Old Jul 01, 2001, 05:33 PM
Steven D is offline
Find More Posts by Steven D
This space for rent
Steven D's Avatar
Peachtree City, Ga USA
Joined Apr 2000
Pushing the limits on 1406 2y?
Aveox lists the 1406 2y w/3.7:1 as running up to 16 cells and 51 amps for 722 watts on their web site, anybody actually tried running one at these power levels?
I'm looking at a project running this motor on 14 cells and a 12-8. Using motocalc and the actual constants for my motor (a bit lower than spec.) I get 56.6 amps and 707 watts, 99.2 oz thrust. Full power should only be used for very short bursts, hover at around 90% - 43.5 amps and level flight at 50% - 7.4 amps, less if I can shed some weight.
Any real world experience with these motors at these power levels?
Steven
Steven D is offline Find More Posts by Steven D
Old Jul 01, 2001, 05:48 PM
twest is offline
Find More Posts by twest
100% electric since 1990
twest's Avatar
United States, MA, Ware
Joined Jul 2001
You will be fine. The motor is fine at 60 amps for short bursts, and yes, that is from hands-on knowledge.
This motor has been used in europe as a 10-cell F5B primer, using 10 zapped cells, a 3.7 gearbox, and a 15-15 prop. I have also heard of one guy using this motor on 20 cells (!) with the 13-7 cam prop. He was drawing over 100 amps. I doubt the motor lasted long, but it probably was fun.
twest is offline Find More Posts by twest
Old Jul 01, 2001, 05:53 PM
twest is offline
twest's Avatar
Joined Jul 2001
Oh, now I read your post again. You want to use this motor in a conventional plane with throttle. You will be pushing the thermal limit of this motor, depending on how much time you spend at high throttle settings. Provide plenty of cooling air for the motor and controller. Also, some people have had good luck using R/C car heatsinks (available from tower). These are made for ferrite motors, but aveox's are the same diameter. The heatsinks are aluminum and weigh an ounce or two. If you haven't bought the motor yet, you are better off buying a motor that is 2 ounces heavier rather than putting a heatsink on a smaller motor.
It might be worth a shot. Again, it all depends on how much time you spend at high throttle.
voltage limits on 6v 400 buckeyes1997 Power Systems 4 Jul 09, 2001 10:33 AM
Aveox 1406/2y or 3y ESC for Voyager BenTolbert Electric Heli Talk 8 May 18, 2001 12:54 AM
anyone ever push a 1406-2y to 1000 watts joe Electric Sailplanes 2 May 17, 2001 10:43 PM
F-16 Performance on 1010/2y? EricBjorn Electric Ducted Fan Jet Talk 15 Apr 30, 2001 03:36 PM
What Gearbox to Use on a 1010/2Y Joe Elston Electric Plane Talk 15 Apr 26, 2001 04:35 PM
