2013 11:52 AM |
| Build Log IBCrazy's homebrew antenna tracker | IBCrazy | Video Piloting (FPV/RPV) | 48 | Oct 25, 2012 06:07 PM |
