Old Dec 29, 2005, 08:20 PM
jonathan8388 is offline
Find More Posts by jonathan8388
Elmwood Park,NJ, United States
Joined Nov 2004
thanks Dave. i figured out what i had to do. i had to do ALOT of tweaking to the brightness and contrast of the colors. when that was done, it came out quite okay. i found the template for this RX in this forum, posted by Dave DEWIT. the black and white colors were reversed, so i put them where they had to be in my program.
i didnt have a laser printer, so luckily i picked this one up from EBAY http://cgi.ebay.com/ws/eBayISAPI.dll...tem=6833641877 i luckily got it pretty cheap too. it is 1200X1200 DPI how accurate will the small PCB printings be with a 1200X1200 DPI printer?
with all that said, i still DIDN'T find any artwork for the IRXA301 on Koichi's site. i searched through each of his projects twice(which took me 30 minutes to do), but i still didnt find one.
jonathan8388 is offline Find More Posts by jonathan8388
Old Dec 30, 2005, 08:00 AM
Dave Wulff is offline
Find More Posts by Dave Wulff
Dave Wulff's Avatar
USA, FL, Fort Lauderdale
Joined Feb 2002
Go back to page 21 of this thread, there is a post by Koichi (#303). Click on his name and a dialoge box will drop down. Click on the link to his homepage, Tokos Home Page comes up, click on the line that says "english translation" it will show you his site through Bablefish. If Bablefish gives you a translation error, just back up and try again, sometimes it takes a few trys to get it to load right. On the left hand column, scroll down to the Main Catagory and click on PIV/AVR. It is an index of all of his projects. The 301 rx is listed as #32, open it up and scroll down, there are 2 pix of the rx, underneath are highlighted links to the GIF pcb files. Right click on the link and do a save as and put it where you can find it. Pay attention to the 200 pixel/cm note, that what it needs to be printed at in PhotoShop to be the right size. I thought all you kids were computer wizards?
Dave
Dave Wulff is offline Find More Posts by Dave Wulff
Old Dec 30, 2005, 05:17 PM
david_dewit is offline
Find More Posts by david_dewit
Australia
Joined Sep 2001
Artwork for 301 is listed in index of this thread as "Koichi's pcb artwork for 200 ohm coils" page 15 post 225
Copy and paste to MSword, right click on image to resize as %
Dave
david_dewit is offline Find More Posts by david_dewit
Old Aug 07, 2006, 03:19 AM
nathanrcman is offline
Find More Posts by nathanrcman
nathanrcman's Avatar
Joined Nov 2003
Hi guys im thinking of making one of these rx's and a tx transmitter for it.
I ve read all through this and lernt quite a bit, do you guys have any pointers on building one, or before i build?
I have not yet though found a part list of everything i need for the rx and tx. can someone out there help me. Im aware this rx total weight ends up around 0.4g? So then this rx CAN be used on a square 9 am i correct? Because i have the plane built and am trying to find a cheap resoloution for an rx. How much approx will one of these and tx be to build? Thanks alot guys for the help
Nathan
nathanrcman is offline Find More Posts by nathanrcman
Old Aug 07, 2006, 08:25 AM
Australia
Joined Sep 2001
Hi Nathan,
Read the first post (index) of this thread again. You will find link to parts list
there. You will also find some programming tips there. Koichi's IR is ideal for the Sq9. Your best solution may be to buy a kit or built unit from Koichi.
Dave
Old Nov 11, 2008, 09:18 PM
iver is offline
Find More Posts by iver
Joined Sep 2006
Hi friends... I wat to make my own battery charger for the 30mah. 50mah and 90mah LI-POs.
Can anybody help me with shematics for a DIY LI PO charger.
iver is offline Find More Posts by iver
Old Nov 13, 2008, 04:26 AM
Australia
Joined Sep 2001
Easiest diy charger to build uses LTC4054L. Will charge cells from 10 - 140mA.
Program resistor = 150/charge current, answer in K ohm.
eg: 150 divided by 30mA = 5K
4.5 - 6V supply.
You might read data sheet.
Dave
Old Nov 13, 2008, 06:50 AM
mrfliboy is offline
Find More Posts by mrfliboy
Don't leave it Stock
mrfliboy's Avatar
USA, IL, Round Lake
Joined Feb 2004
Hey Dave,
I can not believe I have not run across that schematic before. Is this something you are currently using? I pratically live on this site LOL Thanks
mrfliboy is offline Find More Posts by mrfliboy
Old Nov 13, 2008, 10:06 AM
msurguy is offline
Find More Posts by msurguy
Max
Joined Jul 2006
I've posted about the above simple charger and some more info on it here :
http://www.rcgroups.com/forums/showp...8&postcount=19
Using it till this day.
msurguy is offline Find More Posts by msurguy
Old Nov 13, 2008, 10:34 AM
mrfliboy is offline
mrfliboy's Avatar
USA, IL, Round Lake
Joined Feb 2004
Thanks msurguy, I thought I'd seen and built them all. Thanks for another project. LOL
Old Nov 13, 2008, 10:43 AM
msurguy is offline
Max
Joined Jul 2006
You're welcome !
P.S. there are many more new simple to build chargers from the linear technologies for even bigger currents, and i believe you can order samples from their website for free.
www.linear.com
Old Nov 14, 2008, 04:53 AM
Australia
Joined Sep 2001
Originally Posted by mrfliboy
Hey Dave,
I've been using these chargers since about January 2004
http://www.rcgroups.com/forums/showp...&postcount=338
Dave
Old Feb 03, 2010, 07:22 AM
starscream4002 is offline
Find More Posts by starscream4002
starscream4002's Avatar
Tabriz, Iran
Joined Sep 2008
how do you roll so neat balsa tubes?
starscream4002 is offline Find More Posts by starscream4002
questions on diy ir rx jonathan8388 Scratchbuilt Indoor and Micro Models 29 Jan 11, 2005 10:44 AM
Question Diy IR Z-tron Tx micromad Scratchbuilt Indoor and Micro Models 0 Dec 10, 2004 11:50 AM
DIY IR Rx PCB's david_dewit Scratchbuilt Indoor and Micro Models 11 Nov 04, 2004 05:12 PM
Where is the DIY IR and LRFers thread? Timbo337 Scratchbuilt Indoor and Micro Models 2 Dec 30, 2003 04:29 PM
DIY IR 555 timer help. j8m8l Scratchbuilt Indoor and Micro Models 4 Dec 03, 2003 10:02 PM
