Old Nov 04, 2011, 03:52 PM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Originally Posted by IBCrazy View Post
Jack, when using a helical there are only two rules that MUST be followed precisely in order for the helical to work effectively.
Rule #1: Aim
Rule #2: Fly
That's it. Put it in the air or the ground. Your choice so long as the Fresnel zone is clear.
-Alex
Thank you much Alex.
nakelp86 is offline Find More Posts by nakelp86
Old Nov 04, 2011, 08:47 PM
yanickr1973 is offline
Find More Posts by yanickr1973
Zebro
yanickr1973's Avatar
Canada, QC, Blainville
Joined Sep 2007
Hi everybody, I just built my first cloverleaf for 2.4 ghz thank you alex for your incredible tutorial, everything went well and i am very happy with the build.
Now my question: I saw on the site http://videoaerialsystems.com the antenna pair... a cloverleaf for tx a one with 4 lobes for the rx...
I am about to build the antenna for the rx and wonder if i should build the 4 lobes one?
will i see a big difference compared to the cloverleaf?
Thank you !
yanickr1973 is offline Find More Posts by yanickr1973
Old Nov 05, 2011, 12:14 AM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
one with 4 lobes (Skewed Planar wheel) for the rx...
Thank you !
Skewed Planar Wheel is a great antenna for the Rx
m_beeson is offline Find More Posts by m_beeson
Old Nov 06, 2011, 07:12 AM
teopbako is offline
Find More Posts by teopbako
Ikaruswannab
Joined Sep 2009
Does a cloverleaf qualify for RC receiver antenna???
teopbako is offline Find More Posts by teopbako
Old Nov 06, 2011, 01:48 PM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
Sure Many people will suggest using a Skew-wheel but I've been using a cloverleaf with great results.
pdiddyg40 is offline Find More Posts by pdiddyg40
Old Nov 07, 2011, 05:21 AM
Zebro
Joined Sep 2007
I builded a cloverleaf and a skew planar for 2.4ghz
My 2.4 system is in the mail so i tested them on 900mhz inside the house and i got a good picture so at least i know they are working
I have a concern ...my brother read somewhere that cp antennas kill long range systems...
is that true?
I fly using a Rmilec LRS (400-470 mhz)
Will I affect my range with a cloverleaf on my video tx?
Thank's
Old Nov 07, 2011, 05:40 AM
pdiddyg40's Avatar
Joined Jul 2008
is that true?
Thank's
Testing your 2.4 antennas on 900 doesn't really show anything about their performance, but I guess it does show that they work. I'm so paranoid about burning a $75 VTx that I never plug in anything that doesn't belong there
The range killing thing is something I've never really heard before- and I think that it's a bit unfounded. If everything checked out okay with your LP antennas, everything should be fine with your CP antennas. The antennas shouldn't make a difference.
Old Nov 07, 2011, 06:50 AM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
is that true?
Thank's
It's my impression that after the "first shock" people now start to talk about CP antennas which probably should not do so. Unfortunately everybody in forums can post whatever he/she likes. A badly tuned antenna can disturb other systems but this holds true for cirular polarized antennas as well as linear antennas. Especially the so widespread used whip antennas are more than often of very bad quality easily leading to such side effects. So as a general statement what your brother read is plain and simply wrong.
Markus
markus123456 is offline Find More Posts by markus123456
Old Nov 07, 2011, 07:21 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I use it as an RX antenna from time to time. It works fine.
_Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Nov 07, 2011, 07:22 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Thank you !
For 2.4 GHz you will see some difference. Not much, but the 4 lobe is certainly better. That's the reason I sell them as a paired set.
-Alex
Old Nov 07, 2011, 08:45 AM
Zebro
Joined Sep 2007
Right now i always fly within a range of less than 2km
So should i stay with only one rx fitted with the skew plannar
Or would there be an advantage to build a diversity for such short range?
