Old Nov 21, 2011, 03:19 AM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
Originally Posted by lrrps View Post
What kind of gyro do you use, personally I have the Range Video OSD that also serves as an autopilot, I always activate the Fly by Wire function that helps keeping the wings level.
I'm hoarding these ESKY 704 rate gyros. Nothing fancy but you can't find them in stores or online anymore. The only place you'd have luck is in the for sale section in the heli section for people parting out their esky helis.
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Old Nov 21, 2011, 03:36 AM
lrrps is offline
Find More Posts by lrrps
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
That's a brilliant idea.
lrrps is offline Find More Posts by lrrps
Old Nov 21, 2011, 04:04 AM
Joined Apr 2011
yeah I got a good deal on them. My first was $20 but I got the other 3 for $10 each shipped
Old Nov 21, 2011, 06:52 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I got a question that has nothing to do with a CP antenna, pls. forgive me if this is out of place.
People at my club told me that in order to get maximum GPS signal, the antenna has to be installed on an aluminum foil, is that confirmed?
That is complete garbage. Aluminum foil will do nothing but harm your signal.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Nov 21, 2011, 07:35 AM
Joined Apr 2011
ok wow... I went out this morning and it was complete garbage. I think it's because I was parked next to a 7 story building. I think the RF was reflecting off the building and was causing really bad multipathing.
So note that any structures near you really do make a difference!!! I'll look for a new place to fly that's far away from any buildings.
Skip to 3 minutes and you can see that my range is exactly the distance of my receiver to the building.
????????/// (6 min 26 sec)
I chose that spot because the sun was in my eyes. Normally I go out in the evening but I wanted to try out my new firmware on the OSD ASAP
Old Nov 21, 2011, 07:57 AM
ExperimentalAir is offline
Find More Posts by ExperimentalAir
Ed @ Experimental Airlines
ExperimentalAir's Avatar
United States, AZ, Phoenix
Joined Sep 2011
CP interference from double-reflection?
I have a really esoteric question about circular polarization.
I made a right-hand SP receiver and CL transmitter antenna pair for 5.8gHz, mounted inside a foamboard fuselage tube and flying within 300m. They work phenomenally in the confined and RF-busy urban area where I fly.
There is still one zone on my field where I consistently get interference that seems to be at the focal point between a large 12' freeway noise abatement wall and the side of a Costco (also huge, of course) oriented at 90 degrees to one another.
Is it plausible that some of the transmitted reflection off each large surface is being reverse-polarized and then re-polarized by the other, causing a big multipathed correct-polarized signal back to the receiver?
I'm familiar with this bounce-bounce principle with certain optical systems, like prismatic reflectors, but am curious if it applies to circular polarization.
Otherwise the antennas work fantastically! Thanks Alex!
Ed
ExperimentalAir is offline Find More Posts by ExperimentalAir
Old Nov 21, 2011, 08:43 AM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
-Alex
Thanks Alex, I won't do the garbage mod then.
Old Nov 21, 2011, 09:54 AM
noobee is offline
Find More Posts by noobee
Joined Dec 2006
-Alex
this was suggested in the remzibi osd thread:
http://www.rcgroups.com/forums/showp...postcount=3500
i think the theory was to use aluminium foil to shield the gps receiver from the rest of the electronics, particularly in a confined area such as a multicopter.
i have not tried it out so i don't know if it actually works.
noobee is offline Find More Posts by noobee
Old Nov 21, 2011, 10:47 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
http://www.youtube.com/watch?v=taXy6cBpHtk
That is noise floor without a doubt. Something is on your channel. See the fuzz? That's external interference. Circular polarization is not going to fix that. You need a different location or frequency.
-Alex
Old Nov 21, 2011, 10:49 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Ed
Possibly. Reflections off of concrete reinforced buildings and metal structures usually retain a fair amount of signal strength so it's certainly possible.
-Alex
Old Nov 21, 2011, 10:53 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
In the case of the quad copter the effects of the aluminum plate outweigh it's benefits as far as the antenna is concerned. The metal plate will throw off the resonance of the GPS antenna. However the electronics may benefit from less induced noise.
-Alex
Old Nov 21, 2011, 04:29 PM
Arck is offline
Find More Posts by Arck
I land with enthusiasm
Arck's Avatar
Lima-Peru
Joined Aug 2004
Hi IBCrazy, just bought your Blubeam whip set antenna from your website, could you please send me some recommendations to install it in the bixler?, I will use it with the HK 5.8 Ghz 200mw, I didn't have it yet but I what to be prepared.
thanks
werner
Arck is offline Find More Posts by Arck
Old Nov 21, 2011, 05:00 PM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
I'm not Alex, but there are a few options for this. You could place your VTx on the wing saddle and run the antenna out to the wing, you could place it on your tail, and run it out onto the boom. There are others, I'm sure, but that's what I came up with off the top of my head
pdiddyg40 is offline Find More Posts by pdiddyg40
Old Nov 21, 2011, 05:08 PM
daronj is offline
Find More Posts by daronj
Joined Jun 2010
I recently built the cloverleaf and SKW antennas for a 200mw 5.8ghz tx/rx. I haven't had much success with them so I was wondering about left hand polarization vs right hand. My understanding is that it does not matter which I use as long as both are the same. I mean, the polarization is not related to a particular tx or rx, right?
daronj is offline Find More Posts by daronj
Old Nov 21, 2011, 05:35 PM
pdiddyg40's Avatar
Joined Jul 2008
You summed it up pretty well. As long as you have two rights or two lefts, it'll work. What exactly are your issues?
Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! IBCrazy FPV Equipment 2368 Apr 23, 2016 04:12 AM
Mini-HowTo IBCrazy's DIY antenna tracker!!! IBCrazy FPV Equipment 459 Mar 30, 2016 06:38 AM
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy FPV Talk 357 Dec 10, 2015 06:40 AM
Build Log IBCrazy's Minion - The ultimate FPV plane IBCrazy FPV Aircraft 151 Apr 19, 2013 11:04 PM
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
