Old Feb 10, 2011, 01:51 AM
GRVW is offline
Find More Posts by GRVW
Australia, ACT, Canberra
Joined Aug 2006
Question
Yellow Aircraft F-4 manual copy?
Folks - can you help me out here? I'm after the Yellow Aircraft instruction manual for their F-4. I've just bought a third-hand kit and the manual has long gone. I gather there could be two versions of the manual - one with pictures, one without, but either would be good. If someone's got them electronically that'd be excellent.
Here's hoping someone can sort this out for me.
GRVW
GRVW is offline Find More Posts by GRVW
Old Feb 10, 2011, 08:13 AM
jmalone1982 is offline
Find More Posts by jmalone1982
jmalone1982's Avatar
Alexandria ,Louisiana
Joined Sep 2009
Here is all i got.
jmalone1982 is offline Find More Posts by jmalone1982
Old Feb 10, 2011, 02:16 PM
GRVW is offline
Joined Aug 2006
Thanks very much jmalone1982. That will help to get me going.
Now, for the text bit.....anyone?
Old Feb 14, 2011, 06:43 PM
goforit is offline
Find More Posts by goforit
United States, WI, De Pere
Joined Aug 2010
Hi,
I am middle of Y/A F-4 build. I have a manual but it is for the older style kit. If this will help you out I can make a copy and get it out to you. Let me know.
Dennis
goforit is offline Find More Posts by goforit
Old Feb 14, 2011, 08:08 PM
GRVW is offline
Joined Aug 2006
Thanks Dennis
I'm not sure if mine is the newer or older style kit, but if you could copy your manual I'd be hugely grateful. Anything to go on would be good.
How's your build going? I want to put a turbine in mine, but I'm a bit concerned about the high wing loading, having read some reports.
Cheers
Gowrie
Old Feb 14, 2011, 09:00 PM
goforit is offline
Joined Aug 2010
Manual for F-4
My kit is the older style. Top hatch has to be cut out. I spoke with Shaun Evans regarding Turbine conversion and he stated they file just fine with P-60
He also recommended if you go turbine order the heavy duty controll arms for the elevators.
I am installing the XPS fan in mine. I have to install intake ducts and mount canopy and I will be ready for primer and glassing wings. I will make a copy of the manual and get it out to you .
Good luck on your build.
Dennis
Old Feb 16, 2011, 04:14 AM
GRVW is offline
Joined Aug 2006
Dennis , I just browsed up the XPS site. Those fans are fierce! What will you be running? 10S?
Old Feb 16, 2011, 06:44 PM
goforit is offline
Joined Aug 2010
I plan on flying with a 11s set up, I like the extra power for take off.
Thanks for your interest
Dennis
Old Feb 21, 2011, 01:05 AM
GRVW is offline
Joined Aug 2006
I found a copy of the written part now. All that's left is the actual build, which I gotta say doesn't look like a particularly easy one.
Dennis, what have you used for undercarriage/wheels/struts etc?
Old Feb 21, 2011, 08:33 PM
goforit is offline
Joined Aug 2010
I ordered spring air retracts. I still researching struts and wheels. I want to have brakes. Possible BVM or Robart struts,wheels and brakes.
The build is not bad. Plans look like a lot of work but the build goes okay. I can try to answer your questions if you run into any problems.
Good Luck
Dennis
Old Feb 21, 2011, 09:46 PM
CRCJA is offline
Find More Posts by CRCJA
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Great Timing
WOW great timing guys, can one of you trace the main formers for me? I have the ARF version (I think) and want to redo it. Step 109 in the manual, The main formers appeared to be drilled wrong for the wing brackets.
http://www.rcgroups.com/forums/showthread.php?t=1384185
Ralph
CRCJA is offline Find More Posts by CRCJA
Old Feb 23, 2011, 03:24 PM
GRVW is offline
Joined Aug 2006
Hi Ralph
Hope this helps.
This is the page taken from an old Yellow F4 manual showing the shapes of the formers. I scanned the page at at 1:1, but you'll see you need to scale the shapes up, as directed.
Cheers
Gowrie
For Sale New Yellow Aircraft F-16C latest version **LOWER PRICE** samdimaio Aircraft - Electric - Jets (FS/W) 6 Feb 23, 2013 07:32 AM
Sold Yellow Aircraft F-15 ARF Hammbone Aircraft - Fuel - Jets (FS/W) 0 Sep 29, 2010 08:17 AM
Wanted Yellow aircraft F-16C Rudder/vertical stab wanted, new or used tenacious101010 Aircraft - Fuel - Jets (FS/W) 0 Sep 22, 2010 04:00 PM
Found Yellow A-4 manual needed remote pilot Aircraft - Fuel - Jets (FS/W) 3 Sep 12, 2010 08:43 PM
Help! Yellow Aircraft f-16 manual needed raypadro Electric Ducted Fan Jet Talk 2 Mar 12, 2010 07:05 PM
