Old Aug 22, 2011, 10:58 AM
P. Tritle is offline
Find More Posts by P. Tritle
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
The Maiden Voyage
The radio was checked out and found to be running properly. The sound system works great, but inside the cabin is pretty muffled. Unfortunately there's not much we can do about that without placing an UGLY speaker grill on the cabin...
Using a 430 mah 3S Lip for the sound system and a 2500 mah 2S Lipo for the motor power, she sits right on the water line due to the extreme weight -- over 22 oz. in the sound system alone. But in spite of that, the model ran GREAT!!! Much better then expected, and at 2/3 power plains off nicely for a very scale speed and appearance. It's dead stable, and turns beautifully at both idle and cruising speeds.
Unfortunately, at full throttle the water crawls up the sides and pours in over the rear deck, so the speed had to be limited to keep the water on the outside where it belongs.
Almost Done: Next up is to get the name on. I think too that I'm going to pull the prop shafts and hone them down a couple thousandths in the lathe as the left side runs just a skoash tight and is a bit noisy. From there, she's finished.
Overall, this has been a terrific project. The kit itself wasn't bad, though there were some fairly serious fit problems with the hull frames, and if I had it to do again I would eliminate every other frame since they were so close together, closer then need be since the hull was planked rather then sheeted. But in the end, was worth all the effort just to see this vintage kit come to life.
PAT
P. Tritle is offline Find More Posts by P. Tritle
Old Aug 22, 2011, 11:14 AM
Sharky1dk is offline
Find More Posts by Sharky1dk
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
Sweet it look's sooooooo good.
Sharky1dk is offline Find More Posts by Sharky1dk
Old Aug 22, 2011, 12:55 PM
Gravman is online now
Find More Posts by Gravman
United States, TX, La Porte
Joined Apr 2007
Man oh Man how cool is that!!. She looks great! See what a skilled craftsman can do! You took something old and made it a lot better. I like to see things from another time built and put to use today. Great Job.
Gravman is online now Find More Posts by Gravman
Old Aug 22, 2011, 04:33 PM
frankg is online now
Find More Posts by frankg
Joined Dec 2004
PAT- That Owens turned out great. As for the water crawling up the side of the hull, install a set of spray knockers a little above the water line starting at the bow and going back to the front of the cabin. This will not only stop the water and spray from coming up on the deck , but it also helps to lift the bow when cutting thru wakes.
frankg is online now Find More Posts by frankg
Old Aug 22, 2011, 08:20 PM
r/cjunkie is online now
Find More Posts by r/cjunkie
Central Florida
r/cjunkie's Avatar
United States, FL, Lakeland
Joined Aug 2008
On the outside looking in...... One thing you might do is put some curtains in the back side windows and possibly the large windows just to rear of side doors. You could cut the windows and move the front half back like the windows were open to get a breeze. It would let the sound out at the same time. But what a beautiful boat you have.
r/cjunkie is online now Find More Posts by r/cjunkie
Old Aug 22, 2011, 10:36 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Fantastic looking yacht, Pat! Great job! She looks great on the water!
Aerominded is offline Find More Posts by Aerominded
Old Aug 23, 2011, 05:49 AM
woodybob is online now
Find More Posts by woodybob
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Very nice...
woodybob is online now Find More Posts by woodybob
Old Aug 23, 2011, 07:24 PM
charlie eaton is offline
Find More Posts by charlie eaton
charlie eaton's Avatar
N.E.Mass.
Joined Apr 2007
Beautiful,Pat, just plain beautiful.
charlie eaton is offline Find More Posts by charlie eaton
Old Aug 24, 2011, 12:29 AM
jeepers1940 is offline
Find More Posts by jeepers1940
Madison, MS
It is really nice to see the potential beauty of these old, rather basic kits brought out by a fine craftsman, Pat. If only they were a bit larger, they would be a larger canvas for your artistry. Thanks for sharing her and the build process with us.
jeepers1940 is offline Find More Posts by jeepers1940
Old Sep 01, 2011, 11:10 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
The Last Finishing Touches
OK, got the windows removed from the rear of the cabin and and replaced with black screen, so the openings for the sound to escape are there, without being obnoctious about it. The change looks good and works great.
The last step was to add the name, and with that, the Owens is officially finished.
In the end, though the kit was a challenge to build, it turned into a good looking great running model. Meanwhile, I have another old Dumas kit stashed away in the shed, the Chris-Craft 35' Sport Fisherman, and as soon as I get a few other more pressing projects finished might just have to drag it out and see if it turns out as nice as this one did.
PAT
Old Sep 02, 2011, 05:43 AM
WooHoo!
woodybob's Avatar
Lake Balboa, CA
Joined Jun 2007
Nice ending. Love the name.
I'd have to go with something like "I Owe, I Owe, It's Off To Work I Go". Way too long for a transom.
Old Sep 02, 2011, 06:08 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Woody, "I think you're going to need a bigger boat".....
PAT
Old Sep 02, 2011, 10:21 AM
Joined Feb 2004
PAT
LOL!!!
Old Sep 02, 2011, 10:41 AM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Will it have a captain Pat with a cigar?
E-Challenged is online now Find More Posts by E-Challenged
Old Nov 11, 2011, 11:05 PM
Drunkskunk is offline
Find More Posts by Drunkskunk
Crash tester
Drunkskunk's Avatar
Texas
Joined Sep 2006
WOW!
Thats an amazing build!
I've been working on one of these kits for the last 7 years. I pull it out, work on it, realize I need more skill at something, and it gets put away again. I pulled it out last week and am still working on the ribbing.
It was my father's, and he bought it when it first came out, but never got around to it. when he retired, he left it for me to finish.
Thanks for posting this build thread, You've inspired me to keep at it.
Drunkskunk is offline Find More Posts by Drunkskunk
Wanted Dumas fittings set 0-60 for OWENS 42' FLAGSHIP pfezj Boats (FS/W) 3 Dec 23, 2010 07:36 PM
Discussion New products from Dumas AprilRose Dock Talk 31 Nov 03, 2010 10:14 PM
Discussion Dumas Spad XIII Kit 42" morback Scale Kit/Scratch Built 12 Jul 12, 2009 08:02 AM
Help! Owens Flagship Drunkskunk Dock Talk 13 Feb 14, 2007 07:40 PM
BBC news axed from UK Flagship vessel Tim Jonas Life, The Universe, and Politics 8 Apr 08, 2003 01:58 PM
