Old Feb 11, 2011, 03:58 PM
EyeFellOver is offline
Find More Posts by EyeFellOver
England
Joined Feb 2011
Question
Custom Quad Frame Design
I'm currently designing a custom frame for my 1st quad and I've got a few questions.
First, here are the pics:
The arms will be made out of Square Tube Aluminium that is 12.5mm x 12.5mm x 1.6mm. The central hub will be made from either milled/cast aluminium or printed on a 3d printer depending on strength.
I have left a 1mm gap around the arms where they mount to the hub for thin rubber sheeting, this should help reduce vibrations and as far as I can tell that's a good thing! Is it needed though?
Has anyone got experience of making parts by printing them on a 3d printer? The one I'll be using is a Z Corp 310 Plus but I'm not sure of the material they have at the moment.
Is a 432mm motor to motor span adequate? I was working on the idea of using 9x4 props and this gives me the required additional space but I'm not sure.
I'd also love advice on a cheap motor/esc/prop combination that would be good for a newbie on a budget
EyeFellOver is offline Find More Posts by EyeFellOver
Old Feb 14, 2011, 02:25 AM
reph is offline
Find More Posts by reph
Joined Jan 2009
Consider the HobbyKing 12A BlueSeries ESC, 2205C motor, and APC 8x3.8 props. Expecting ~350g thrust per motor. More importantly, actually in stock.
reph is offline Find More Posts by reph
Old Feb 14, 2011, 09:49 AM
jes1111 is offline
Find More Posts by jes1111
United Kingdom, England, Weston-super-Mare
Joined Jul 2010
I wouldn't use rubber between the arms and the fuselage. Although I can't speak from experience, I believe it will harm performance. It may well (help) reduce vibration, but you don't want a flexible airframe. Quite the opposite: you want the entire airframe to be as rigid as possible.
jes1111 is offline Find More Posts by jes1111
Old Feb 14, 2011, 03:15 PM
England
Joined Feb 2011
Thanks guys. Jes, that makes a lot of sense! Now I think the vibration reduction would be better localised to the Gyros rather than the whole central hub.
Reph, those parts look good! Have you got a link to the props because I can't seem to find them.
Does the overall thrust multiply exactly or is there a reduction as you add more motors? I.e.
4 motors x 350g = 1400g of total thrust?
Old Feb 15, 2011, 03:23 PM
maidenlnnium is offline
Find More Posts by maidenlnnium
Joined Feb 2011
hello
these plate's are for sale at ebay.de (Mikrokopter Quadrokopter X-Ufo Alu Rahmen Set)
perhaps you can find more info there.
martin
maidenlnnium is offline Find More Posts by maidenlnnium
Old Feb 15, 2011, 03:25 PM
vic20owner is offline
Find More Posts by vic20owner
LOAD "FLIP-FPV",8,1
vic20owner's Avatar
Joined Sep 2006
Hmm looks like a solution in need of a problem, but I am in no way knocking your design ability. Looks great hopefully it will offer the improvement you are seeking.
vic20owner is offline Find More Posts by vic20owner
Old Feb 15, 2011, 05:22 PM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Originally Posted by maidenlnnium View Post
hello
martin
Yep, I have one of these:
http://cgi.ebay.de/Mikrokopter-Quadr...item45f8b6da56
kinderkram is offline Find More Posts by kinderkram
Old Feb 16, 2011, 02:14 AM
England
Joined Feb 2011
Thanks guys.
That was actually the frame design I was copying, I wanted to order one but Google Translate makes a right mess of the eBay page so I couldn't really understand what I'd be getting! Do you get the cross plates, the end pieces, and the power distribution board?
Can I order from the guy on here to save translating german ebay?!
Also, is this a good frame to use with the Wartox board?
Cheers!
Discussion Quad frame idea for safety andrewonline Multirotor Talk 10 Mar 06, 2011 03:43 PM
Wanted Quad and/or Hexa frame - MK frame / Flexlander beeker_12 Aircraft - Electric - Helis (FS/W) 1 Feb 18, 2011 07:04 PM
Discussion QuadCopter frame design papirkopi Multirotor Talk 3 Feb 09, 2011 03:30 AM
Discussion QUAD FPV Super Landing Gear? How to make this design? hardhat Multirotor Talk 3 Dec 19, 2010 07:01 PM
New Product Custom frames and frame design rp181 Multirotor Talk 24 Sep 23, 2010 03:49 PM
