Old Feb 09, 2011, 08:46 PM
bob.titus is offline
Find More Posts by bob.titus
Flying at Sochi 2014 Olympics
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
Alternative MK Flight Control FC v1.33 - v2.0 MK THREAD-PART2
__________________________________________________ __________________________________________________ _______________________________________
since "Alternative MK Flight Control FC v1.33 - v2.0 MK THREAD" has been closed by Quad Addict, here is "Part 2" to follow up...
Part 1 is here : http://www.rcgroups.com/forums/showthread.php?t=1300414
Important notice :
you are buying and using a clone MK at your own risk, and I'm not promoting nor selling anything here and cannot be held responsible for your choice.
I simply opened this thread to continue what was started and closed by Quad Addict and because I know many people rely on this, including those using the real Mc Coy
I don't believe the clone is detrimental to Mikrokopter.de but on the contrary contributes to it's development.
Those who buy this cheaper copy wouldn't buy the original one in the first place, and I know for a fact that most will naturally go to the original product after a short while (Quad Addict did and so did I as an example).
Now back to the thread :
G and Dan, do you know how to flash the Ublox with v4 firmware, I couldn't find how?
Cheers,
Bob
bob.titus is offline Find More Posts by bob.titus
Old Feb 09, 2011, 09:01 PM
G-unit is offline
Find More Posts by G-unit
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
AZ
Joined May 2006
Cool, i will send info..
G-unit is offline Find More Posts by G-unit
Old Feb 09, 2011, 11:27 PM
hexa is offline
Find More Posts by hexa
hexa's Avatar
United Kingdom, Scotland, Edinburgh
Joined Nov 2010
too bad the part 1 is closed there was tones of good info in there.
hexa is offline Find More Posts by hexa
Old Feb 10, 2011, 12:53 AM
dt8666 is offline
Find More Posts by dt8666
Joined Oct 2005
Cheers,
Bob
Hi Bob,
Not tried loading other firmware yet but should be a simple one.
For the config file loading as you can read from the Wiki (I know too much reading....), you have to do the followings:
- download the ucentre software from ublox site
- download the xx2008xx.txt file from the wiki site - under GPS
- run the ucentre and connect the GPS module with USB
- look for the selection of loading of config (i think is under tool as I dont have my hobby NB with me now) and load the file. try this as if you still have issue, I will forward you the full instruction (or maybe someone can also forward that to you since I did send that to someone else here)
- after finish the above (you should not see a pink screen if all goes as normal), click on view and look for Configuration, click the port and select UART1, 0+1 binary NEMEA, 57600. and click send at the bottom screen. then select configuration and click send once.
DONE! you should read the Sat info reading from MKtool after you reconnect all back as usual! If your GPS module is working.
Hope this helps.
dt8666 is offline Find More Posts by dt8666
Last edited by dt8666; Feb 10, 2011 at 06:33 AM. Reason: more focus on the discussion
Old Feb 10, 2011, 03:25 AM
hawaiitaco is offline
Find More Posts by hawaiitaco
hawaiitaco's Avatar
Joined Dec 2010
subbed.... sucks the other thread had to close....... anyways... did a real low hover with my i2c converter....looked like it worked...more mktools setting adjustment and probably do a maiden flight sometime soon.....looking good...
hawaiitaco is offline Find More Posts by hawaiitaco
Old Feb 10, 2011, 05:49 AM
MalaysianFlyer is offline
Find More Posts by MalaysianFlyer
Joined Apr 2007
Just to make sure we dont loose track of part 1
MalaysianFlyer is offline Find More Posts by MalaysianFlyer
Old Feb 10, 2011, 06:03 AM
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
good thinking, I've edited my first post.
Bob
Old Feb 10, 2011, 06:09 AM
milouze is offline
Find More Posts by milouze
Registerer Used
milouze's Avatar
Paris
Joined May 2010
subscribed too..
milouze is offline Find More Posts by milouze
Old Feb 10, 2011, 06:43 AM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
i havnt bought one yet still working out which motors are best for me so im glad theres a part 2 aswell
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Old Feb 10, 2011, 06:46 AM
Quad_Addict is offline
Find More Posts by Quad_Addict
United States, IL, Chicago
Joined Dec 2006
since "Alternative MK Flight Control FC v1.33 - v2.0 MK THREAD" was getting too big and has been closed, here is "Part 2" to follow up...
Cheers,
Bob
no shame eh bob? you wrote it was closed because it was getting to big? WRONG, YOUR one of the reasons it was closed, so kinda funny you make another thread with the same name eh? more and more people will learn about you, you want to live in my shadow, be my guest.
Quad_Addict is offline Find More Posts by Quad_Addict
dt8666 is offline
Joined Oct 2005
bob... here you go for the GPS picture
Old Feb 10, 2011, 07:52 AM
Chukmil is offline
Find More Posts by Chukmil
Chukmil's Avatar
United States, AL, Birmingham
Joined Mar 2005
Thats great, I will be interested in the settings adjustments you make
Chukmil is offline Find More Posts by Chukmil
Old Feb 10, 2011, 08:24 AM
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
funny enough I was just trying to be fair with you, but never mind.
And I'm one of the reasons?? Because I was trying to get my gps working and asked for help on "your" thread?
What's wrong with some of you guys on RCG?
Don't worry, people will learn all about me soon enough, with ot without your "help".
There are a few things in the pipeline I cannot discuss now but later
Anyway it's working now, thanks to G and Dan... and a bit of luck I guess.
By the way, somebody mentionned gps was supposed to be flashed with v4 firmware, mine is loaded with v5 and seems to be working fine.
Bob
Old Feb 10, 2011, 08:38 AM
bob.titus's Avatar
France, IDF, Paris
Joined May 2009
thanks Daniel,
this confirms I didn't screw up bridging 5v with first capacitor next to it
All is fine now, I believe battery was dead and something happened because of it.
I left the GPS connected to USB on the PC all night and all seems ok now.
I have replaced the faulty ME 2.2 with a genuine ME 2.1 and will test later today.
Bob
Old Feb 10, 2011, 11:07 AM
noppita is offline
Find More Posts by noppita
noppita's Avatar
Joined Jul 2009
ok part2, so i will do my first post with question
anyone has flash this green bl with 0.42 or other version before, i have red bl and know how to flash red bl with red mkusb , but when i tried green bl with red mkusb, i can not flash it, it give me something like can not reset
noppita is offline Find More Posts by noppita
Discussion Alternative MK Flight Control FC v1.33 - v2.0 MK THREAD Quad_Addict Multirotor Talk 4985 Aug 18, 2012 07:21 AM
Poll POLL... Should i CLOSE the Alternative MK Flight Control FC v1.33 - v2.0 MK THREAD??? Quad_Addict Multirotor Talk 33 Feb 09, 2011 07:43 PM
Help! MK FC 2.1 Help I've blown it up Murphy Rebel Multirotor Talk 4 Jan 22, 2011 04:26 AM
Build Log Building MK Okto FC 2.0 - Now with 111 pictures drhswe Multirotor Talk 18 Oct 20, 2010 01:53 PM
Discussion MK FC ME V2.1 no on off switch? jeffreymikl Multirotor Talk 3 Aug 19, 2010 12:33 PM
