Old May 03, 2012, 03:48 PM
mikmerl is offline
Find More Posts by mikmerl
mikmerl's Avatar
Athens, Greece
Joined Apr 2010
I finally found some empty space on my work bench and started the tedious task of removing the old covering film. Most of it had become very attached to the balsa and really challenged my patience.
Heat worked to some degree, clear packaging tape helped a lot (you apply it to the old film and then pull it up wards). It removes quite a bit of the old residue from the airframe.
At the end of the day sandpaper and a lot of elbow grease bring the final result. I repaired some cracks in the airframe wood and removed the old servo mounting wood blocks as I will be using new generation micro servos.
Now I am treating the oil soaked wood around the firewall with talc
um powder to the degree that it helps.
Keep in mind the little bird is more than 30 years old.
mike
mikmerl is offline Find More Posts by mikmerl
Old May 04, 2012, 10:44 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
How much does it weigh in that condition , please?
Mine (from '75) is in the closet :-) Awaiting an eventual wee outrunner repowering.
Baking soda has worked for me in the past as oil remover.. takes time though.. days even ?
Bare is offline Find More Posts by Bare
Old May 05, 2012, 07:28 AM
mikmerl is offline
mikmerl's Avatar
Athens, Greece
Joined Apr 2010
Bare the weight in its current condition, no hardware except for the wheels and of course no covering is 208grams.
Let me know which wee outrunner you decide on as I am leaning heavily in the direction of converting mine to electric as well.
Thanks for the baking soda tip; I just gave the whole firewall area a liberal coating.
mike
Old May 06, 2012, 03:16 PM
Bare is offline
Canada
Joined Nov 2000
Best motor IMO suitable is the Hobby King 24 gram blue wonder /turnigy 2730 in 1700 kv ! wind.
Light and powerful these are V good motors by any yardstick, the fact that they are Cheap is just a Bonus :-).
Use Rhino 610 2s (35gms) Or Rhino750 3s (56g) to go Fast.
8x4 for mild perf, 7x6 for racer like.
Have fun.
Old May 07, 2012, 02:12 AM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
DONT GO ELECTRIC!
Part of the fun of 1/2a is running annoyingly loud hilariously small motors. If you take that away you'll all but take the soul out the Q-Tee.
If you want an electric one, do so, but start afresh, and lighten the heck out of it. I can almost guarantee that you'll chortle greatly when flying the glow one, and be a little indifferent to the lek-trick.
Curare is offline Find More Posts by Curare
Old May 07, 2012, 01:17 PM
MrGoodwreck is offline
Find More Posts by MrGoodwreck
Model Hijacker
MrGoodwreck's Avatar
United States, WA, Monroe
Joined Mar 2011
last year,this thread, along with eliworms posts have gotten my 9 year old daugter interested in building one. I guess I better get on the ball She wants hers to be electric, and I will be putting a Norvel in mine
Thanks for bringing this back to my attention
MrGoodwreck is offline Find More Posts by MrGoodwreck
Old May 07, 2012, 04:13 PM
barry wilson is offline
Find More Posts by barry wilson
amherst,nova scotia,canada
Joined Nov 2003
Since my last one many years ago. With the vastly reduced weight of radio gear today it should fly much better. Still have an original kit and plans.
Actually a modern electric version might overall be lighter than my original and far more powerful.
barry wilson is offline Find More Posts by barry wilson
Old May 07, 2012, 04:59 PM
Bare is offline
Canada
Joined Nov 2000
I found even using the ancient S400 and Gasp! nicads that it was still a little bit lighter than My QT's first incarnation, which was with a black widow.
This due to the nicad receiver pack, plus largish servos and Rx. S400 was a heavy lump.
I did enjoy the s400 powered one far more than the black widow version.
Quiet, instant on and perfect throttling was a whole new world then.. Not to mention the more than 3x 'run time'.
Nostaligia is great.. but when something simply works better..it's tough to quickly dismiss it.
A few? years back the IMO horrid little man of SR batteries infamy kitted a Cutie (blatant copy)
For use with a geared (2.3:1) s400 and 10 cells of nicads. Despite it being seriously heavy it was a fairly popular model as the electrics gave it more perf/use than the Glo versions ever did.
