Old Nov 30, 2012, 11:58 AM
Mud Duck Bill is offline
Find More Posts by Mud Duck Bill
Mud Duck Bill's Avatar
Up State New York , USA
Joined Mar 2009
My flat carbon fiber came yesterday and I have it all installed, across the top and bottom and on the inside radius too! Gluing up the KF plates when dry will snap a few pictures. Decided to go with 4channel set up so I cut and hinged the outer alerons too. It is a bit too close to Christmas to self indulge but if I can swing it I will order up the motor and esc from Headsuprc they can get it to me in 3 days. In the meantime I can hook up control surfaces.
Pictures soon
Bill
Mud Duck Bill is offline Find More Posts by Mud Duck Bill
Old Nov 30, 2012, 03:45 PM
Joined Mar 2009
Ya know it just hit me about what you said about NOT cutting the elevator off for hinging if I was to go Delta set up. It's only a matter of glue in it back and if it didn't work just cut I back in ! Leaning back toward Delta AGAIN !
By the way the thickness of the nose is 1" with the tri thick pink FFF. Here in NY...
Bill
Old Nov 30, 2012, 03:52 PM
Joined Mar 2009
Front view .
Old Nov 30, 2012, 03:57 PM
pecanpatch is offline
Find More Posts by pecanpatch
Home of "Golf Cart Flying"
pecanpatch's Avatar
Griffin GA
Joined Aug 2008
Oh No!
You needed the biggest canopy!
the other ones are for smaller birds.
Sorry about that.......
Your looking good tho!
Seriously , your first foamie? I am honored
pecanpatch is offline Find More Posts by pecanpatch
Latest blog entry: 6th Annual South Eastern FPV...
Old Nov 30, 2012, 04:57 PM
Joined Mar 2009
Well I went back and found a 36-55 canopy at the very end of the canopy section obviously the better fit my mistake for not looking through the entire listings. I now have one coming my way!
Bill
Old Nov 30, 2012, 05:39 PM
electrich is online now
Find More Posts by electrich
65 Buick =make my own thermals
electrich's Avatar
United States, GA, Atlanta
Joined Feb 2011
You can always make a baby bat for your small canopy next. 3mm depron should work nice.
electrich is online now Find More Posts by electrich
Old Dec 01, 2012, 02:32 PM
Joined Mar 2009
All glued up waiting on the motor and ESC and servos , I suppose I can build the motor mount .
See anything that I should know ?
Bill
Old Dec 01, 2012, 02:46 PM
electrich's Avatar
Joined Feb 2011
If you are going to paint it, now is a good time.
Old Dec 01, 2012, 02:54 PM
pecanpatch's Avatar
Griffin GA
Joined Aug 2008
Bill
It looks great....
The "V" that goes aft where the motor mount goes......
I have been cutting that straight across and not having the rearward "V"
Then the motor and mount gets moved forward accordingly....
This helps with CG issues.
Old Dec 05, 2012, 08:59 AM
Joined Mar 2009
Well fellas I finished the Geobat yesterday and took it to the field for a maiden flight. Now I had a good flight and it flew rather well but it seemed to be tail heavy when I was over 1/4 throttle nose up and plowing through the air slowly climbing, if I backed off I had good level flight and glide slope was good. It was a little sluggish on turns but that is to expected I guess from what I have read here. balance seemed to be about 3/4 " in front of the carbon fiber crossbar in the nose. the thrust line of the motor is 90 degrees to the body has anyone added a little up thrust to that to maybe push the nose down a bit? Or is it a matter of adding weight to the nose?
So far so good still working on securing the canopy the Velcro is not working out leaning towards magnets now.
Pictures to follow!!
Bill
Old Dec 05, 2012, 09:03 AM
pecanpatch's Avatar
Griffin GA
Joined Aug 2008
Bill
I swear the KF's move tha CG forward.... and you have a double KF
So I would move the CG 1" forward and go again.
Also it helps if the motor is up a coupla inches high on the wing. This helps push the nose down.
I have not played with thrust angles
Old Dec 05, 2012, 11:51 AM
Joined Mar 2009
Reworked the canopy with magnets and I think it will hold much better. Checked the c/g @ about 1-1/4" I front of C/F rod crossing.
Old Dec 05, 2012, 11:53 AM
Joined Mar 2009
The finished product !!
Old Dec 05, 2012, 12:01 PM
Joined Mar 2009
Don't know if you can see it or not but I shimmed the bottom of the motor with washers to give it a little different thrust line ... Just playing around a bit will report back after another flight, weather sucks at the moment and getting colder each day too,not to mention I am still hobbling around on crutches.
Old Dec 05, 2012, 12:15 PM
pecanpatch's Avatar
Griffin GA
Joined Aug 2008
Outstanding for your first foamie.... Your gonna love it man. Trim it at half throttle... if it climbs at full throttle, thats to be expected.
The canopy looks great. Good Job all around sir.
Build Log B-17 Flying Foamie The Legacy Foamies (Scratchbuilt) 43 Feb 14, 2014 08:30 AM
Discussion Which two DW Foamie Models are the Best, and is their a night-flying kit interest? gabrielisrael 3D Foamies 7 Jan 15, 2011 10:49 AM
Video 5.25" geobat flying figure-8's in a 13'x15' living room iter Electric Plane Talk 0 Aug 18, 2006 11:10 PM
RC Vectron Flying Saucer Daniel11 Coaxial Helicopters 19 Jan 02, 2005 05:50 PM
