Old Mar 07, 2011, 05:43 PM
studioRS is offline
Find More Posts by studioRS
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
Originally Posted by DL8698 View Post
Sorry if I have caused confusion by bringing the DG1000 into the picture.
Awe, no worries. I have a DG-1000 too (ST-Model EPO version).
studioRS is offline Find More Posts by studioRS
Old Mar 07, 2011, 10:43 PM
trub is offline
Find More Posts by trub
Mr T
trub's Avatar
New Zealand, Manawatu-Wanganui, Feilding
Joined Dec 2009
I'm using the Turnigy SK35-48 900 http://www.hobbyking.com/hobbyking/s...idProduct=7393 with a 60A ESC.
900 KV on 3S battery.
I get about 250-280 watts measured with a Tamazo DC Watt meter.
Edit: Apologies, I should have mentioned that this setup is for my DG1000, not for a Ventus.
Have you tried with a similar sized 4 cell battery, that should get it up. That motor is more powerfull than mine, and I hauling a 4m bird up with not too much drama. link to that motor http://www.hobbyking.com/hobbyking/s...idProduct=7708
with 12/8 folding prop. For my ventus I have lined up a much smaller motor,
http://www.hobbyking.com/hobbyking/s...idProduct=2112
I had to reverse the shaft, I hope it will fit without packing it out too much - but I still waiting for them to dispatch my order, so likely wont recieve my ventus for three + weeks, damn slow HK.
trub is offline Find More Posts by trub
Old Mar 08, 2011, 12:22 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
I know what you mean about slow,I am now held up waiting for parts also.
Shame we cant PM directly to Anthony Hand .
Interview with him here.http://www.rcgroups.com/forums/showp...4&postcount=22
olmod is offline Find More Posts by olmod
Old Mar 08, 2011, 08:33 AM
JORGEVAL is offline
Find More Posts by JORGEVAL
Joined Oct 2010
this is my setup:
motor:http://www.hobbyking.com/hobbyking/s...idProduct=5690
esc:http://www.hobbyking.com/hobbyking/s...idProduct=9482
servos:http://www.hobbyking.com/hobbyking/s...idProduct=9392
train servo:http://www.hobbyking.com/hobbyking/s...idProduct=9392
receiver:http://www.hobbyking.com/hobbyking/s...dProduct=14300
prop:10*8
the axle motor must be fitted in the other side of the motor.
i will try to put photos but i am very bad with the pc....
i have all mounted and configurated,only need to use epoxy for the union
JORGEVAL is offline Find More Posts by JORGEVAL
Old Mar 08, 2011, 08:34 AM
JORGEVAL is offline
Joined Oct 2010
with this motor you dont need to add wood like the motor ok olmod.it fits perfectly.
Old Mar 08, 2011, 09:54 AM
studioRS is offline
Klassische Bilder
studioRS's Avatar
Northern Vermont
Joined Jul 2010
@JORGEVAL - thank you for your links, this is helpful. You were able to post your setup using your PC and indeed very clever
@olmod
@trub
fyi, I placed my order on 4/3/2011 and just this morning was "dispatched" and shipped 4 days later within the JIT window as indicated. I choose the least amount of shipping costs to New England, USA (Air Parcel (UNITED STATES) 2500g - 2999g $36.54). Hopefully it arrives within two weeks.
Yes, it would be nice to PM Anthony! I bet everyone also would like to do the same, he'd need a very large inbox...
Old Mar 08, 2011, 04:16 PM
thanos_kal is offline
Find More Posts by thanos_kal
Greece, Attica, Athens
Joined Jan 2010
@Olmod
Very nice building log. Helps alot since I am in the process of ordering the ventus.
But I have not read any real flight experience. Does anybody have maiden the plane to share some comments with us ?
thanos_kal is offline Find More Posts by thanos_kal
Old Mar 08, 2011, 04:44 PM
olmod is offline
olmod's Avatar
Joined Apr 2004
Originally Posted by JORGEVAL View Post
this is my setup:
prop:10*8
The servos you selected may be to thick for the wings,you need a thickness ~10mm.
Old Mar 09, 2011, 11:28 AM
JORGEVAL is offline
Joined Oct 2010
if you are careful with the dremel you can make deeper the servo space.iwas going to do the same that in the blizzard mpx(the servo can be seen in both sides),but is not necesary.
Sorry by the english because i dont talk very well(i am spanish).
