Old Aug 15, 2003, 08:54 AM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Joined Nov 2000
Dave, I think the finding a suitable mill bit might be a problem at this size??
Why not photo etch? Print out layout on a transperent and get some photo sensitive pcb. AFAIK you can use sunlight for the exposure.
Michael
epilot is offline Find More Posts by epilot
Old Aug 15, 2003, 11:43 AM
GailInNM is offline
Find More Posts by GailInNM
Near Albuquerque, NM USA
Joined Apr 2003
Dave: Milling PWB's is done quite often for prototyping. There are several several machines built for that purpose and associated softwre is available to do large area copper removal to make "conventional" looking boards. Very small eyelets are normally used for layer interconnects for double sided boards. All of this is expensive however. I have used these machines some and they work well.
I have milled PWB's with a CNC milling machine for years doing the same type of layout style that you are doing where a minimum amount of copper is removed. I normally use a conical point engraving type cutter with a flattened tip to give about 0.005 wide removal line width. These cost aobut $10 or so if you buy them or take about 5 minutes to make from a "used up" 1/8 shank carbide end mill using a diamond wheel. They like to turn at 20K RPM or more but will work at 3500 in a pinch. You do need to use carbide as glass board really eats up HHS rapidly.
GailInNM is offline Find More Posts by GailInNM
Old Aug 16, 2003, 04:21 AM
david_dewit is offline
Find More Posts by david_dewit
Australia
Joined Sep 2001
Thanks for that.
Maybe a dremel mounted verticaly with a suitable tip might even work for small pcb's.
Picture of pcb with components
david_dewit is offline Find More Posts by david_dewit
Old Aug 16, 2003, 08:21 AM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
I am sure I can mill pcbs with my Proxxon CNC conversion. Another possibility would be to build a small hand cranked mill. A few micrometer slides off ebay and a dremel
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Aug 16, 2003, 09:36 AM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
Dave,
I use a system called Press n Peel, it works by printing the pattern you want at 1:1 scale onto a special release film which you then iron onto the copper side of your PCB material. The film is peeled away to leave the printer's toner stuck to the surface of the board, the etch resist layer. You do have to etch this but the P n P system provides a clean etchant, it is completely clear and does not stain everything in sight like ferric chloride.
Press n Peel comes from USA but is available in the UK and I guess other places too I get it from MPS (Maplin).
Andy.
AndyOne is offline Find More Posts by AndyOne
Old Aug 17, 2003, 10:15 PM
Australia
Joined Sep 2001
Thanks.
Familiar with etching process, press 'n' peel, riston etc. A lot to buy for a small pcb or two. Having said that I'm sure I would use it on other projects and when the cost is divided up!
On the other hand if you already have a mill, lathe and or dremel!
Dremel mounted over lathe, pcb fixed to slide.
Dave
Old Aug 17, 2003, 10:16 PM
Australia
Joined Sep 2001
Old Aug 18, 2003, 10:18 AM
indoor flyer is offline
Find More Posts by indoor flyer
chicago
Joined Jul 2003
Thats a nice looking reciever! about how much does it wiegh?
indoor flyer is offline Find More Posts by indoor flyer
Old Aug 18, 2003, 11:15 PM
Australia
Joined Sep 2001
Haven't weighed it yet, but it is small and light.
The Rx I guess is about 1 gram at most.
With wires and sensor about 1.5 gram tops.
Have powered up smd IR Rx without motor attached, it works.
Must say I'm impressed with this little Rx.
Dave
Old Aug 26, 2003, 07:46 PM
Australia
Joined Sep 2001
Have now weighed IR Rx on 0.1 gram resolution scales, as pictured below with wires and light weight batt connecter (about 0.4 gram) and sensor weighs just 1.2 grams.
Being so light I have made a slightly larger pcb to give more room for soldering wires direct. Board will use some smaller components (pic and 1uF caps) So weight increase will be little or none.
Dave
Old Aug 26, 2003, 07:55 PM
Australia
Joined Sep 2001
1.2 grams
Old Aug 27, 2003, 04:26 AM
Philip Thulin is offline
Find More Posts by Philip Thulin
Hacker motoren rules :)
Philip Thulin's Avatar
Sweden, Östergötland County, Norrköping
Joined Sep 2001
just use some thinner wire and you´ll be below 1 g
looks great!
How did you conect the TX board to your TX?
sounds promising if you can use your regular TX to IR stuff
/Philip
Philip Thulin is offline Find More Posts by Philip Thulin
Old Aug 27, 2003, 08:02 AM
Australia
Joined Sep 2001
Phillip
Yes the wiring is a bit heavy duty. All I could lay my hands on.
Have to get something better from Graham.
The IR Tx plugs into trainer jack. Couldn't be easier.
Dave
Old Aug 27, 2003, 08:37 AM
Sticky Shepherd
Oxford/England
Joined May 2001
For an quick source of wire check out dead mice cables. Not as nice as my wire but cheap.
For signal connections make your own litz wire by twisting together say 7 strands of really thin copper wire. Use a power screwdriver and anchor the other end of the bunch on a sprung hook (this helps stop snapping.
Graham
Old Aug 27, 2003, 08:54 AM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Dave,
I'm a huge convert to Graham's light weight wire. But, to save a bit of additional weight I sand off all possible excess plastic on those type of plugs. It helps. Your board looks great. Keep it up!
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
questions on diy ir rx jonathan8388 Scratchbuilt Indoor and Micro Models 29 Jan 11, 2005 10:44 AM
Question Diy IR Z-tron Tx micromad Scratchbuilt Indoor and Micro Models 0 Dec 10, 2004 11:50 AM
DIY IR Rx PCB's david_dewit Scratchbuilt Indoor and Micro Models 11 Nov 04, 2004 05:12 PM
Where is the DIY IR and LRFers thread? Timbo337 Scratchbuilt Indoor and Micro Models 2 Dec 30, 2003 04:29 PM
DIY IR 555 timer help. j8m8l Scratchbuilt Indoor and Micro Models 4 Dec 03, 2003 10:02 PM
