Old Aug 01, 2003, 06:09 AM
david_dewit is offline
Find More Posts by david_dewit
Australia
Joined Sep 2001
DIY IR LRFers
I started this model last night. Obviously inspired by the Midge and a want for something a bit more relaxing than the helis to fly in the living room.
Expecting it to be a bit heavier I increased the wing area by approx 50% to 72sq in. Span is 8 inchs. Airframe without wheels is 2g. Guesstimates say: model 2g, batt 2g, IR 2g, motor/g/p 2g. All up weight less than 9 grams. When I get some more CF I'll make a carbon version.
Updated 3/3/05
Planning to use Koichi Tanaka's DIY infra red, discussed here and in DIY infra red thread. This is a 3ch unit, rudder, elevator and throttle. Receiver has inbuilt ESC. Transmitter consists of small module that plugs into trainer jack or if you don't have this feature it can be wired into most transmitters. A stand alone tx can also be made using playstation controller and joysticks.
Thanks and credit to Andy Birkett.
Credit and many thanks to Koichi Tanaka for his help.
Index
MicroWorks For small model supplies in Australia
Koichi Tanaka's web page
IR Tx module schematic and hex file No's 15 and 18. Koichi's page PIC/AVR learning.
IR Rx schematic and hex file No 16. as above (for 200 ohm coils)
PIC writer, as above
Flat package adapter No 1, as above
Flat package adapter pictures, page 20 and 31 DIY infra red
http://www.rcgroups.com/forums/showp...postcount=2356
Babelfish translater
Ic-prog
Because transmitter channel assignment and neutral differs between brands, it is neccessary to use receiver software to suit your particular transmitter.
Transmitter software is same for all three transmitters, is both 38 and 57kHz and selectable by switch.
Transmitter schematics differ between brands because of different trainer jack socket and shift. My Hitec Eclipse works with Futaba schemtic with throttle trim all the way down.
Receiver software (hex files) is available to suit Futaba, JR and Sanwa transmitters.
Receiver can be made to operate on 38 or 57kHz, simply by using 38 or 57kHz sensor.
Koichi now has a number of IR transmitter and receiver units to choose from. Details of all can be found on his PIC/AVR page.
JDM programmer
Farnell
IR receiver component layout
Parts List Has links to Digikey, Linear Technologies and Maxim. Credit and thanks to Dindea
Rx pcb layout for Max1595
Lightening Sensor
Thinning pcb
Picture of finished Rx
Formula Wheel
200 ohm Coil Specs
Picture of Flat Package Adapter smd pic to dip socket
Flat Package Adapter Another way of doing it.
UV Lamps
Rx pcb layout for LTC3200
Mechanical timer has 12/60 M3 gears and coil wire
Component Size Chart Courtesy of clipclop
Koichi's pcb artwork for 200ohm Rx
Programming hints and tips.
Keep progammer lead short, better still, plug programmer directly into PC.
Download hex files directly from Koichi's site, don't download whilst viewing through babelfish.
If you are having problems go to ICprog "settings" and click on "clear settings" and check that your settings are correct. My hardware settings (98SE) are:
Ports = Com2
I/O delay = (4)
Interface = Windows API
Communication = all unchecked
david_dewit is offline Find More Posts by david_dewit
Old Aug 01, 2003, 06:14 AM
Australia
Joined Sep 2001
IR Rx
Old Aug 02, 2003, 06:54 PM
bmutlugil is offline
Find More Posts by bmutlugil
bmutlugil's Avatar
Turkey
Joined May 2002
Hi David,
That looks very good. Were the TX and RX schematics published in the DIY IR thread?
I could convert my long forgotten 27MHz TX to IR - this band is dangerous to use here.. I have some experience with IR coding (RC5). I had built a uP RX working with standard IR TV remote control units - this was for a mechanical engineering student project - it was only multi channel on-off control. People kept asking if the robot (a mars rover kind of thing) received all TV channels, during the project contest
I don't have the time for anything news, though.
