Old Feb 07, 2011, 02:06 AM
vmaxmasonrya is offline
Find More Posts by vmaxmasonrya
vmaxmasonrya's Avatar
USA, CA, Arcadia
Joined Apr 2006
Question
how to repair antenna?
I recently purchased a 6 channel corona fm receiver. It had a kink in the antenna. When I put it in my plane and tried to maiden, I lost control when the model was 20 feet away. I duplicated the problem when I put the receiver in another plane and lost control after 20 feet.
My question is if I could just replace a kinked antenna wire with the wire from another fm receiver? does it have to be the same gauge?
any help would be greatly appreciated
vmaxmasonrya is offline Find More Posts by vmaxmasonrya
Old Feb 07, 2011, 02:19 AM
David Hogue is offline
Find More Posts by David Hogue
Blew out my flip flop
David Hogue's Avatar
USA, NC, Clayton
Joined Feb 2001
As long as its close to the same gauge...you dont want too thin for durability reasons, nor too thick for weight. The rx doesnt care what gauge it is, all that matters to it is the length. Get the length as close as you can to the original...within 1/4inch should be fine
David Hogue is offline Find More Posts by David Hogue
Old Feb 07, 2011, 02:28 AM
coastalflyer is offline
Find More Posts by coastalflyer
Build/Fly/Crash/Repeat
United States, CA, Diablo
Joined Jan 2002
What he said.
Any gauge will be fine, but get too thin and it will break easily.
The "kink" in your original antenna has probably caused the wire to break inside the insulation, resulting in a significantly shorter antenna.
Before you fly this receiver again, and ANY receiver you are unfamiliar with, DO A RANGE CHECK.
Good luck with your repair. Don't overheat the circuit bd. when you attach the new antenna. One way to avoid this is to cut the existing antenna a few inches from the bd. and attach your new one to that point, avoiding having to heat the bd. at all.
On some receiver I've done this and then used a small bullet connector to attach the antenna. This allows you to easily remove the receiver and move it around planes without having to remove the entire antenna.
coastalflyer is offline Find More Posts by coastalflyer
Old Feb 07, 2011, 02:46 AM
USA, CA, Arcadia
Joined Apr 2006
wow! thank you for your answers. I guess you are up late as well.
Old Feb 07, 2011, 11:22 AM
cliffh is offline
Find More Posts by cliffh
Gustavus, OH
Joined Oct 2007
CoastalFlyer gave some very good advice. I'll only add that soldering very thin wire and/or soldering to a very small PC board requires some skill that is only obtained with experience.
If you are not real good or experienced with soldering, please, find someone who is to do this 2 minute job. Your receiver can be ruined in the same amount of time if the job isn't done correctly
Besides heat, solder "bridges" can form which can really mess things up.
The only problem with cutting the antenna wire short, then soldering to that piece, is that where the wire/solder joint is located becomes a stress point. It will be very easy for that exact spot to break with some flexing. It can work okay, but if you do the repair this way, be sure to tape the wire joint to the airplane surface so that this area does not flex at all.
This is a very simple repair, but a very important one that you want to make sure was done correctly.
Cliff
cliffh is offline Find More Posts by cliffh
Old Feb 07, 2011, 11:38 AM
larsy87 is offline
Find More Posts by larsy87
Lookin' Good. Real Good.
larsy87's Avatar
London, Canada
Joined Aug 2002
You could probably get away with buying a shortened antennae. I think azarr makes them? and are really short, easy to install, and cheap. and proven to work.
larsy87 is offline Find More Posts by larsy87
Old Feb 07, 2011, 02:59 PM
LuckyArmpit is offline
Find More Posts by LuckyArmpit
Rehab is for quitters
LuckyArmpit's Avatar
West Middlesex, PA, US
Joined Jun 2001
I've replaced antennas a few times. A 4 channel Berg I had, the antenna was ripped off of the board. I used a 25 watt soldering iron to get it back on the board. It t'weren't easy!!!!
I've also made patches where I had to re-attach a portion of the antenna. This was easier than the other repair. I used shrink also. Both of these rx's work like new. Especially the Berg since it's been repaired twice and has also spent some time in trees for a few weeks.
One thing to keep in mind like some of the others have said, keep the length!!!!
I believe 72 mhz FM rx antennas are 39 inches long.
Lucky...
LuckyArmpit is offline Find More Posts by LuckyArmpit
Old Feb 08, 2011, 02:22 AM
USA, CA, Arcadia
Joined Apr 2006
thanks everyone.
Old Feb 08, 2011, 08:22 AM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
On a typical receiver, a 39 to 41 inch antenna will work well, you won't be able to tell the difference in performance with those limits on length.
Rodney is offline Find More Posts by Rodney
Old Feb 08, 2011, 10:00 AM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
Originally Posted by CoastalFlyer View Post
What he said.
That's an excellent idea - one other possibility would be to use the gold pin and socket from an ordinary servo extension lead, soldered or crimped, as appropriate ad further secured with a piece of heatshrink.
leccyflyer is offline Find More Posts by leccyflyer
Question How to repair a broken antenna on a Spektrum AR6100e Rx? liam2317 Radios 8 Sep 24, 2015 10:19 PM
Discussion How to repair a cut antenna? coreysnyder04 Foamies (Scratchbuilt) 12 Aug 14, 2013 07:03 AM
Question First blasa plane. How to repair light wingtip scrape damage? T-CAT The Builders Workshop 5 Oct 06, 2010 10:56 PM
Help! How to repair my balsa T-34? j10fighter The Builders Workshop 6 Oct 05, 2010 01:11 PM
Discussion how to repair x-twin bi-wing antenna devnath99 Micro Ready-to-Fly 1 Oct 06, 2009 12:33 PM
