Old Feb 09, 2011, 04:43 PM
TurboFanElectric is offline
Find More Posts by TurboFanElectric
www.turbofanelectrics.com
TurboFanElectric's Avatar
Tampa, FL
Joined Apr 2002
Cool
Turbo Fan Electrics Boomerang Clone (Venture) Ramtec EDF VIDEO!!!
Hi everyone as some have already seen. Turbo Fan Electrics has finished the flight testing phase of the Venture, complete epoxy/composite construction 123mm EDF jet. No polyester resin used in this Beast. As you can see from the video below, even at 19.5lbs the Ramtec 123mm EDF system propels the jet very nicely. Below is the equipment used in the Venture jet; ENJOY!
- Venture 123mm jet
- 123mm Ramtec edf
- Scorpion 5035-650kv motor
- Servos: HS-225mg on ailerons/flaps, HS-125mg on rudders, HS-5245mg on
elevator, HS-85mg on nosewheel, and LS-02mg on the retract valve.
- Battery: LIPO Turgnigy 5000mah 12s 40c.. two 6s in series.
- ESC: Ice 160hv
http://shop.turbofanelectrics.com/pr...&categoryId=40
http://shop.turbofanelectrics.com/pr...&categoryId=38
best regards,
William (TurboFanELectrics.com)
Ramtec 123mm EDF in Vertigo Venture Jet available at WWW.TURBOFANELECTRICS.COM (3 min 5 sec)
TurboFanElectric is offline Find More Posts by TurboFanElectric
Data Ramtec edf w/ 123mm impeller scorpion 5035-650kv by TURBO FAN ELECTRICS test w/ video TurboFanElectric Electric Ducted Fan Jet Talk 355 Nov 24, 2014 11:32 AM
Discussion Turbo fan video Eddy Jet Turbines 3 Dec 03, 2010 11:40 AM
Discussion EJF vs. turbo fan electrics STANG KILLA SS Electric Ducted Fan Jet Talk 24 Mar 20, 2009 02:38 PM
Alert Memorial Day Sale at Turbo Fan Electrics TurboFanElectric Hot Online Deals 2 May 27, 2008 07:06 PM
Alert Turbo Fan Electrics Now Open TurboFanElectric Foamy EDFs 0 Mar 10, 2008 07:43 PM