Best regards,
Bulent
bmutlugil is offline Find More Posts by bmutlugil
Old Aug 03, 2003, 06:20 PM
Australia
Joined Sep 2001
Hi Bulent,
for schematics and hex files see index above
Dave
Old Aug 04, 2003, 07:19 PM
Australia
Joined Sep 2001
IR Tx
Old Aug 05, 2003, 11:05 AM
isaac-bees is offline
Find More Posts by isaac-bees
isaac-bees's Avatar
Newport, WA US
Joined Aug 2000
wow! Both the RX and the tx are really simple! (looking at least) What kind of signal do the tx units require? I have a ACE micropro8000 with dual freq. but I am not sure what the output going to the rf board looks like. Would a gws tx work?
Isaac.S
isaac-bees is offline Find More Posts by isaac-bees
Old Aug 06, 2003, 05:53 PM
Australia
Joined Sep 2001
Isaac,
I guess most transmitters will work, my IR Tx module plugs into trainer jack, makes it easy.
Source for small gears and some other goodies is 24 hour mechanical timers. Gears are 60/12 x .2
Old Aug 07, 2003, 06:12 AM
Australia
Joined Sep 2001
The timers are selling for $5.95 AUD.
One Didel 60/12 is approx. $5.10 USD.
There are three 6o/12 x .3 gears in a timer, enough for one two stage gearbox, ($38 USD)
The enemaled wire might be suitable for some actuator coils.
25:1 gearbox.
Dave
Old Aug 15, 2003, 05:26 AM
Australia
Joined Sep 2001
First go at pcb.
Have soldered sm pic in place and done programming.
Don't realise how small it is till you get this far.
Dave
Old Aug 15, 2003, 05:47 AM
j8m8l is offline
Find More Posts by j8m8l
Thats NOT indestructible
j8m8l's Avatar
London UK
Joined Apr 2002
Dave
That is really tiny !, nice work.
Did you design the board?
Josh
j8m8l is offline Find More Posts by j8m8l
Old Aug 15, 2003, 07:08 AM
Australia
Joined Sep 2001
Hi Josh,
The board is similar, but not identical to Koichi's board.
Measures 14 x 11 mm.
Dave
Old Aug 15, 2003, 08:02 AM
Australia
Joined Sep 2001
Rough drawing of pcb layout, on grid paper, good for quick scale drawings.
Dave
Old Aug 15, 2003, 08:13 AM
j8m8l is offline
j8m8l's Avatar
London UK
Joined Apr 2002
I see it now, very nice.
That includes v boosting doesnt it?
Josh
Old Aug 15, 2003, 08:28 AM
Australia
Joined Sep 2001
Thats right Josh,
LTC3200ES6-5, 100mA low noise charge pump.
PIC12C509A-04/SN
IRLML2502 mosfet, N SOT-23
0805 104 cap, .1uF x 2
0805 105 cap, 1uF x 3
Dave
Old Aug 15, 2003, 08:42 AM
Australia
Joined Sep 2001
Does anyone use a mill to make pcb's? to cut copper away,
instead of using etchant or a knife as I did to make above pcb.
Looking for an easier method.
Dave
questions on diy ir rx jonathan8388 Scratchbuilt Indoor and Micro Models 29 Jan 11, 2005 10:44 AM
Question Diy IR Z-tron Tx micromad Scratchbuilt Indoor and Micro Models 0 Dec 10, 2004 11:50 AM
DIY IR Rx PCB's david_dewit Scratchbuilt Indoor and Micro Models 11 Nov 04, 2004 05:12 PM
Where is the DIY IR and LRFers thread? Timbo337 Scratchbuilt Indoor and Micro Models 2 Dec 30, 2003 04:29 PM
DIY IR 555 timer help. j8m8l Scratchbuilt Indoor and Micro Models 4 Dec 03, 2003 10:02 PM