Moderne BL electrics and Lipos gives huge potentials for very little weight... a major improvement over fitting 10! nicad cells.
Old May 07, 2012, 05:12 PM
Model Hijacker
Joined Mar 2011
I have decided to go "Old School"...
I still have a like new in the box 2 ch Cox/Sanwa radio and Cox Black Widow.
Old May 07, 2012, 05:17 PM
Bare is offline
Canada
Joined Nov 2000
Hey! why not :-)
Do try and fit some sort of 'extra' fuel tank tho, the Too Short engine run is a genuine nuisance imo.
Old May 07, 2012, 05:31 PM
ripplewave is offline
Find More Posts by ripplewave
United States, TX, Kerrville
Joined Dec 2007
Here is a tiled and cleaner version of the plans.
ripplewave is offline Find More Posts by ripplewave
Old May 07, 2012, 09:24 PM
Bare is offline
Canada
Joined Nov 2000
Great! I have 2 PDF's and an original Airtronics Paper plan on hand..
clearly I uploaded the wrong one.
Although I don't believe it's 'better' ..
Clearer/easier to read it certainly is.. better it is Not.
As example the silly "improvement ' of showing the Wing incidence angle as 1 degree when the original shows 1/16" as the spacer.
Old May 07, 2012, 11:52 PM
Curare is offline
KE your cub.
Curare's Avatar
Joined Jun 2005
Originally Posted by Bare View Post
Hey! why not :-)
I find that a texaco tank is usually just enough to get bored. of course you could go for a sure start and a film cannister tank,
Old May 08, 2012, 11:21 AM
Bare is offline
Canada
Joined Nov 2000
Texaco tank? Only had the BW tank... No Texaco big prop small venturi.. that was a later decade's phase/variation. Mine had a 2 mins tank run.. on a good day.
Sullivan slant tank rubber banded to the turtle deck and connected to the BW's tank tube Doubled the run time, at least.
Genuinely Ugly and clunky, but it worked.. opening up possibilities of other than 'climb to altitude then coast down' flight profiles.
Agreed, the Q Tee experience, it's basically Boooring. (mark of a good basic trainer ??). once flown a couple/few times my interest dissolves.
Ergo mine's decades long storage, with sporadic and brief revival intervals.
Too good to throw out, (memories/nostalgia we are all at their mercy :-) but it always get re-shelved.
Old May 08, 2012, 12:29 PM
hogflyer is offline
Find More Posts by hogflyer
Master of the Figure "9"
hogflyer's Avatar
Wichita, Kansas
Joined Dec 2005
Boring depending on how you set it up or want to fly it.
I've flown my Q-Tee with the controls cranked up and it's very aerobatic and will do as close to axial rolls as is possible from a 2-channel R/E model. I've also enjoyed many flights over 1 hour catching thermals (battery concerns were the limiting factor). With today's computer radio's, it's easy to set it up to be a very sedate trainer and do very respectable aerobatics.
After reading through this thread again, it's made me get my old S-Tee back out and get it ready to fly. This plane has a replacement fuselage, but the rest is original (except the wheels and radio) going back to 1980 except for the mid 1990's vintage Black Widow that has only a few runs on it. I actually had to add almost 3 ounces of lead behind the firewall to balance it, and it weighs in at a very portly 21.4 ounces. But with all that wing, it still should be a good flyer. Just waiting for a chance to get out to the field to fly it.
Hogflyer
hogflyer is offline Find More Posts by hogflyer
For Sale S-Tee Airtronics 1/2A Unopened Kit dphe0430 Aircraft - Fuel - Airplanes (FS/W) 2 Nov 15, 2010 01:10 AM
Discussion Lee Renaud Slingsby Cadet Tutor Beta mmartin55 Scale Sailplanes 3 Apr 11, 2006 04:09 PM
Lee Renaud Slingsby Tutor plans and short kits mmartin55 Scale Sailplanes 9 Jan 31, 2006 07:56 PM
Grand Espree by Lee Renaud CHARLIE BRITT 7 Aircraft - Sailplanes (FS/W) 8 Jan 04, 2004 09:06 PM
