Old Mar 18, 2012, 03:58 AM
wolfv is offline
Find More Posts by wolfv
wolfv's Avatar
Las Cruces, NM
Joined May 2007
Wiring Harness question
How is the RX turned on and off?
Would the plug on this Traxxas 3034 Wiring Harness fit the Fly Sky R6B receiver?:
http://www.ebay.com/itm/Traxxas-3034...ht_2410wt_1052
wolfv is offline Find More Posts by wolfv
Old Mar 20, 2012, 03:30 PM
NitroTechnician is offline
Find More Posts by NitroTechnician
Joined Jul 2011
Hello,
The receiver turns on once a power source is connected to it or the ESC. It looks like the wires should fit, but from that picture, I can not say it does for sure.
Thank you,
Danny V.
NitroTechnician is offline Find More Posts by NitroTechnician
Old Mar 25, 2012, 11:11 AM
wolfv is offline
wolfv's Avatar
Las Cruces, NM
Joined May 2007
Originally Posted by Bob A View Post
I purchased a Thunder AC6 charger and FlySky CT6B Tx from HP and have been well satisfied with both. However, I am using Nimh batteries in the Tx and would like to recharge them without having to remove them from the Tx.
What can I get to do that? (either using the charger I have or finding a wall wart of some kind somewhere)
Bob
Bob,
I just saw this "Univ Rx Charge Cord" on line, have not tried it. It does not specify plug size:
http://www.hangtimes.com/chargers.html > scroll down to "Univ Rx Charge Cord; Banana Plugs"
The CT6B takes a Size N Coaxial DC Power Plug Tip size: 5.5mm O.D.x2.5mm I.D., available at RadioShack http://www.radioshack.com/product/in...lickid=prod_cs
Radical RC has the complete banana ended charge cord with above plug size $4
http://www.radicalrc.com/category/Ch...Transmitter-75 > SKU Number: CGCDTXFJ96
Old Mar 25, 2012, 01:47 PM
wolfv is offline
wolfv's Avatar
Las Cruces, NM
Joined May 2007
Thanks NitroTechnician. The plugs fit with modification. There was a small tab along the side of the plug. After cutting off the tab, the plug fit into the Rx.
Old Nov 17, 2012, 03:21 AM
tundra9er is offline
Find More Posts by tundra9er
Joined Nov 2012
help
Can I bind this tx to a Park Zone Bind-N-Fly?
tundra9er is offline Find More Posts by tundra9er
Old Dec 02, 2012, 04:17 PM
IwillFlySoon is offline
Find More Posts by IwillFlySoon
United States, MI, Grand Rapids
Joined Jan 2012
No you can't. Those are for spektrum radios.
Iwfs
IwillFlySoon is offline Find More Posts by IwillFlySoon
Old Aug 06, 2013, 06:46 AM
RC Aerobat is offline
Find More Posts by RC Aerobat
RC Aerobat's Avatar
Australia, SA, Adelaide
Joined Jul 2013
What voltage and current power supply should I use to connect to the CT6B charging port?
RC Aerobat is offline Find More Posts by RC Aerobat
Old Dec 01, 2013, 09:15 AM
mjo78 is offline
Find More Posts by mjo78
United States, FL, Tampa
Joined Feb 2013
After binding to receiver, cannot get channel one to due anything,,,,tried plugging into channel 5 or 6 and still get nothing!!! Please tell me how to change receiver????
mjo78 is offline Find More Posts by mjo78
Old Jan 25, 2014, 02:16 AM
jubayer is offline
Find More Posts by jubayer
Joined Jul 2012
my new flysky fs-ct6b rx h 404784 and tx is h1 6373119.buind but after 100 mitter range problem. help me please..
jubayer is offline Find More Posts by jubayer
Old Jul 10, 2014, 05:03 AM
Graham1403 is offline
Find More Posts by Graham1403
Graham1403's Avatar
Joined Jul 2014
Rubbis set
What a performance!
