Old Feb 10, 2011, 12:00 AM
FuzzyWuzzyBear is offline
Find More Posts by FuzzyWuzzyBear
Joined Feb 2011
Help!
Venom GPV-1 Front Sprocket Stuck
While replacing the 11t front sprocket that came with my bike to a 12t that was also included, I got as far as removing VEN-0265, the little screw that secures the sprocket on the driveshaft. However, the front sprocket is still stuck on there real good. It can wiggle maybe a couple degrees and moves forward and backward about a millimeter but won't budge off the driveshaft. I've tried WD-40, levering, all sorts of stuff. Any ideas?
FuzzyWuzzyBear is offline Find More Posts by FuzzyWuzzyBear
Old Feb 10, 2011, 12:42 AM
621clay is offline
Find More Posts by 621clay
621clay's Avatar
United States, TX, Houston
Joined Dec 2009
Get a deep-well socket thats just big enough to be the same diameter of the collar on the sproket and place it with the shaft on the open end of the socket. Then tap it out lightly. If you have a small vise use it also. if all else fails, use a lighter and heat up the sprocket being its brass it should heat up quickly and tap out smoothly. Just dont bend the shaft.
621clay is offline Find More Posts by 621clay
Old Feb 10, 2011, 01:23 AM
Joined Feb 2011
Unfortunately, I cannot remove the driveshaft from the bike completely to try your method. On the other end of the shaft, where the spur gear is, the metal bearing inside the chain tensioner will also not come past its respective flatspot on the driveshaft, making the whole assembly stuck inside the body.
Edit: Just got that bearing free with WD-40. Now for the sprocket...
Old Feb 10, 2011, 07:35 AM
mark675 is offline
Find More Posts by mark675
scale microlights
mark675's Avatar
midlands uk
Joined Sep 2004
I had this on a nouva faor, where the grubscrew tightens down on the flat on the layshaft it chews it up and kicks up abit of a burr, it takes abit of force to get the sprocket off!
the bigger diameter nf layshaft can take abit of force though.. not too sure about the little 1/8th scale ones
mark675 is offline Find More Posts by mark675
Old Feb 10, 2011, 10:05 AM
621clay is offline
621clay's Avatar
Joined Dec 2009
if you plan on getting the up grade stuff just cut or melt the tensioner housing i suppose.
Old Feb 10, 2011, 02:28 PM
Joined Feb 2011
Just to update, I finally got the damn thing off the driveshaft and got the new sprocket on there. All in all, with all the delays and stuck bits, the job took me over three hours! I can change the front sprocket on my KTM motard in about 1/3 the time!
For Sale VENOM GPV-1 Reddy ! Fast venom bike ! Appel82 Cars - Motorcycles (FS/W) 2 Nov 05, 2010 03:58 PM
Discussion Venom GPV 1 Crash Back Gecko Hunter Motorcycles 13 Oct 26, 2010 08:39 AM
Sold Brushless Venom GPV-1 $100 Shipped! jaysoni Cars - Motorcycles (FS/W) 6 Oct 12, 2010 01:05 PM
Discussion Venom GPV-1 n00b Mooklar Motorcycles 14 Sep 20, 2010 01:51 AM
Sold SOLD-Venom GPV-1 Motorcycle with front brakes and LIPO battery tittelba Cars - Motorcycles (FS/W) 1 May 27, 2009 12:24 PM