Old Mar 09, 2011, 02:14 PM
delfin is offline
Find More Posts by delfin
Joined Mar 2009
After reading many days in this tread, always waiting for news, I started to build my Ventus as soon I had received it. As I found the tail too thin and weak, I added a 6mm carbon tube from the end of the fuselage to the wings (sharpen one end of the carbon so that it looks like a saw and drill it with the aid of a akku-drill through the tail). To reinforce the wing tips I added a 3x1x 250mm carbon spar to the underside of the wing.
Weight of the plane 735gr + 2s Lipo 1400mAh: 90gr. Motor Turnigy 2830-1050 (which was on hand), Aeronaut cam carbon 11x8, 40mm spinner, 2s lipo 1400mah, all servos Turnigy 18ooA. I did not yet install a servo for the wheel, as I have no free channel on my TX (Hitec Eclipse with Assan-module). I cut the nose about 4mm, as the motor is a bit too short. CG is about at the servo cable channel, but should be probably further aft, will try the next days.
First flight impression: wings are far too "wobbly", for the second flight I installed a 35cm aluminium tube (10mm) to join the front wing spars, (I had to drill it into the wing with the same method as above), I also added a 6mm carbon tube to the aluminium wing joiner. 2. flight: much better now. With this motor/prop/lipo setup the Ventus climbs at an angle of about 20 degrees quite fast. After stopping the motor, it looses its heigth also fast. No slow curving around as with an "EasyGlider", it wants to be flown fast, it seems better for soaring than thermal gliding. Landing is slow and very easy when applying "crow"-mix. I hope this helps others when building a Ventus.
delfin is offline Find More Posts by delfin
Old Mar 09, 2011, 02:39 PM
ddruck is offline
Find More Posts by ddruck
ddruck's Avatar
Canada, ON, Pickering
Joined Nov 2006
Delfin, what is your total flying weight then?
Dan
ddruck is offline Find More Posts by ddruck
Old Mar 09, 2011, 02:46 PM
delfin is offline
Joined Mar 2009
735gr + 90gr lipo = 825gr.
Delfin
Old Mar 09, 2011, 03:00 PM
ddruck is offline
ddruck's Avatar
Joined Nov 2006
Ok, I was not sure if all was included in that 735g plus battery.
So at 825g total and 336 sq in, we have a wing loading of 12.5oz/sq ft or 38g/sq dm so the cube loading is 8oz/ cubic ft , That is no thermal soarer but it will fly, so removing the landing gear and servo is a good idea to save weight, it looked like it will be hefty, it is the lack of wing area that is worrisome.
Thanks, Dan
Old Mar 09, 2011, 03:09 PM
olmod is offline
olmod's Avatar
Joined Apr 2004
Delfin
Thanks for the input ,I also thought of beefing up the tail fin and boom but as I did not know the final cg position and left the cf out , did you get enough flight time to accertain wether the dropping of altitude was due to suddenly cutting the motor which often happens ,I always cut the motor slowly, You make no mention of your cg ? any glide tests before firing up?.
Old Mar 09, 2011, 03:47 PM
delfin is offline
Joined Mar 2009
I think flight time was at least 10 minutes, but I did not stop it. Motor is on a switch, as I need the throttle stick for the flaps. It was not because of the sudden motor stops, but I just wanted to say that the "gliding angle" and the speed of the model brings it back to the earth much faster compared for example to an "EasyGlider". CG was where the servo cables are under the wing (about 38mm from leading edge) I did no glide test, just started with motor on and running some meters to give the model enough speed. Elevator trim set upwards a bit, CG seems to be still too far forward. Now it's time to sleep in Europe, good night.
Discussion Hobby City's EPO 3d-Hawk Boxhead 3D Foamies 510 Dec 15, 2014 11:46 PM
Discussion ASW 28 EPO from Hobby City - thoughts? Angelo Electric Sailplanes 298 Jul 13, 2011 08:08 AM
Discussion 70mm composite L-39 from Hobby City unknown flyer Electric Ducted Fan Jet Talk 12 Dec 04, 2010 03:14 PM
Discussion Hobby King(city) Vs Hobby Partz mikeruth Vendor Talk 21 Nov 03, 2010 08:38 PM
Sold PRICE DROP - WOW! Hobby City F-14 Tomcat with 2 Dons Wicked 4000 NIB MinneFlyer Aircraft - Electric - Jets (FS/W) 9 Sep 06, 2010 10:38 PM
