Old Feb 16, 2013, 02:48 AM
RWData is offline
Find More Posts by RWData
PowerTower
RWData's Avatar
United Kingdom, England, Bristol
Joined Aug 2009
I'm pretty sure mine are 25mm right across, easier to match.
If you go for spec, it's sure to work but 25mm width is about as small as I would go to give the surface enough rigidity. It's quite a long aileron and working it from quite near the inner side you will want it to be able to cope with wind pressure on it when at full tilt. If I were to mod the control surface at all, I would have the inner-most area bigger, making the fixed wing area a bit more prallel to the LE, but not much, maybe 25mm narrow to 40mm wide.
It's easy enough to cut new ailerons in, if after a couple of flights you want to try something different, but first outing I would stay closer to 25mm parallel control surface. Hope this helps
RWData is offline Find More Posts by RWData
Old Feb 16, 2013, 10:23 AM
headlessagain is online now
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Craig, nice tidy build
25mm wide ailerons with max mechanical throws i.e. furthest hole out on servo arm and lowest hole on control horn will be very aerobatic. When you get to the maiden I'd launch on 50% rates and say 30-40% expo on the aileron and elevator and adjust back from as required.
Andy
headlessagain is online now Find More Posts by headlessagain
Old Feb 16, 2013, 12:13 PM
craigblk is offline
Find More Posts by craigblk
RC Geeky
craigblk's Avatar
United Kingdom, Watford
Joined Mar 2011
Andy
Thank you Andy and for the rates / expo info.....cut in and hinged rudders today, 33mm deep and about 80mm long, will have to angle in the ends of the elevator slightly so as not to bind on the rudder at full deflection but looking good so far...Craig
craigblk is offline Find More Posts by craigblk
Old Feb 16, 2013, 05:42 PM
Nicoflyer is offline
Find More Posts by Nicoflyer
Pushing the envelope
Nicoflyer's Avatar
Valatie, N.Y.
Joined Jan 2006
Craig, can you post a picture of your FunBat, would like to see how you made your rudders.
Nicoflyer is offline Find More Posts by Nicoflyer
Old Feb 17, 2013, 07:53 AM
craigblk is offline
RC Geeky
craigblk's Avatar
Joined Mar 2011
Rudders
Nico
Picture of rudders attached hope this helps, if you require further info then don't hesitate to ask...Craig
Old Feb 17, 2013, 09:56 AM
Nicoflyer's Avatar
Valatie, N.Y.
Joined Jan 2006
When the plane is all done post a picture of it. This is how I did mine. Name: ImageUploadedByTapatalk1361116452.891904.jpg
Description: Name: ImageUploadedByTapatalk1361116530.145006.jpg
Description:
Old Feb 17, 2013, 10:15 AM
Nicoflyer's Avatar
Valatie, N.Y.
Joined Jan 2006
Here's a video.
Fun bat mini (0 min 14 sec)
Old Feb 17, 2013, 10:22 AM
craigblk is offline
RC Geeky
craigblk's Avatar
Joined Mar 2011
Canopy
When the plane is all done post a picture of it. This is how I did mine. Attachment 5543955Attachment 5543956
Nico
Canopy looks great does it house any electronics or is it purely for aesthetics....may have to do something similar if you don't mind me using your idea....Craig
Old Feb 17, 2013, 10:33 AM
Nicoflyer's Avatar
Valatie, N.Y.
Joined Jan 2006
Go for it, that's what this hobby is all about. Sharing good ideas, and no to housing anything.
Old Feb 17, 2013, 12:47 PM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
New CNC layout for the original Funbat
birdofplay is offline Find More Posts by birdofplay
Old Feb 17, 2013, 12:54 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Now that all the excitement about the Flyguys has calmed down I have some
time to revisit the Funbat.
The Old Funbat has had many builds and mods and I decided to revisit my layout
to see it I couldn't improve things a bit.
I've Lengthened the Nose about 1" for those having trouble getting the CG forward.
I also put the Wing and KF doubler parts together so they are now one piece.
To do that, I changed the CUT LINE and tab for Fore/Aft Wing parts.
A very minor misalignment was fixed as well.
So NOW you can cut out your Funbat from 1 1/2 sheets for Depron or whatever.
I'll be offering them at the same price as materials and cutting time Have not changed
See the new layout attached above.
Looking forward to Spring FINALLY !!!
Bob
Hoosier Cutout Service
Old Feb 18, 2013, 07:16 PM
cwindram is offline
Find More Posts by cwindram
Central Scrutinizer
cwindram's Avatar
United States, MA
Joined Dec 2012
This'll be my first foamy. Coupla pics from the build, including my buddy RS pasting up the plans.Thanks to all on the thread for the tips n info. - C
cwindram is offline Find More Posts by cwindram
Old Feb 18, 2013, 08:21 PM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Congrats! You'll enjoy this plane.
mclarkson is offline Find More Posts by mclarkson
Old Feb 21, 2013, 12:29 AM
craigblk is offline
RC Geeky
craigblk's Avatar
Joined Mar 2011
Does anyone have any pics of a battery tray and how it's made for the funbat with extended nose including any restraints to prevent movement in flight. I assume speed controler and RX will sit below the battery tray taking into account CG obviously...just the servos and motor to install after that so any help would be appreciated...Regards Craig
Old Feb 21, 2013, 02:20 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Hi Craig
Use "Tread tools", "Show attachments.." to find photos. Then click on "post/pict.." to go to the full post showing the picture. Here is how I did my first one.
http://www.rcgroups.com/forums/showp...&postcount=106
You can see the esc and rx position underneath the lipo compartment before I sealed up the bottom. Cooling air comes into the bottom and top section via a slot in the ply motor mount and cut out in the depron lipo tray. It exits via a hole further back underneath. The lipo is just held in with a strip of velcro although you could add a strap if you wanted to.
Andy
For Sale Ace Simple Corsair, GP combat Mustang, .40 trainer LoneRanger Aircraft - Fuel - Airplanes (FS/W) 4 Nov 07, 2010 12:27 PM
Discussion BoxFly Simple Foamboard plane good for windy days with video & plans propjobbill Foamies (Scratchbuilt) 16 Nov 01, 2010 10:18 AM
Discussion Simple 3D balsa plane chulian1819 3D Flying 0 Oct 13, 2010 10:26 AM
For Sale NIB J&C Funbat -combat aircraft kit - $15 shipped JBFergus Aircraft - Fuel - Airplanes (FS/W) 0 Dec 05, 2008 05:07 PM
Can I slope this kind of plane? WM combat plane or ACE simple 400?? Magna Slope 3 Oct 20, 2003 10:27 PM
