Old Nov 17, 2011, 10:50 PM
Gravity - It's the law
Yabba's Avatar
USA, CO, Denver
Joined Jul 2008
Originally Posted by volto View Post
Yabba, I would be more worried about that serious camera wobble. That would drive me crazy.
Ha! I heard you. Actually I just changed the motor shaft prop adapter and checked the balance of my prop (it was spot on).
I'm thinking the adapter must have been bent at one time or another (did you notice my cowl? Hmmmmm )
I don't think it's the shaft itself, it's 5/32nd.
So I hope that it will be better tomorrow.
Howz the weather in Durango? You get any of that wind the other day?
Yabba
Yabba is offline Find More Posts by Yabba
Old Nov 18, 2011, 12:53 AM
United States, FL, Maitland
Joined Apr 2011
Originally Posted by gundamnitpete View Post
interesting templates. where did you get them? you make them? want to add them to OP? should help in constructiong this antennas.
I made them. You can get the DWG file here: http://tunerspotter.com/%5Cdropbox%5Cmisc%5C1040mhz.dwg
It's really simple to draw in AutoCAD. This is what it looks like on a regular printer(I assume you don't have a designjet):
Make sure the scale is right so you have accurate printout.
If you don't have AutoCAD or any Autodesk software get Trueview because it's free... http://usa.autodesk.com/adsk/servlet...&siteID=123112
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Navigator
volto's Avatar
USA, CO, Durango
Joined Sep 2010
I get way too much wind here. Crashed my plane into a power line today because of it. (and because of my bad piloting)
I am gonna be in Denver weekend after next, after Thanksgiving, a couple of us are getting together for some FPV if you are interested.
http://www.rcgroups.com/forums/showt...431921&page=32
volto is offline Find More Posts by volto
Old Nov 18, 2011, 02:28 AM
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Originally Posted by chatch15117 View Post
Here's the Rx antenna. I need to make a stand for it. Video coming shortly(30% uploaded)
The antenna looks nice. What surprizes me a bit is that you intend to go for a cloverleaf on the reciver end. You surely CAN do this, but a skew planar wheel would be a little better. Then, for the reciver antenna I would go for a bottom feed as it's easier to place it on the reciver. Other than this, I'm sure you will be pleased with the outcome!
Markus
markus123456 is offline Find More Posts by markus123456
Old Nov 18, 2011, 02:48 AM
Joined Apr 2011
What's the difference with a 4th lobe?(pros/cons)? I made a stand for my Rx cloverleaf today and it should be a bit better at 15 inches off my car instead of resting on the roof.
I have a feeling I'll be moving to UHF on a Turnigy 9X for Christmas. If you look at 6:00 in my video on the other page there is a cessna at my altitude about 500 meters west(flies from left of screen to right)... flew right by. I'm not sure why they keep looping around the lake. The executive airport is like 3 miles south and I'm in class D airspace.
Old Nov 18, 2011, 03:27 AM
Team White Llama!
gundamnitpete's Avatar
http://upload.wikimedia.org/wikipedi...o_Spectrum.jpg
Most likely because you are broadcasting in an aerial navigation band (1040mhz) next to an airport!
gundamnitpete is offline Find More Posts by gundamnitpete
Old Nov 18, 2011, 03:49 AM
Registered FPVer :)
Joined Aug 2006
Definately. Putting your side feed CL directly on the roof of your car is a bad idea. Make sure to have it high in the air. The higher the better genreally. I have mines on a tripod with a wooden stick on it resulting in a heigth of about 9 feets off the ground.
The fourth lobe (but pay attention, the lobes are of DIFFERENT size for the SPW) adds sensitivity to the antenna. In genreal, and especially for reciveing antennas you can't have enough wire in the air. The wires catch the signal, so the more wire you have, the more of a signal you can catch. Of course, the "wire" has to be shaped propperly and resonant etc but in general the equation is right. It would be a good idea to have even more lobes, but doing so would require to match/tune their lenght and positions to get the antenna propperly resonant. Others did that in the past, and one of Alex newer designs (Pentalobe) goes this way. But without measuring equipement and software to simulate such a new design, go for an SPW as there is a tutorial with propper formulas etc. The SPW is a wonderfull omni directional antenna that works very well.
That's for FPV in general a good idea. UHF systems are a lot more reliable, so it's not only a question of more range, but generally better link quality. FPV menas fun with flying low between trees etc, and there a UFH system comes in handy.
