Old Mar 29, 2011, 10:15 AM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
I totally agree, kits have come a long way over the years but with a little bit of work, these older kits produce nice boats.
Aerominded is offline Find More Posts by Aerominded
Old Mar 29, 2011, 09:12 PM
r/cjunkie is offline
Find More Posts by r/cjunkie
Central Florida
r/cjunkie's Avatar
United States, FL, Lakeland
Joined Aug 2008
nice
r/cjunkie is offline Find More Posts by r/cjunkie
Old Apr 12, 2011, 08:21 AM
P. Tritle is offline
Find More Posts by P. Tritle
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Fitting the Rudder Servo and Linkage
The rudder control horns were made up from wheel collars and ,032 brass straps. The pushrod was bent from brass wire with a brass tube coupler for the final fine adustement, then soulderd in place. And finallt, the servo was mounted and the link soldered to the pushrod.
Because the scale boat was not designed for R/C, the rear deck had to be fudged forward to hide the control set up. I really hate to deviate from scale, but simple always works, so what ir boils down to is functionality first, and fidelity to scale second. In the end though, it'll come out fine.
P. Tritle is offline Find More Posts by P. Tritle
Old Apr 12, 2011, 08:26 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Priming the Hull and Prepping for Paint
A heavy coat of filler primer was sprayed on the hull, then the imperfections were filled with spot glazing putty. The process was repeated until the flaws were all gone, then a final heavy coat of primer was sprayed. After letting it dry overnight, the next step will be to do a final wet sanding, then start adding the bumpers, plank the deck and then add the rub rails. But first, I think I'll build up the basic cabin assembly, just in case the opening needs to be adjusted. I'd hate to find out nothing fits, AFTER the planking was in place.
PAT
Old Apr 12, 2011, 08:54 PM
Joined Feb 2004
Looking good Pat!
Old Apr 19, 2011, 10:24 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Planing the Deck
The deck is planked with some .020 X 1/4" yellow hardwood strips left over from some of the old Latina kits built over the years. It started with the centerline plank, then the rest were added. Then once all the planks were in place, a bass wood bumper strip was added around the perimeter.
Old Apr 19, 2011, 10:27 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Adding the Rub Rails
Once the deck was done and the bumpers were in place, the rub rails were added in the scale location. These were shown on the plans, and were made up from 3/32 X 1/8 bass wood. It won't be long now till the hull gets a coat of paint.
PAT
Old Apr 19, 2011, 05:21 PM
bboarder711 is offline
Find More Posts by bboarder711
bboarder711's Avatar
State College, Valley Forge PA, LBI NJ
Joined Jun 2008
subscribed!
bboarder711 is offline Find More Posts by bboarder711
Old Apr 19, 2011, 11:46 PM
MILLERTIME is online now
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Me too.
MILLERTIME is online now Find More Posts by MILLERTIME
Old May 03, 2011, 11:12 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
Painting the Hull
With all the prep work done the base coat of white was sprayed, followed by the black bottom and gold boot line and then the final clear coast.
The deck has 3 coats of spar varnish applied now, and will be followed by 2 or 3 more. So now, it's time to get rolling on the cabin assembly....
PAT
Old May 03, 2011, 10:05 PM
Joined Feb 2004
Keep up the good work Pat! She's coming along nicely!
Old May 04, 2011, 08:43 AM
RGinCanada is offline
Find More Posts by RGinCanada
Tinkerer in Training
RGinCanada's Avatar
Guelph, ON
Joined Sep 2004
The deck hardwood is beautiful. What type of wood is it?
RGinCanada is offline Find More Posts by RGinCanada
Old May 05, 2011, 10:45 AM
P. Tritle's Avatar
Albuquerque NM
Joined Oct 2003
RG, I really don'y know what kind of wood it is on the decks. I have a bundle of it left over from past kit builds (Helen, St. Elm, and a couple of static sailing ships from Latina). It's about .025" thick and 1/4" wide. It's a loose grain and very brittle, but for relatively flat surfaces it works well and finishes nicely with spar varnish.
PAT
Old May 15, 2011, 10:38 PM
jeepers1940 is offline
Find More Posts by jeepers1940
Madison, MS
There's a lot to like in this build by Pat. I particularly like the dead straight waterline and boot top that he has incorporated on this model. I think they enhance the basic hull lines of this type of cabin cruiser, as opposed to the waterlines that curve upward as they approach the bow.
This is going to be a great rendition of a classic model from yesteryear, as done by the master himself. All one could hope for is that he had seen fit to expand the model by about 50% larger, but that would have defeated his purpose.
As he requests, I'll "stay tuned."
jeepers1940 is offline Find More Posts by jeepers1940
Old May 16, 2011, 09:42 AM
redlined_b16a is offline
Find More Posts by redlined_b16a
Joined Jun 2008
very beautiful work
redlined_b16a is offline Find More Posts by redlined_b16a
Wanted Dumas fittings set 0-60 for OWENS 42' FLAGSHIP pfezj Boats (FS/W) 3 Dec 23, 2010 07:36 PM
Discussion New products from Dumas AprilRose Dock Talk 31 Nov 03, 2010 10:14 PM
Discussion Dumas Spad XIII Kit 42" morback Scale Kit/Scratch Built 12 Jul 12, 2009 08:02 AM
Help! Owens Flagship Drunkskunk Dock Talk 13 Feb 14, 2007 07:40 PM
BBC news axed from UK Flagship vessel Tim Jonas Life, The Universe, and Politics 8 Apr 08, 2003 01:58 PM
