This thread is privately moderated by gardleopard, who may elect to delete unwanted replies.
Old Feb 10, 2011, 02:40 PM
gardleopard is offline
Find More Posts by gardleopard
Asker, Norway
Joined Jan 2010
Simple delta
Today my brand new simple delta had her maiden in the moonlight with her lights on. It was kinda hard to trim her because she wanted to dive and it felt more complicated to trim in the dark. After I got her trimmed out she flew beautiful, loops, inverted loops and fast rolls. When the battery started to feel weaker I took her inn for a high alpha or what its called landing. I stopped the motor when she was about 20 cm above ground and let the nose fall into the snow. I got some snow in to the receiver or esc in the front, so I couldn't fly more than that battery. She is now standing in the hall, drying up
My setup
Motor: Turnigy C2230 1780KV
ESC: 10A brushless
Servos: HXT500
prop: EP70x35
I've got 20 leds on my SD for night flying. I can switch them on and off with the TX gear channel. They are driven from the RX by a modified servo circuit.
Night flying 5.4.2011 (hatcam)
Simple Delta night flight (Hatcam) (9 min 23 sec)
Ground test before flight.
Simple delta ready to fly (1 min 27 sec)
gardleopard is offline Find More Posts by gardleopard
Old Feb 12, 2011, 03:14 PM
Asker, Norway
Joined Jan 2010
Pulled the motor and mount off today. Gave full throttle with 3s and 7x6 apc prop. The motor just flew off! The glue is curing right now. I guess -12C is to cold for my foamies.
Old Mar 15, 2011, 01:09 PM
UAVPilot is offline
Find More Posts by UAVPilot
Foam Floats Better
UAVPilot's Avatar
The Big Country of TX.
How did you modify the servo circuit to turn the LED on and off?
Do you have link to doing it or did you figure it out yourself?
UAVPilot is offline Find More Posts by UAVPilot
Old Mar 15, 2011, 02:24 PM
Asker, Norway
Joined Jan 2010
I have a link that explains how to do it http://www.helifreak.com/showthread.php?t=271481
One thing that I've done on some of mine that differs from that guide is that I've used the potentiometer that is in the servo in stead of using resistors.
Quick and simple way to do it:
1. take the servo apart
2. replace the motor with a LED
3. connect the circuit to the rx
4. turn the tx and rx on
5. set the switch you want to light the LED to on
6. is it on?
----a. yes, try switching it off. Should be working now
----b. no, try all positions on the potentiometer
----c. tried all potentiometer position and still not working. Shut everything down, turn the led around and goto step 3.
Hope it all makes sense
Old Mar 17, 2011, 12:05 PM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
Thank you very much.
Yes, it all makes sense.
Again I do appreciate it.
Regards
Ernest
Discussion Simple Delta... a quick build "prop on the front" delta dekan Foamies (Scratchbuilt) 3000 Mar 20, 2016 07:04 AM
Discussion Simple Delta EDF JDExsquid Foamy EDFs 0 Jul 24, 2007 10:20 PM
Discussion Simple flat plate Delta dekan Foamies (Scratchbuilt) 13 Apr 29, 2007 06:28 AM
Idea Ultra Simple 6mm Delta superdave42 Foamies (Kits) 14 May 11, 2006 02:56 PM
MY Simple EDF Delta acr007 Electric Ducted Fan Jet Talk 10 May 23, 2005 06:30 AM