Old Nov 08, 2011, 06:17 AM
HeliEye is offline
Find More Posts by HeliEye
HeliEye's Avatar
Stevenage, Hertfordshire
Joined Dec 2007
800mW 5.8GHz Transmitter Manual
Originally Posted by scoobysport View Post
Great topic, everything looks clear and understandable even to me
Been working my way through this topic today, but with this topic in mind and Alex's website i got a little confused.
I use my twinstar mostly above water and am fairly new to FPV flying. I quickly got out of range with my kit (5.8ghz Fatshark kit, 100mw transmitter, also got an 800mw but it performed worse than the 100mw so i'm guessing it's faulty) so want to build/buy CL and/or SPW / Helical antenna.
What would now be my best option/combo? I was thinking of building the CL's for my RX and TX, but on Alex's site it's mentioned it's better to use a helical for the RX? And on this forum CL on the TX and SPW on the RX are advised... So i'm not sure now what to build/buy.
Thanks in advance for you help guys! and Kudo's to alex for writing this up!
Hi Scoobysport here's a link to the manual for your 800mW TX
http://www.electronicarc.es/AVTX58v1.0.pdf
Hope this helps
Steve
HeliEye is offline Find More Posts by HeliEye
Old Nov 08, 2011, 08:47 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
This is strictly your call. Nobody can tell you what you need except you. Without knowing the environment, type of flying, noise floor, ect, we can't even begin to guess. If what you have works, why change?
-Alex
Old Nov 08, 2011, 07:19 PM
Zebro
Joined Sep 2007
Thank you for taking the time to answer my questions
right now i don't have a setup that works so my questions are to try to have a set up that will give me the best chances of success
recently i lost a plane that was working perfectly using 900mhz video and a Rmilec LRS
I bought everything back and now it seems nothing want's to work well
good thing is i have my brother living 2 streets from me who fly FPV too so we have pretty much everything in double quantity so this helps a lot for troubleshooting
After much troubleshooting i think i found the culprit...my LRH system. what i find strange is that i changed nothing on the rc tx side...but now my rmilec affects my video reception to the point that it is impossible to fly, i have reception on the ground but as soon as i take off i loose reception. i tryed my new hobbycrap 900 mhz and my brother's 1.3ghz systems and it is the same with both. I ruled out the plane as the problem because i have this problem even with the camera and video tx out of the plane.
took me a while to figure out because i had absolutely no issues before with my rmilec
now i ordered a 2.4ghz (should be here tomorrow according to tracking) i also ordered a low pass filter to put on the rmilec to see if this will help.
my googles are cheap google made by my brother from videogame googles(trimmersion i think?)...anyway now they are unusable as soon as i power on my rc tx so i ordered fatsharks base edition.
so thats it...for now i am mostly fed up with this but trying to see the positive: when done i will know my system inside-out and knowledge is always a good thing !
sorry for my english...hope you understand me
Thank's again!
Old Nov 10, 2011, 07:08 AM
lrrps is offline
Find More Posts by lrrps
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
I just received my 5.8Ghz VTX and VRX, they both have a male connector, as the antennaes I bought from Alex also have male connectors, the only thing to do is to install a female/female adapter between the antenna and the TX or RX, do you confirm that there won't be any loss if I go this way?
Where to buy these adapter?
Uploaded with ImageShack.us
lrrps is offline Find More Posts by lrrps
Mini-HowTo Circularly Polarized Helical antenna 7.5 -13 dbi - New: Wave Trap match! IBCrazy FPV Equipment 2407 Sep 01, 2016 06:01 PM
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy FPV Talk 360 Aug 08, 2016 10:44 AM
Mini-HowTo IBCrazy's DIY antenna tracker!!! IBCrazy FPV Equipment 461 Aug 07, 2016 09:36 PM
Build Log IBCrazy's Minion - The ultimate FPV plane IBCrazy FPV Aircraft 151 Apr 19, 2013 11:04 PM
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
