Old Feb 07, 2011, 05:21 AM
Joined Oct 2007
need help with p80 pls pls pls pls
Hi all
Pls I need your help
I have a jet cat p80 and I have only 2hours on it and this week I but it on falcon 120 and I test it and I have a problem with it ..
The problem is :
The max rpm is 123000 as we no so when I start the jet and I go to the run menu when u see u-bump : and rpm : on this menu when I go full throttle the u-bump is go from 0.400 to 1.7 only and the rpm go to max rpm 81000 only and I don’t know way ……………..
So I rest the default sitting in the ECU and try it agene the u-bump go to 2.6 or 2.7 and rpm 110000 or 113000 only …
And in every time I start the electric jet power I have the same thing and I have to rest the default sitting to get the 110000 or 113000 rpm and I don’t know way is that happen to me……………so pls any one can help me]
I have the ECU V 5.0 and software 5.1 or 5.01 I think …
Thanks any way
cool_t5 is offline Find More Posts by cool_t5
Old Feb 08, 2011, 10:34 PM
Joined Oct 2007
helloooooooooooooooooooooooooooooo plsssssssssssssssssss
Old Feb 09, 2011, 02:29 PM
aeh
Finland
Joined May 2007
Have you tried Jetcat customer support?
aeh is offline Find More Posts by aeh
Old Feb 09, 2011, 09:57 PM
Joined Oct 2007
yah i sent email but no replay i am waiting
Old Mar 17, 2011, 09:47 AM
Joined Jan 2006
Couple of things:
In the Min/Max memu is the max RPM set too 123,000
I assume by bump you mean pump @ max voltage this should go too 4.3volts or thereabouts, check your acceleration mode in the Min/Max menu.
Go to the JetCat US site and download the JetCat manual, it is vastly different and has more information on it than the one you get from JetCat or any retailer in the UK.
I don't frequent this Fourm very often so if you ask questions you may not get a reply from me in quick order.
BaldEagel is offline Find More Posts by BaldEagel
Old Mar 18, 2011, 01:12 PM
Bleriot's R Us
xairflyer's Avatar
Ireland, County Donegal, Letterkenny
Joined Nov 2003
Bump had me confused too !
xairflyer is offline Find More Posts by xairflyer
Discussion jet cat p80 problem pls help cool_t5 Fuel Jet Talk 4 Feb 09, 2011 09:54 PM
Help! Noob needs help assembling propeler!!! pls help ! omarko Power Systems 5 Jan 19, 2011 06:04 AM
Discussion Help me program 9C for Pan/Tilt pls MaxGen Video Piloting (FPV/RPV) 6 Oct 19, 2010 08:18 AM
For Sale Need help with sale or trade for heli with my brand new just built gp reactor neweramarketin Aircraft - Fuel - Airplanes (FS/W) 6 Sep 30, 2010 07:26 PM
hy..i need some help pls with a gsmart mini3... alex_SW Aerial Photography 4 Jan 13, 2004 12:53 PM
