Re post 146 I will ask again can someone measure the tailplane angle against the centreline of the fuselage please.
Latest blog entry: For motor builders
Sverige, Västra Götalands Län, Trollhättan
Joined Oct 2006
Ventus PNF kit has arrived
Hi!
My Ventus has arrived now and I wanted to show the kit content's. The only things to do before flying is to glue vert stab, attach wings, install RX. Then it's just to grab a battery and leave for the field. I will do that later on today so I'll get back to you with a maiden flight report. The installation of servos and other stuff seems good. The servos provided are HXT900 except for the LG servo which I can't see the label on. The supplied folder prop is 10x7 and it was quite unbalanced. I'm replacing the folder hub with one I have on the shelf.
Thanks Ken I can make corrections now.
Would it better to just reinforce the weak area with Glass Fibre wrapped around on the outside? Or a long flat CF strip (I have 3mm width x 1 mm thick) sandwiched between the 2 fuselage halves on the bottom edge, with the width vertical. Would look nicer than the CF wrap. I also probably would remove the hump you mentioned. |
I think that the problem of rear fuselage breakage is caused by the unequal lengths of the fuselage halves putting a weak point just in front of the fin. This is just where you want the fuselage to be strongest. I plan to put some CF reinforcement through this join but I have not decided exacty how to do it yet. When I do I will post some photos. I have been too busy building a Hobby King 55 inch span SE-5a. Ken |
UK, North Down, Bangor
Joined Nov 2009
Would this plane make a good replacement/upgrade from this one?
http://www.hobbyking.com/hobbyking/s...idProduct=8372
? My ASW is needing retired. My first plane, but it's just a little beat up by now.
My Ventus arrived yesterday evening while I was at work. Went home at 2 am and quickly opened the box.
The foam was very nicely moulded, so smooth. However on examining every part more closely, found the "built in" weak point at the fuselage fin base is half cracked. Beats the hell out of me why HK did not choose a point further forward to have the production break. (didn't notice the pun till I typed it in!) Wonder if the Towerpro 2409 with 2s battery is powerful enough? Originally wanted to use my Dualsky XM2830CA-12 but just found out the smallest 3s battery I have is 1750mah which I think is too heavy. I have 2 questions regarding the wing joining. 1. With the Alum wing joiner in the middle holding the 2 Alum wing spars, does the CF rod still contribute anything to the strength of the joint? 2. Can I use the supplied CF rod in the Front spar instead, and rely solely on the Alum joiner for the rear spar? An idea I am considering for holding the wings together is this: I won't use the supplied Alum joiner, but instead I epoxy small tongues on the ends of both the Alum spars, so that they overlap each other when the wings are inserted into the fuselage. Then all I need is to shove a tight fitting pin through concentric holes in the tongues. For this option I will have to rely on the CF rod in the Alum spars to provide all the strength. But the CF rod looks a bit skinny. If this idea is not good, then I will use the original Alum joiner, but I will make tiny dimples on the Alum spar ends where the grub screw sits, so that the grub screw need not be tightened too much, risking thread stripping. |
After taking a close look at the wings, I find that the Alum rear spars are only 16 cm long. I don't think that contributes much to strength of the joint. So I will be using the supplied CF rod in the front spar where it fits perfectly. The front spars run nearly all the way to the wing tips, so that's where I want the wing joint strength to be. I consider the rear Alum spar merely as a way of preventing the wings from detaching during flight.
I have 2 ideas in mind for the retractable gear piece. Either I detach the wheel and the retract mechanism from the platform and just fit the platform (this still gives me the option of fitting in the wheel mechanism later), or I don't fit the entire piece. Don't really think I need wheel for belly landing on grass. This will help to reduce weight. I am still waiting for anyone to comment on my choice of the Towerpro 2409 motor before I start assembling the fuselage.
I bought the early version of this Ventus from HK and it has been sitting in my workshop while building other gliders, Got a used F3J 3m, old but good quality, I fly regularly my full house Easy Glider pro and standard Radian. After following this thread and having another look at this glider in the box, I have decided that it was a waist of servos and sold it yesterday. Good luck guys, happy flying!
Dan |
Joined Mar 2009
I think the main load bearing spar is the front spar, which goes almost to the wing tips, not the rear spar, which I don't really consider is a spar, being only 16 cm long for a wing half length of 1m. So my cf rod is going to the front spar. I will fix a tube to the fuselage for the cf rod to fit into to strengthen the rod at the center area inside the fuselage. I will use a tube, maybe brass or copper, to replace the supplied alum wing joiner. I'll epoxy one end of my replacement joiner to one wing alum spar end, then drill a small hole through this tube and the other alum spar end, and just use a pin to lock the wings together. I really don't like to fix the wings with the grub screws. |
I agree about the alloy tube /grubscrew idea could have been done better with a nylon shear pin and sleeve assembly.
bigger allerons and elevator would have been nice. |
| Thread Tools | |
| Discussion Hobby City's EPO 3d-Hawk | Boxhead | 3D Foamies | 438 | Jun 13, 2013 07:27 AM |
| Discussion ASW 28 EPO from Hobby City - thoughts? | Angelo | Electric Sailplanes | 298 | Jul 13, 2011 08:08 AM |
| Discussion 70mm composite L-39 from Hobby City | unknown flyer | Electric Ducted Fan Jet Talk | 12 | Dec 04, 2010 03:14 PM |
| Discussion Hobby King(city) Vs Hobby Partz | mikeruth | Vendor Talk | 21 | Nov 03, 2010 08:38 PM |
| Sold PRICE DROP - WOW! Hobby City F-14 Tomcat with 2 Dons Wicked 4000 NIB | MinneFlyer | Aircraft - Electric - Jets (FS/W) | 9 | Sep 06, 2010 10:38 PM |
