Old May 17, 2011, 11:20 AM
P. Tritle is offline
Find More Posts by P. Tritle
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Straight Waterlines
Jeepers, The key to getting a straight waterline is all in how the line is laid out. With all the odd curves and angles on a hull, it's virualy impossible to eyeball a straight line, so I made the tool here just for this purpose.
To lay it out, block the hull on the building board upside down so that the distance from the board to the waterline at the bow and stern are equal. Then set the pencil height to match and simply drag the base of the tool around the hull leaving the pencil mark on the surface. Then mask and paint and you're in business.
PAT
P. Tritle is offline Find More Posts by P. Tritle
Old May 17, 2011, 11:24 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Getting Started On the Cabin
Framing the cabin began with cutting out all the parts from the printed sheets, then gluing the upper and lower side sections together. The sides were pinned to the hull and the top formers fitted and glued in place. Much to my surprise, the parts fit quite well. Only minor trimming in width was required.
Old May 17, 2011, 11:26 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Adding the Aft Top
The cabin top is supposed to be done with 1/16 balsa sheeting, but I've been down that road before, and it never has worked out all that well. So, this time I went with 3/16 sheeting to get the required height in the curve and rough sanded it to shape.
Old May 17, 2011, 11:33 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Adding the Main Cabin Top
This time I went with 3/32 sheet in the middle and 3/16 on the sides. The formers were reshaped for the flat sections, then once glued in place were carved and roughtly shaped.
The forward section was laminated from a combination of kit parts and balsa sheet to fill the area forward of the forward most former. The blocks were carved to contour and then the roof was rough sanded to final shape.
I also replaced the vertical window framing with 1/8 X 1/4 balsa since as designed, the grain rain horizontally and was far to easy to break. Then the windshield framing was added to complete the basic assembly.
Next up will be to bend the curves into the aft rails to contour with the deck, and then extend the rear most former down to the lower deck level, then build up the rear deck details in the hull and make it all fit.
PAT
Old May 19, 2011, 07:56 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Roughing In the Rear Deck
Got the floor laid in and the side planking in yesterday. Then sealed up the cabin with 3 coats of dope. Will prime as soon as the crumby weather breaks and get moving forard on the finish. So far things have gone well on the top side, and the fit was much better then I had expected.
PAT
Old May 19, 2011, 10:45 AM
norgale is offline
Find More Posts by norgale
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
That's really looking good Pat. Nice boat to model too. I'll have to try the silkspan on a model now that I've read this thread. Pete
norgale is offline Find More Posts by norgale
Old May 20, 2011, 09:55 AM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Looking nice, Pat!
Aerominded is offline Find More Posts by Aerominded
Old May 21, 2011, 04:59 PM
LaBob is offline
Find More Posts by LaBob
Bob
Metairie, La. USA
Joined May 2010
PAT
My version of a waterline machine.. It is tall as I build many different scale and size models.... Note the holes under the wing nut to adjust the pencil in or out depending on the length of the pencil. I always cut off the eraser end to get a tight fit.. Only problem w/building this jig is one needs a router.
Bob
www.ChrisCraftModels.com
PS- love the model and your workmanship.
LaBob is offline Find More Posts by LaBob
Old May 21, 2011, 05:19 PM
Fodigo is offline
Find More Posts by Fodigo
Capt. Jack
USA, CA, Petaluma
Joined Oct 2010
This is how I do it
But you way seems more accurate
Fodigo is offline Find More Posts by Fodigo
Old Jul 05, 2011, 09:45 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Finishing the Cabin
Been busy working on the Owens, but not posting, so figured I'd best get the Thread back up to date.....
The cabin was sealed with Nitrate Dope, then a heavy coat of sandable primer applied. When dry, a coat of spot glazing putty was squeegeed onto the entire surface. The putty was sanded, then re-primed and the last of the flaws fixed individually. Once it was all done, the color coat was sprayed.
Old Jul 05, 2011, 09:55 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Planking the Rear Deck Walls
Mahogany planks were ripped to fit the rear deck walls and glued in place, then sealed with 3 coats of Spar Varnish.
Old Jul 05, 2011, 10:00 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Fitting the Motors and Shafts
The motor mount was built up from lite ply and balsa and the motors glued in place with silicone caulk. The mount was then aligned and glued into the hull. The prop shafts were made up and mounted in the hull and the couplings made up from Robart landing gear air hose and Tygon fuel tubing, secured with Zip-Ties. The wiring was soldered in place and is ready for the ESC to be connected.
Old Jul 05, 2011, 10:04 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Fitting the Windows
Each of the 16 cabin windows were fitted into the openings individually and labeled for their individual locations. Then the final boo-boo's were fixed and the catalized clear coat sprayed on the cabin to complete the assembly. After curing over the long weekend, it's now time to glue the windows in place.
Old Jul 05, 2011, 10:06 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
On the Home Stretch
At this point, the windows need to be glued in place, then the deck fittings can be added. From there it's down to hooking up the sound system and getting the ESC and radio set up, and then off to the pond for the test runs.
PAT
Old Jul 05, 2011, 10:09 AM
Gravman is offline
Find More Posts by Gravman
United States, TX, La Porte
Joined Apr 2007
Pat how much do you thin the dope when you apply the silkspan? Tower Hobbies list Dope but it does not say nitrate, where do you purchase your supply?
Gravman is offline Find More Posts by Gravman
Wanted Dumas fittings set 0-60 for OWENS 42' FLAGSHIP pfezj Boats (FS/W) 3 Dec 23, 2010 07:36 PM
Discussion New products from Dumas AprilRose Dock Talk 31 Nov 03, 2010 10:14 PM
Discussion Dumas Spad XIII Kit 42" morback Scale Kit/Scratch Built 12 Jul 12, 2009 08:02 AM
Help! Owens Flagship Drunkskunk Dock Talk 13 Feb 14, 2007 07:40 PM
BBC news axed from UK Flagship vessel Tim Jonas Life, The Universe, and Politics 8 Apr 08, 2003 01:58 PM
