Old Nov 16, 2012, 06:26 PM
Joined Oct 2012
Iacei.... Could you talk me through exactly how you soldered the wires.... Not sure if i have shorted something but it would appear i have done something wrong! Advice appreciated!
Thecoltster is offline Find More Posts by Thecoltster
Old Nov 16, 2012, 11:02 PM
Johan Moelich
Moelich73's Avatar
South Africa, KZN, Durban
Joined Feb 2007
The way I did it was to remove the battery connector and then solder a JST plug to the + and Gnd where the battery terminal was. It works great and is easy to do. Details and photos here:
http://fpvlab.com/forums/showthread....l=1#post165827
Hope this helps.
Moelich73 is offline Find More Posts by Moelich73
Old Nov 17, 2012, 06:53 AM
Luxembourg
Joined May 2009
this did not work for me but you can try
iacei is offline Find More Posts by iacei
Old Nov 17, 2012, 07:34 AM
Luxembourg
Joined May 2009
Well I do not know what to tell you more then soldering where you saw the red and the black arrow on my pictures....
Old Nov 17, 2012, 11:51 AM
Johan Moelich
Moelich73's Avatar
Joined Feb 2007
It's working fine for me with the battery connected to the original battery terminals. Maybe I have a different model TK102 than you?
Old Nov 19, 2012, 09:11 PM
Joined Oct 2012
Thanks.... Looks slightly different to mine, my light was blue... Where did youmsource yours from?
Old Nov 19, 2012, 09:57 PM
Johan Moelich
Moelich73's Avatar
Joined Feb 2007
I bought it from this eBay seller:
http://myworld.ebay.com/sweetheartst...84.m1439.l2754
It seems like there are several different Xexun clones. That would explain why mine works directly on the battery terminal and iacei's one does not. It probably needs a specific resistor load to register that the correct battery is connected. That is what the 3rd pin of the battery terminal is for.
I'm guessing you can measure the resistance between the battery's center pin and Gnd to see what the resistance is, and put a similar value resistor on the tracker between the center pin and Gnd. Take note that I'm guessing, so don't take my word for it.
Old Nov 23, 2012, 04:12 AM
Joined Oct 2012
Very interesting stuff thankyou!
Old Nov 23, 2012, 05:28 AM
Johan Moelich
Moelich73's Avatar
Joined Feb 2007
I searched for info on the 3rd battery terminal and found this:
The third pin is usually for an internal temperature sensor, to ensure safety during charging. Cheap knock-off batteries sometimes have a dummy sensor that returns a "temp OK" value regardless of actual temperature.
Some higher-end batteries have internal intelligence for charge control and status monitoring, in which case the third pin is for communications.
Source
Old Feb 19, 2013, 03:44 PM
Kragerĝ, Norway
Joined Jun 2010
Is it a battery on this tracker, or do you need to solder and fix your own servo cable from this tracker to an open channel on your reciever? Where can I buy a 2g sim card? I live in norway, and got a iphone 4S, so i got microsim only.
How does it work? You use a sim card you buy, a prepaid for example, and how do you send the message to the tracker, and where do you get the GPS cordinates?
Voguna is offline Find More Posts by Voguna
Old Feb 19, 2013, 06:37 PM
Joined Apr 2011
As an update, I have followed this thread for a while.
I purchased and installed the tracker in my Skywalker. I ended up using an ATT sim card in mine and it works great!!
I live in Texas, so international users will néed to adjust providers accordingly.
Good Luck,
Hector
texasdrifters is offline Find More Posts by texasdrifters
Old Feb 19, 2013, 11:46 PM
Joined Oct 2009
check the first post vaguna, always a good place to look for information on these types of threads
Jetboatftw is offline Find More Posts by Jetboatftw
Old Feb 21, 2013, 11:00 AM
Joined Mar 2008
Im having problems with powering this unit. LED stays solid with 5V power on the USB pins, but it does not respond to sms commands. But it works perfect with the battery (3,7V). Is it possible to power the unit with a 5V supply on the battery connectors?
BiZARRE is offline Find More Posts by BiZARRE
Old Feb 22, 2013, 11:07 AM
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
I fly where there is no cell service, so this would not work?
greedyg76 is offline Find More Posts by greedyg76
Old Feb 22, 2013, 11:16 AM
maurof78's Avatar
United States, IL, Chicago
Joined Feb 2012
Correct. The unit needs to be able to send a text message with the gps coordinates.
maurof78 is offline Find More Posts by maurof78
Discussion DIY UHF GPS tracker / beacon Fred. Video Piloting (FPV/RPV) 35 Feb 08, 2013 06:18 AM
Discussion No More Lost Planes!!!! GPS Tracker Plane Finder Locator rc_ron Electric Plane Talk 62 Jul 02, 2011 05:48 AM
Discussion GPS to GSM tracker ziomatrixacs Video Piloting (FPV/RPV) 19 Feb 18, 2011 06:13 PM
Discussion Real-Time GSM/GPRS Plane Tracking or lost plane finder. for 59$ ganapati08 Video Piloting (FPV/RPV) 12 Nov 05, 2010 10:21 AM
Discussion Using a GPS / GSM based tracker for downed plane locating air UAV - Unmanned Aerial Vehicles 1 Oct 02, 2007 05:32 AM
