Old Feb 09, 2011, 12:32 PM
Curtis
suseuser's Avatar
Nampa, Idaho
Joined Apr 2010
How to determine maximum wing size?
I'm looking to build a larger wing for my "foam" Mini Super Cub.
http://www.amazon.com/Hobbyzone-HBZ4...uct/B001IF3XVY
The purpose is to improve it's glide properties. I would like to have a spare wing that I could put on when I'm in the mood to do a little slow flying and chase a few thermals.
Is there a formula to calculate a maximum wing size for a specific fuse size? Rib/Spar size and length?
Curtis
suseuser is offline Find More Posts by suseuser
Old Feb 09, 2011, 12:56 PM
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
You can typically make the wing about another 25% bigger and not run into issues. But that's it. The model's stability and other flight factors is affected by the wing and tail size and the distance between the wing and tail. If you alter these things by too much on a given design then the resulting model will either be a bear to fly or won't fly at all due to stability issues.
This is why power models look like they do and sailplanes look like they do and why you can't just mix and match stuff around willy nilly.
BMatthews is offline Find More Posts by BMatthews
Old Feb 09, 2011, 02:25 PM
Curtis
suseuser's Avatar
Nampa, Idaho
Joined Apr 2010
That makes total sense. I knew there had to be a maximum length and width that could be used without running into problems. I'm sure the standard wing size on the model is more a matter of keeping the model to scale as much as anything. And the original wing size for the full-size Super Cub was designed to give the best overall performance. I am just trying to push the wing towards maximum lift rather than maximum engine powered performance and forward speed. The stock Mini Super Cub is a real floater in stock form. I'm looking at designing a wing with a flat bottom.
Curtis
Old Feb 10, 2011, 12:55 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
At the size of the Mini Cub the best low speed option is the simple arc wing that it came with. I know that sounds odd but it's related to the airspeed and wing chord size. The term used to describe this size scaling effect is given as the Reynolds number that the wing operates at. For the sort of very low Reynolds number range of operation of this sort and size of model for the slowest flight speed the simple arc shape is actually the optimum shape.
If you want to make the model fly slower the trick would be to build a new model of around the same size but lighter. And the best low speed flying would come from using a fairly highly cambered airfoil such as those used on free flight P-30 or Coupe d'Hiver rubber powered models.
Old Feb 10, 2011, 04:00 PM
Curtis
suseuser's Avatar
Nampa, Idaho
Joined Apr 2010
It would be really hard to make a lighter airframe. The Mini Super Cub doesn't weight much. So, I think wing design is about my only option. I always thought a wing with a flat lower surface created the most lift.
Curtis
Old Feb 10, 2011, 10:09 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
All else being equal the one with the greater % of camber (the mid line between the upper and lower surfaces) will achieve a higher lift coefficient before stalling. This is why undercamberd airfoils are used for slow flying models in free flight.
Old Feb 11, 2011, 09:52 AM
Zor
Zor's Avatar
Ontario,Canada
Joined Feb 2007
BMatthews,
Please a few words on your expression "arc shape".
Zor
Zor is offline Find More Posts by Zor
Old Feb 11, 2011, 10:55 AM
Jim C Patrick
jcpatrick's Avatar
Shenandoah County
Zor asked about the term "arc shaped". Not speaking for BMatthews, but it is probably the rounded wingtips shown on Hobyzone's webpage for this Cub looks like what most people call 'an arc shape". It's not exactly an arc because it is not 'an exact arc' —a section of a perfect circle— but other Hobbyzone Cubs all have a rounded wingtip.
jcpatrick is offline Find More Posts by jcpatrick
Old Feb 11, 2011, 01:17 PM
South of Boston, Ma.
Joined Mar 2004
I don't think so. I think BMatthews was discussing airfoil cross section.
Skyshark is offline Find More Posts by Skyshark
Old Feb 11, 2011, 09:21 PM
Zor
Zor's Avatar
Ontario,Canada
Joined Feb 2007
Now we can see why I asked.
Zor
Old Feb 12, 2011, 11:33 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
It WAS the airfoil shape that I was referring to.
By "arc shaped" I mean that the airfoil resembles a sheet of balsa that has been curved across the grain into an arc. A popular example of such a wing section are the molded "meat try" foam wings of the GWS Lite Stik, Beaver, Cub and other GWS models that share that same wing style. Another example would be the single covering on a typical indoor rubber duration model that is supported in an arc shaped or at least single surface camber shape by the ribs of the wing. The Steven's Aero Doodlebug is another example of such a basic shape. It basically describes any "airfoil" that is formed from very thin sheet that is less than about 1% thick or uses a single sided covering where that covering is basically both the top and bottom surface shapes.
Discussion How to Determine the Wing Aspect Ratio and Aileron beetles Electric Motor Design and Construction 1 Oct 18, 2010 07:32 AM
How do I determine model/engine size? tolladay Scale Electric Planes 9 Sep 19, 2002 05:44 AM
How to determine maximum current draw of a particular cell ??? ARE Electric Plane Talk 1 Aug 15, 2002 02:52 PM