Maybe pete is right here. If the frequency you are on is illegal where you are you should change it.
Markus
Old Nov 18, 2011, 08:14 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
More on what Markus said: You can't simply add lobes. I wish it were that easy. The Skew wheel is generally better than the cloverleaf as an RX antenna. However, the omni distance record is set at 7.5 miles with a cloverleaf on the RX, so the change in performance isn't that much bigger.
I do have another 5 lobe design, but the geometry is very different to get it to work correctly. It is slightly better than the skew-wheel but I find the antennas is very fickle and therefore hard to get correct unlike the cloverleaf where you can really mess up and get a good antenna.
I have released the Pentalobe sphere antenne into the TV productioin world, but not FPV just yet. Still working on a few things before it's FPV ready
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Nov 18, 2011, 10:23 AM
Joined Sep 2008
Could I be a pain and get your thoughts on this?
I've built a SPW for the receiver end and I've built a Cloverleaf for the TX end. Both made from 0.8mm MIG wire. The cloverleaf is currently on a long piece of RG316, I've yet to add the connector.
So, I'm thinking of mounting the cloverleaf in one of two positions as seen in the picture below.
A. On top of the horizontal stabiliser, red line shows cable route
B. On the DPCAV Vee antenna mast, blue line shows cable route
I would love some advice on where you think the best position would be. I'm not very radio-wave intelligent and some, if not most, of the technical speak on the issue baffles me. Does cable length have a significant impact on performance?
And does anyone know of a tutorial of how to add the rp-sma connector, with particular attention to the measurements of wire stripping?
jonsky7 is offline Find More Posts by jonsky7
Old Nov 18, 2011, 10:39 AM
Joined Apr 2011
At high frequencies cable length matters but if you're on 900MHz you can get away with even a few feet of cable before worrying about attenuation.
I got some multipathing today. That interference caused my capture card to freak out and go all gray and lose sync(vsync?). Video is uploading and I'll post it later. I thought having my RX antenna mounted properly in the air would fix the problems but it doesn't seem like it did. It's 20-30mph winds now so I'll have to wait for saturday to fly again.
Old Nov 18, 2011, 11:00 AM
Registered FPVer :)
Joined Aug 2006
I would mount it on top of the rudder. Well, actually I did it this way on my Ez* with sucess. Just move the transmitter more backwards, that way the coax cable does not add damping as it can remain short. With all our FPV stuff in the plane it should not be a problem to move components in the cockpit to compensate the CG.
Markus
Old Nov 18, 2011, 11:57 AM
Joined Apr 2011
http://www.youtube.com/watch?v=wOpjOE7qYOo
Also if anyone can tell me why the video has apparent horizontal lines and jagged edges please tell me if I can fix that with OSD settings.
Old Nov 18, 2011, 12:47 PM
Joined Apr 2011
Here's the setup. I use the patch antenna base(not in use anymore) for structural support as a base for the cloverleaf. The silver rod is an old 72MHz antenna.
Maybe I'll move the antenna to the left wing. I like to fly in counter clockwise circles so that should work out nicely.
Old Nov 19, 2011, 08:24 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Looks like reflections off the patch panel to me. The cloverleaf has some disadvantages when it comes to ground reflections, unfortunately. This is why I designed the Pentalobe sphere. It fixes this problem.
-Alex
Old Nov 19, 2011, 09:25 AM
Joined Oct 2006
-Alex
Which combination of antenna types would you recommend along with the Pentalobe?
TX <-------------> RX
a) Pentalobe <-----> SPW
b) Pentalobe <-----> Helical
c) Pentalobe <-----> CP Patch
d) CL <------------> Pentalobe
Cheers,
Hartwig
hartwig is offline Find More Posts by hartwig
Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! IBCrazy Video Piloting (FPV/RPV) 1485 Today 07:41 PM
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy Video Piloting (FPV/RPV) 293 May 13, 2013 05:03 PM
Build Log IBCrazy's Minion - The ultimate FPV plane IBCrazy Video Piloting (FPV/RPV) 151 Apr 19, 2013 11:04 PM
Mini-HowTo IBCrazy's DIY antenna tracker!!! IBCrazy Video Piloting (FPV/RPV) 242 Mar 27, 2013 11:52 AM
Build Log IBCrazy's homebrew antenna tracker IBCrazy Video Piloting (FPV/RPV) 48 Oct 25, 2012 06:07 PM
