United States, FL, Kissimmee
Joined Dec 2008
I've been watching this thread and now I am building one too ! I'll use the Eflite Delta V 28 mm EDF with a Castle Thunderbird 6 esc on 3 cell lipo. The one I am building right now will be a test bed for the components and to dial in the cg, the next one will be more detailed... I am also using a Spektrum board rescued from a Parkzone Sukoi, it took me a while to program it correctly for the elevons and took even longer to figure out how to adapt the esc but it all works now ! I'll put in some photos later on....
Fred, so far I've counted 3 motors that have gone but others may not have noticed it in theirs or everyone elses are still OK.
Nadine, I use hot glue on each side of the case to hold it in place. Makes it easier to remove the unit if needed. Next one will have that attachable design I've got to make things easier. Differences in the motors: eflite: 11450kV - has higher torque so good for static thrust (higher blade count at lower revs) Ammo: 12750kV - has higher kV so good for high eflux (lower blade count at higher revs) |
But Ammo d ont have 11500 kv!?.... For your Bae hawk,who is better motor choice from this 2 babies!!? Cheeeers |
Dave,you could, please,give me the correct link to buy one 25mm case edf,for 10mm inrunner!?...he tells me,page error!
Also,did you think,that with this 25mm edf,with Ammo inrunner and with one GWS 6 blades,but 6 blades not chopped to 3 blades,with 2S lipo,i could have resonabil t hrust!?...Thanks for your time ![]() Cheers |
http://www.shapeways.com/model/35184...-edf-case.html for 10mm inrunners.
http://www.shapeways.com/model/44491...mm-motors.html for 12mm inrunners. That's worth trying with the 6 blade count! You'd need bigger intakes or a cheater hole because of the increased static volume of air so you don't want to load down the motor by choking air supply. |
| Thread Tools | |
| Discussion Team30 Micro EDF T-45 BAE Hawk | NitroCharged | Micro EDF Jets and Power Systems | 481 | Feb 08, 2011 03:04 AM |
| Sold UltraFly T-45 BAE Hawk...price reduced | mgroves | Aircraft - Electric - Jets (FS/W) | 3 | Sep 23, 2010 12:53 PM |
| Sold UltraFly T-45 BAE Hawk...Price reduced | mgroves | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 23, 2010 11:36 AM |
| Sold Ultrafly T-45 BAE Hawk Pusher | mgroves | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 15, 2010 03:06 PM |
| For Sale BAE Hawk/T-45 Goshawk EDF kit | 747drvr | Aircraft - Electric - Airplanes (FS/W) | 1 | Jun 13, 2005 10:36 PM |
