Old Feb 11, 2011, 08:03 AM
olmod is online now
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Hobby city epo ventus
I could not resist one of these http://www.hobbycity.com/hobbycity/s...dProduct=16582 even if it means doing a few mod's I'll keep you posted on kit quality ect. cheers Lez.
olmod is online now Find More Posts by olmod
Old Feb 11, 2011, 09:01 PM
blvdbuzzard is online now
Find More Posts by blvdbuzzard
The high desert of Southern California
Joined Jul 2002
Looks good. I have the glass one and it fly's very well. Looking forward to your build.
Buzz.
blvdbuzzard is online now Find More Posts by blvdbuzzard
Old Feb 20, 2011, 08:53 PM
olmod is online now
olmod's Avatar
Joined Apr 2004
Recieved email that this has finally been posted, its been a long wait.
Old Feb 23, 2011, 10:27 PM
olmod is online now
olmod's Avatar
Joined Apr 2004
Good news ,it arrived and just going through the box,
parts do have a nice gloss finish no instructions which par for the course but who grizzles at this price.
Dead lucky with the damaged box it even went through the second box.
Old Feb 24, 2011, 01:50 AM
olmod is online now
olmod's Avatar
Joined Apr 2004
The folding prop was not included and it looks like a 40mm prop hub will be needed and the foam end shape is not a true circle.
Old Feb 24, 2011, 07:27 AM
olmod is online now
olmod's Avatar
Joined Apr 2004
I will do a weigh up of all parts in the morning to late now 11.30pm.
Old Feb 24, 2011, 11:57 AM
Joined Jul 2002
Looks good so far. What power setup are you going to run?
Buzz.
Old Feb 24, 2011, 05:10 PM
olmod is online now
olmod's Avatar
Joined Apr 2004
Buzz.
I will wait until all the weights are totalled ,this is a very slick bird and is not going to require much power.
as a comparison I have a windrider fox epp thats powered by a tripple 20 custom built motor @~ 200watts it climbs quite well near vertical.
Old Feb 24, 2011, 05:50 PM
olmod is online now
olmod's Avatar
Joined Apr 2004
Weigh in found one wing 4.5g heavier than the other .
total weight of parts 457g
taiplane area 41.25 sq inches.
wing area 336 sq inches
the moment arm is 17.5"
The cord average of the wing is 4"
The 6 servos @9g
and 1 servo @17g
= 61 g to be added plus decals .
total weight ~ 520g .. power system to be added.
This a very high aspect ratio ship and with such a small tailplane area My bones are telling me that the CG is going to be forward and sensitive.
Old Feb 25, 2011, 04:44 AM
olmod is online now
olmod's Avatar
Joined Apr 2004
I decided to try and keep everything light on the power side ,the pix will progress.
Old Feb 25, 2011, 06:31 AM
BJ64 is offline
Find More Posts by BJ64
The wheels touch down FIRST??
BJ64's Avatar
Australia, VIC, Melbourne
Joined Jun 2009
Can we post stuff on non-powered gliders here too, Les?
BJ
BJ64 is offline Find More Posts by BJ64
Old Feb 26, 2011, 12:35 AM
olmod is online now
olmod's Avatar
Joined Apr 2004
More pix and a couple of mysteries the battery tray on the left has an has a T shaped appendage Never seen anything like that before
The other is 2 small ~3/4" pieces of laser cut ply that can be assembled into what I thought maybe a pushrod hangar but where it belongs .
The turned allum piece is the wing joiner ,just got to make sure the grub screws are facing forward when gluing into the first half, i think I shall relace them to a slightly larger size as I dont have an extention for key sizes that darn small.
Old Feb 26, 2011, 09:03 PM
olmod is online now
olmod's Avatar
Joined Apr 2004
Mysteries solved ,the battery tray must be installed in the opposite orentation as in the pix, the T shape is to used to hold one end of a rubber band wich is then hooked on to the bottom of the canopy floor where the other mystery pieces are glued into forming a hook for the rubber band.
Old Feb 27, 2011, 06:32 AM
olmod is online now
olmod's Avatar
Joined Apr 2004
I did remove the deck on the undercarriage and turn it over this allows all the parts to be glued in to finnned half of the fuselage.
The rods that are being glued into the motor mount are some 3mm fibre glass I had on hand is a reinforcing of my own conception.
I am using the HK bluebird BMS-306BB servos which fit the cavities and I have had no problems with them in the past plus an MG9 for the wheel.
Old Feb 27, 2011, 11:36 PM
olmod is online now
olmod's Avatar
Joined Apr 2004
Joined the 2 halves together using Formular 560 canopy glue ,this product dries clear stcks well and while wet wipes up with a damp tissue and gives plenty of time to check alligment.
The wing control surfaces are decidedly stiff ,I made mine a bit freer by inserting a 1.5mm wire into the larger V groove and stressing the alleron/flap against the wire plus a lot of flexing ,a single pass with one of these http://www.hobbyking.com/hobbycity/s...dProduct=10124 along the hinge line also helped.
Discussion Hobby City's EPO 3d-Hawk Boxhead 3D Foamies 510 Dec 16, 2014 12:46 AM
Discussion ASW 28 EPO from Hobby City - thoughts? Angelo Electric Sailplanes 298 Jul 13, 2011 09:08 AM
Discussion 70mm composite L-39 from Hobby City unknown flyer Electric Ducted Fan Jet Talk 12 Dec 04, 2010 04:14 PM
Discussion Hobby King(city) Vs Hobby Partz mikeruth Vendor Talk 21 Nov 03, 2010 09:38 PM
Sold PRICE DROP - WOW! Hobby City F-14 Tomcat with 2 Dons Wicked 4000 NIB MinneFlyer Aircraft - Electric - Jets (FS/W) 9 Sep 06, 2010 11:38 PM
