Old Sep 05, 2003, 01:45 AM
david_dewit is offline
Find More Posts by david_dewit
Australia
Joined Sep 2001
Almost there.
flying weight 8.5 gram
wing loading 0.6 oz/sqft
thrust 5.2 gram at the moment
current 180mA
rpm 2200
ratio 18.7:1
prop 132mm adjustable pitch
motor 4mm x 8mm 10 ohm
david_dewit is offline Find More Posts by david_dewit
Old Sep 05, 2003, 05:18 AM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
Looking very good! It has to fly
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Sep 05, 2003, 07:55 AM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Joined Nov 2000
Yep, definetly looks flyable. Any chance of a video of the maiden flight?
Michael
epilot is offline Find More Posts by epilot
Old Sep 05, 2003, 05:26 PM
billystiltner is offline
Find More Posts by billystiltner
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
I agreee that it will have to fly also but
it might be a trick to turn it right handed.
Or will it be left handed down under?
Do you guys use props that rotate
counterclockwise(from behind)?
The plane sure is pretty.
Thanks for the gearbox picture and info.
Billy
billystiltner is offline Find More Posts by billystiltner
Old Sep 05, 2003, 05:49 PM
TeamSME is offline
Find More Posts by TeamSME
40%, 5% whats the diff?
TeamSME's Avatar
Baltimore Greenbelt, Maryland, United States
Joined Jul 2003
Are there any step by step manuals on how to build an ir reciever. And is there a problem with ir radiation, like you have to wear some wierd glasses?
TeamSME is offline Find More Posts by TeamSME
Old Sep 12, 2003, 05:01 AM
Prashanth is offline
Find More Posts by Prashanth
Bangalore Hindustan, India
Joined Apr 2003
The biggest problem is getting the two chips required the LTC-3200 and irlm mosfet in the RX. Iam stuck without it.
help.....
Prashanth
Prashanth is offline Find More Posts by Prashanth
Old Sep 12, 2003, 05:39 AM
Australia
Joined Sep 2001
The IRLML2502 is easy enough to get, Farnell and Graham Stabler are just two sources.
The LTC3200 is also easy to get (Linear Technology) but s&h is $25.
Max1595 is replacement for LTC3200 and is available as free sample.
Dave
Old Sep 12, 2003, 10:11 AM
Joined Nov 2002
David
Have you flown the plane yet?
Does it turn good? I was just joking about the prop
rotating counterclockwise Down Under. I can see from
your photo that you have a normal prop. I am curious about the
large diameter prop. Wondering if it turns slow enough not to
generate too much torque. There was a discussion on FFML
recently about tourque rolls and some said the rubber acting on the rear hook generated the torque on the model. The discussion got pretty complicated and hard to follow so now I'm confused about big props and the effects they have on the flying. On my 3" rubber models decreasing rubber size(cross section) decreases torque rolls so maybe your prop is spinning slow enough.
Nice plane.
I bet it's fun.
Billy
Old Sep 12, 2003, 10:37 AM
Australia
Joined Sep 2001
Billy,
The triplane is flying good. Though it could do with more thrust to overcome high drag during slow fight and manuvering. Increased rudder area for better turning and moved cg forward as it seemed a bit pitch sensitive.
Prop does not seem to effect it much at all, needs little side thrust. Have since fitted bit motor and 160mm prop, still no noticeable effect. Triplane has a fair bit of wing area.
Dave
Old Sep 12, 2003, 11:51 AM
Joined Apr 2003
hey david
Could u please post a pic of ur finished tX and rx and also a video of ur micro flight
happy landings
Prashanth
Old Sep 12, 2003, 07:44 PM
Australia
Joined Sep 2001
Sorry, can't do a vidio yet.
Rx pic
Old Sep 12, 2003, 07:46 PM
Australia
Joined Sep 2001
Tx. need to put it in jiffy box.
Old Sep 12, 2003, 07:47 PM
Australia
Joined Sep 2001
Props tested so far.
Old Sep 12, 2003, 07:50 PM
Australia
Joined Sep 2001
5mm plastic bead used for adjustable pitch prop hub.
Cross drill for CF rod.
Old Sep 12, 2003, 09:11 PM
clipclop is offline
Find More Posts by clipclop
QLD, Australia
Joined Sep 2003
plugs
Great work David 8.5grams is realy getting down there, do you use plugs on your bat?, have you thought of these ie useing strip ic socket cut up as plugs the legs fit the socket so are male n female plug set
can use just 2 or if you want it pollarised to avoid disaster u can use a 3 pin with only the centre n 1 outside pin connected
clipclop is offline Find More Posts by clipclop
questions on diy ir rx jonathan8388 Scratchbuilt Indoor and Micro Models 29 Jan 11, 2005 10:44 AM
Question Diy IR Z-tron Tx micromad Scratchbuilt Indoor and Micro Models 0 Dec 10, 2004 11:50 AM
DIY IR Rx PCB's david_dewit Scratchbuilt Indoor and Micro Models 11 Nov 04, 2004 05:12 PM
Where is the DIY IR and LRFers thread? Timbo337 Scratchbuilt Indoor and Micro Models 2 Dec 30, 2003 04:29 PM
DIY IR 555 timer help. j8m8l Scratchbuilt Indoor and Micro Models 4 Dec 03, 2003 10:02 PM