I bought one of these, and it came with no instructions and I had to find them(the official manual) online. When I did, I followed the instructions for binding the receiver to the transmitter and though I tried several times, it just wouldn't work.
So I looked on Youtube and found this :
How to Bind a CT6B Rx FlySky (3 min 28 sec)
The instructions in the official manual, and those quoted in this thread, are incomplete!
They should be as follows:
1. Install batteries in the transmitter.
2. Plug link lead into batt. socket of receiver.
3. Plug battery into any other socket. NOTE: negative (black) lead towards nearest outside edge of receiver - i.e. right side if holding receiver with label right way up. LED will flash.
4. Hold down the "bind" button of the transmitter and THEN switch the transmitter on. (This wasn't mentioned in the manual)
5. When LED on receiver does not flash any more, the binding is complete.
I'm still having problems, though.
Flipping the dual rate switch on the throttle (Sw B on top left of unit) actually sends the throttle immediately to the full off position, and the throttle lever no longer works. Push the throttle fully forward and turn "on" Sw B, and I get a 110 degree throw from full forward to full back with no in-between control. With the switch "off" I get about 85 degrees controllable throw on the throttle stick. If you get what I mean.
Anybody got any ideas about this?
As I'm actually using this in a boat, with the throttle operating the sail servo and the steering operating the rudder, this might not be a problem, but it's a bit annoying.
Graham1403 is offline Find More Posts by Graham1403
Old Sep 08, 2014, 02:39 PM
Willem Nagel is offline
Find More Posts by Willem Nagel
Joined Sep 2014
Hi guy's could any one help me out. I bought a fly sky FS-T4B Transmitter that came with a receiver ( fly sky model FS-R6B ). I found that they arent bonded. So i tried to bind them. The way you posted o here. All what happens the red light keeps flashing on the receiver and doesnt look like it bonded with the transmitter. Can you pleas assist me whats the cause that its not binding.
Willem Nagel is offline Find More Posts by Willem Nagel
Old Sep 10, 2014, 11:51 AM
RaidenCharlie is offline
Find More Posts by RaidenCharlie
HobbypartZ Support
Joined Jul 2011
We don't carry the FlySky FS-T4B but going by the pictures that I can find of the unit it looks like it's just a 4CH version of the CT6B. I assume the binding procedure should be exactly the same as the CT6B.
RaidenCharlie is offline Find More Posts by RaidenCharlie
Old Feb 04, 2015, 06:27 PM
Flagstaff Flyer is offline
Find More Posts by Flagstaff Flyer
Joined Feb 2015
T6B and Quadcopters with GPS
Has anyone set this TX / RX combo up on an APM quadcopter? I'm planning on doing so, and will only be using stability, loiter and RTL modes in from the APM is this possible to do on this TX?
Flagstaff Flyer is offline Find More Posts by Flagstaff Flyer
Old Jul 15, 2016, 03:40 PM
tomaka0 is offline
Find More Posts by tomaka0
Joined Apr 2016
Fly sky ct-6b
My servos will not reverse why is that
tomaka0 is offline Find More Posts by tomaka0
Sold Fly Sky Tx/Rx (FS-CT6B) w/6-channel Rcvr kaging Aircraft - General - Radio Equipment (FS/W) 1 Feb 17, 2012 11:08 PM
For Sale Fly Sky Tx/Rx (FS-CT6B) kaging Aircraft - General - Radio Equipment (FS/W) 1 Feb 19, 2011 08:47 AM
Sold New Hobby King 2.4g 6 channel transmitter and receiver 50 dollars shipped. blueindian Aircraft - General - Radio Equipment (FS/W) 0 May 13, 2010 12:31 AM
Wanted R617FS 7-Channel 2.4g Receiver or R6106HFC 6-Channel 2.4g Receiver Mikey 68 Aircraft - General - Radio Equipment (FS/W) 1 Jan 15, 2010 04:40 PM
