Old Nov 16, 2011, 09:11 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Originally Posted by chatch15117 View Post
I'm doing a more accurate approach to my antenna build this time... plotting the drawings so I can have them exactly perfect.
One odd thing - the arc length is 141.69 but my half wavelength is 147.605... why are these different? The angle I used is 110
Based on what you say it's not clear to me wether you used Alex's measures as a base for the complete lobes or if you draw them according to what you think they should be and now realize that there is a difference.
Alex's measures do not only base on the wave lenght alone. There is the velocity factor of air that must be compensated, and depending on the antenna construction there are other correction factors that have to be applied. I.e. the more lobes one of those antennas is having, the shorter each lobe has to be because of one lobe affecting the function of the nearby lobes just to give you one example out of quite a few things to consider.
HTH
Markus
markus123456 is offline Find More Posts by markus123456
Old Nov 16, 2011, 11:03 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by Vantasstic View Post
I'm flying my long range fixed wing FPV plane on 1280MHz and have a 5.8Ghz VTx/VRx system coming in for closer in 'video quadcoopter' use. I wanted to try CL antenna's on both platforms. Is there a 'preferred' OD MIG wire that will cover both freqs or just the range of diameters mentioned at the beginning of this thread?
.035" wire for the 1280MHz and .023" for the 5.8GHz for best results. Changing wire thickness changes the impedance.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Nov 16, 2011, 11:49 AM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
HTH
Markus
No, I'm talking about simple geometry. The directions call for the lobe to be 1/2 wavelength long. So that's 614035/1040/4 per Alex's instructions. When you bend the curve, the arc length obviously does not change. The angle changes, and he says it is 110. Unless you don't have a perfect arc you simply can't fit 1/2 wavelength in 110 with the two sides(the radius...) being 1/4 wavelength. The ending angle would be about 114.59, not 110
The angle is the ratio of the side to the raidus. This is simply 2.
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Old Nov 16, 2011, 11:59 AM
charlienofun is offline
Find More Posts by charlienofun
charlienofun's Avatar
United States, CA, Santa Clara
Joined Mar 2008
I also made a template for myself to create some 5.8Ghz clovers and got stuck at the same measurement. If I could get mine right I would post them here, I think they can make constructing the smaller clovers much easier just lay the cut wires on paper and bend to match etc.
-Charlie
charlienofun is offline Find More Posts by charlienofun
Old Nov 16, 2011, 12:15 PM
Joined Apr 2011
I'll wait for Alex to post back before I go bending more wires into non-optimal configurations . These things aren't cheap!
Old Nov 16, 2011, 12:23 PM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
They're not Mig wire is... well... almost free
pdiddyg40 is offline Find More Posts by pdiddyg40
Old Nov 16, 2011, 12:35 PM
yzguy is offline
Find More Posts by yzguy
yzguy's Avatar
Florida
Joined Mar 2007
I'm not sure the center for the radius of the arc is the intersection of the 2 base legs. If you make the radius a little shorter, and move the center for the arc a bit further up, you can fit a longer length of arc between the same 2 points. (this will also make the angle at those points a bit larger than 90 degrees)
yzguy is offline Find More Posts by yzguy
Old Nov 16, 2011, 12:41 PM
Joined Apr 2011
Time is money . I spent like 3 hours on the last set that didn't work
That may be it. But I was drawing from this picture in OP.
Old Nov 16, 2011, 01:16 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Hey guys,
I need some help. :-)
I am trying to find ready made 5.8 Ghz antennas (Alex's Blue Beam) and it seams no one have them in stock even the Master :-).
I am not able to make my own since i do not have a tools to calibrate or access to exact wire. So would someone here be able to make a set for me.
Oh, I am not asking for freebee. Thx.
nakelp86 is offline Find More Posts by nakelp86
Old Nov 16, 2011, 02:45 PM
Registered FPVer :)
Joined Aug 2006
Originally Posted by nakelp86 View Post
Hey guys,
I build a pair fine tuned SPW/CL for you if you want. I ask $20 per antenna. Registered shipping is $15.50 if you are within the EU, $18 elsewhere. Send me a PM if you are interested.
Markus
Old Nov 16, 2011, 02:59 PM
Registered FPVer :)
Joined Aug 2006
I think I understood you well. What I tried to say is that Alex numbers of the legs and angles etc. are only aproximations as you don't need that angle if you follow his build instructions. You only need it if you want to do what you do. So, if you want to end up with the same thing like in the instructions, draw them the same way. In other words, draw the legs with the measures given, then make an arc between the two that is the given wire lenght minus the two legs.
I already build quite a few of those antennas and I don't know which frequency you are targeting. If it's 5.8, no chance to get it optimal no matter what build quality you use. There are too many factors. So your work will be an aproximation, but at the same time I can tell you that it will work, and it will work better than linear antennas. It will be a matter of luck how well it will work, and no single antenna will be the same. That's totally ok if you don't strive to make a range record and are happy with an average result which again is probably fine for many people.
If the frequency is 2.4, or lower, things are a lot more relaxed and the antenna will be close to your targeted frequency. Again, if you intend to end up with a resonant antenna on a given 5.8Ghz band frequency, you won't have a chance without the propper measuring equipement. I have optimized my build process to a very very high degree and still I have to tune every single antenna on my vector network analyzer. When measuring out antennas made by others or those first ones I made myself, I could see how much off I was. Usually pretty dramatic, like 100 or even 200Mhz or more. However, the antennas worked. Only range and picture quality are not on par with really fine tuned ones.
Markus
Old Nov 16, 2011, 03:46 PM
Joined Apr 2011
I'm buiding for 1040MHz. Thanks.
Old Nov 16, 2011, 04:08 PM
Registered FPVer :)
Joined Aug 2006
That should be fairly relaxed. So don't overthink this. If the overall lenght of your drawing matches the wire measures given by Alex in their total lenght you are definately ok. The angle and as a result even the shape of the arc are not so very critical - especially not on lower freuqencies.
Markus
Old Nov 16, 2011, 04:15 PM
idletime is offline
Find More Posts by idletime
idletime's Avatar
Canada, ON, Toronto
Joined Apr 2011
Markus
I'll take you up on your offer (PM you later)....but a quick question...how does the tuning affect the individual frequency...for example with this 5.8 Rx,
( CH1:5705 - CH2:5685 - CH3:5665 - CH4:5645 CH5:5885 - CH6:5905 - CH7:5925 - CH8:5945)
are you tuning for one particular channel?? And if so how much is the effect if you have to switch to another channel.
I'm just curious as to how it all works / relates.....thx
idletime is offline Find More Posts by idletime
Old Nov 16, 2011, 04:45 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Markus
PM sent :-)
Thx.
Mini-HowTo IBCrazy's DIY antenna tracker!!! IBCrazy FPV Equipment 460 Today 06:09 PM
Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! IBCrazy FPV Equipment 2390 Today 01:54 PM
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy FPV Talk 359 Jun 26, 2016 02:04 PM
Build Log IBCrazy's Minion - The ultimate FPV plane IBCrazy FPV Aircraft 151 Apr 19, 2013 11:04 PM
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
