Old Feb 07, 2011, 08:30 PM
balsa or carbon is online now
Find More Posts by balsa or carbon
Hot glue held together by foam
balsa or carbon's Avatar
United States, OR, Portland
Joined Aug 2010
Cool
Home made mechanical elevon mixer.
Here is a Leadfeather type PBF I made for a friend who doesn't have mixing capabilities on his transmitter , so I made a mechanical mixer. The bottom of the aileron servo is attached to a hinge , then a pushrod from the elevator servo is attached to another hinge near the top of the aileron servo. then the elevator servo can move the top of the aileron servo back and forth. Seems to work well!
Home made mechanical elevon mixer (0 min 26 sec)
balsa or carbon is online now Find More Posts by balsa or carbon
Old Feb 07, 2011, 09:13 PM
forevercat is offline
Find More Posts by forevercat
*crunch*
forevercat's Avatar
United States, CA, Saratoga
Joined Aug 2010
wow! i never thought it could be set up that way.
good idea
forevercat is offline Find More Posts by forevercat
Old Feb 07, 2011, 09:36 PM
Joined Aug 2010
good idea
Got the idea from browsing RC Groups! There is so much great information ( and inspiration ) available here!
Old Feb 08, 2011, 03:57 AM
SA/RCFlyer is offline
Find More Posts by SA/RCFlyer
SA/RCFlyer's Avatar
Joined Jan 2009
Can you draw a plan and post it?
SA/RCFlyer is offline Find More Posts by SA/RCFlyer
Old Feb 08, 2011, 09:08 AM
Del-Dredd is offline
Find More Posts by Del-Dredd
Del-Dredd's Avatar
Near Aberystwyth - Wales
Joined Aug 2004
Used to do things like that all the time years ago before the advent of Computer radios, it was the only way.
You even used to get premade variations using sliding trays etc or chunky bits of electronics (still got electronic one somewhere, probably with some old junk).
The best I saw was small cicular piece that attached on top of the aileron servo arm, this had a hinged piece on top which had a ball joint at each end for the aileron rods and a ball joint in the center that the elevator servo rod attached to.
Nice and compact and worked very well.
Del-Dredd is offline Find More Posts by Del-Dredd
Old Feb 08, 2011, 12:22 PM
poweredlawndart is offline
Find More Posts by poweredlawndart
Joined Aug 2004
http://shop.dubro.com/products/produ...=215/101.0.1.1
Take a look at this Dubro unit and it will give you some ideas...or you could by this one.
poweredlawndart is offline Find More Posts by poweredlawndart
Old Feb 08, 2011, 12:32 PM
Joined Aug 2010
Mechanical elevon mixer plans
Here are the ( hand drawn ) plans you asked for, along with some close-up photos. Hope it helps!
Old Feb 08, 2011, 12:43 PM
Joined Aug 2010
I saw that Dubro unit, but it's more fun to do it yourself! And I made this one with stuff I already had laying around.
Old Feb 13, 2011, 12:17 AM
Joined Aug 2010
video
here is my friend flying the PbF with the mechanical mixer. He's never before flown a plane capable of rolls or unlimited vertical, so he's really going for it!
Crazy Flying RC II (2 min 4 sec)
Old Feb 13, 2011, 01:12 AM
Slider2732 is offline
Find More Posts by Slider2732
Storm Runner guy
Slider2732's Avatar
USA, OK, Muskogee
Joined Nov 2008
Very neat and tidy. I have a V-tailed Cub that may well use your system there
Been wondering how to do such a thing with as few links and pieces as possible.
Slider2732 is offline Find More Posts by Slider2732
Old Feb 13, 2011, 02:10 AM
str8wing is offline
Find More Posts by str8wing
Las Vegas, NV
Joined Nov 2009
Interesting... The tilting servo was used to mix the collective in the old Xcell helicopter line (Circa 1990s), long before ccpm. 'Looks like it works well for you too. :-)
str8wing is offline Find More Posts by str8wing
Help! how to use this elevon mixer NEW222 Radios 6 Jan 11, 2011 07:08 PM
Sold Ohmark Elevon/V Tail Mixer EBerris Aircraft - General - Radio Equipment (FS/W) 0 Dec 29, 2010 08:49 PM
For Sale Elevon or V-tail mixer, Fm crytals mikeochs Aircraft - General - Radio Equipment (FS/W) 1 Dec 29, 2010 06:18 PM
Rave FirmTronics DigiMix - II Programmable Elevon and V-tail mixer WLJayne Sailplane Talk 0 Nov 08, 2010 12:26 PM
For Sale RX crystals, Hitec rx pack, Elevon, V-tail mixer mikeochs Aircraft - General - Radio Equipment (FS/W) 2 Oct 31, 2010 03:32 AM
