Old Nov 16, 2011, 05:15 PM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Originally Posted by idletime View Post
I'll take you up on your offer (PM you later)....but a quick question...how does the tuning affect the individual frequency...for example with this 5.8 Rx,
( CH1:5705 - CH2:5685 - CH3:5665 - CH4:5645 CH5:5885 - CH6:5905 - CH7:5925 - CH8:5945)
are you tuning for one particular channel?? And if so how much is the effect if you have to switch to another channel.
I'm just curious as to how it all works / relates.....thx
Yes, I build for the particular frequency one asks for. If you are on spot with the frequency, range and picture quality will be superior. This gets less efficient the farther away you go from this frequency. The other thing people sometimes forget is the fact that its good to have BOTH antennas on the same frequency. I mean if your tx antenna is 100Mhz below where it should be, but your rx is 100Mhz above (because you can't measure it), they are 200Mhz apart. Especially on the 5.8Ghz band, and more importantly if you use with the sky-rf based tx/rx (foxtech etc.) it's IMHO important not to shoot for the center frequency of 5.8Ghz as with the default band E of those products there is simply no channel near this center. With band E you have four channels going down from 5705Mhz and four going up from 5885Mhz. So the closest you could get to a center tuned antenna would be this channel 5 still being 85Mhz away from where it should be. Again, being off is not the end of the world as those antennas are somewhat wideband, but being on spot is the best you can get.
As I saw your post, I just finished tuning a 5.705G (foxtech channel 1) cloverleaf antenna. Attached you see two sweeps of this very antenna, one with the marker set to the wanted frequency of 5.705G, the other with the marker set to the center frequency of 5.8G. If you would have your antenna tuned to the center but operate it on channel 1, you would thus have about -23dB return loss (which equals an SWR of 1:1.4). Thats truly not bad, but on spot you have a return loss of -50dB which equals an almost ideal SWR of 1:1. So, why not makeing it as good as possible if you can? This IMHO especially holds true for the transmitter antenna as any return loss means this, a loss in transmitted energy.
Markus
markus123456 is offline Find More Posts by markus123456
Old Nov 16, 2011, 05:17 PM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
You could tell him what channel you use and then he will tune to that frequency... or you could have him tune it to the middle channel. Or tune it to the average of the difference in frequency. It's your call.
I'm making the 115 antenna now and I'll post back if it works.
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Old Nov 16, 2011, 06:17 PM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
Well it will work. But that's not the question. The question is how well it will work. And you really can't tell that accurately without test equipment.
pdiddyg40 is offline Find More Posts by pdiddyg40
Old Nov 16, 2011, 06:57 PM
Joined Apr 2011
I wish someone in my area had test equipment. I'll ask around. I used a combination of sulfuric and hydrochloric acid to remove the insulation. Clean, bare copper ready for soldering!
Old Nov 16, 2011, 07:27 PM
Joined Apr 2011
I really hope it works well lol... following everything so I can have within 1% tolerance.
Old Nov 17, 2011, 02:32 AM
Registered FPVer :)
Joined Aug 2006
No worries, the way you aproach it and on this frequency you will be pleased with the result. Just be carefull with soldering the coax cable so as you don't create a short. Keep the connection to the antenna "tight" in that you don't have a big distance from the ground mesh and the center where they connect to the propper antenna elements.
Markus
Old Nov 17, 2011, 03:17 AM
Joined Apr 2011
I finished them. I'll post a video tomorrow of my flight. More like in 4 hours haha, it's 4am here
Old Nov 17, 2011, 03:48 AM
Registered FPVer :)
Joined Aug 2006
Show us a picture of the finished antenna.
Good luck with the test fligth, and good night. Over here it's 10:48 am, so no nighty night
Markus
Old Nov 17, 2011, 05:20 PM
Yabba is offline
Find More Posts by Yabba
Gravity - It's the law
Yabba's Avatar
USA, CO, Denver
Joined Jul 2008
Hi all,
I have one of Alex's Video Aerial Systems CPCL on my GS and I built one for my plane.
I mounted the antenna on the bottom of the plane and I'm very pleased with the results BUT....
This is about the cleanest video I have ever gotten so I'm really happy and if I can duplicate the lack of breaking and tearing of the video tomorrow I will try going under the hood.
But can Alex or one of you tell me, is the interference at 2:35 multipathing or from external RF or what. I can live with the amount of interference in this video but is this about the best I can expect using my current setup? Or should I try something else before I trust this setup completely?
Thanks for any help,
Yabba
multipathing, or ? (4 min 41 sec)
Yabba is offline Find More Posts by Yabba
Old Nov 17, 2011, 06:02 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Yes that's multipathing. Pretty minimal really. Perfectly flyable. It looks to me like ground reflections. I think you are good to fly. Seriously, that's a solid video link.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Nov 17, 2011, 06:07 PM
Yabba is offline
Yabba's Avatar
USA, CO, Denver
Joined Jul 2008
-Alex
That's the way I felt but it's good to hear it from someone like you.
I appreciate all you have done for me and for the Community.
Yabba
Old Nov 17, 2011, 08:33 PM
Joined Apr 2011
Here's the Rx antenna. I need to make a stand for it. Video coming shortly(30% uploaded)
Old Nov 17, 2011, 09:20 PM
Joined Apr 2011
http://www.youtube.com/watch?v=t3NFRokr8I8
Old Nov 17, 2011, 10:19 PM
volto is offline
Find More Posts by volto
Navigator
volto's Avatar
USA, CO, Durango
Joined Sep 2010
Yabba, I would be more worried about that serious camera wobble. That would drive me crazy.
volto is offline Find More Posts by volto
Old Nov 17, 2011, 10:25 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
interesting templates. where did you get them? you make them? want to add them to OP? should help in constructiong this antennas.
gundamnitpete is offline Find More Posts by gundamnitpete
Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! IBCrazy FPV Equipment 2368 Apr 23, 2016 04:12 AM
Mini-HowTo IBCrazy's DIY antenna tracker!!! IBCrazy FPV Equipment 459 Mar 30, 2016 06:38 AM
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy FPV Talk 357 Dec 10, 2015 06:40 AM
Build Log IBCrazy's Minion - The ultimate FPV plane IBCrazy FPV Aircraft 151 Apr 19, 2013 11:04 PM
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
