Old Aug 12, 2012, 12:59 AM
chris1379 is offline
Find More Posts by chris1379
chris1379's Avatar
United States, OH, Eaton
Joined May 2006
Originally Posted by headlessagain View Post
Looks like a Funbat to me. Here are the naked photos of my Funbat "Ultra" build.Maiden was interesting as a touch tail heavy and had lots of up trim in. Got her down in one piece so have to regard as a success.
Andy
Looks good! The twin aileron servos will let you have flaperons. Have fun playing with them but you will probably need some elevator mix like I do. I still don't have it right but you should be able to slow it way down with flaps. Keep us updated.
Chris
chris1379 is offline Find More Posts by chris1379
Old Aug 12, 2012, 01:28 AM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Moved the lipo forward and took her up for another flight. Much better but I may have to cut into the le to have enough space for the 4s pack I was planning to use. Good job I used a beefy cf arrow shaft for the spar.
I was able to open her up but getting excessive flutter. I think it's because I used ball joints at the servo end. Changed for nylon control links so hope this will cure the problem.
Time to add some colour.
Andy
headlessagain is offline Find More Posts by headlessagain
Old Aug 13, 2012, 01:51 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
hey andy that looks cool.so where the colour at?
chop stiX is offline Find More Posts by chop stiX
Old Aug 13, 2012, 01:35 PM
Mopower71 is offline
Find More Posts by Mopower71
Corsir Crasher
Mopower71's Avatar
United States, NY, Poughkeepsie
Joined Oct 2011
Version 2 got a bit of color today
Mopower71 is offline Find More Posts by Mopower71
Old Aug 13, 2012, 03:20 PM
STO is offline
STO
Find More Posts by STO
STO
STO's Avatar
Ontario, Canada
Joined Jul 2005
Motor choice
Hi all. I'm planning on building this cool plane. I was wondering if this motor would be OK as I have it on hand from a downed GP DR1:
Rimfire 28-30-950 Brshlss Mtr
Diameter:
30 mmLength:
950 rpmRPM/V (Kv):
54 gWeight:
7.4 - 14.8 VInput Voltage:
14 AMax Consant Current:
20 AMax Surge Current:
155 WMax Constant Watts:
.7 ANo Load Current:
9x3.5S - 12x6SProp Range:
3 mmShaft Diameter:
I have the esc and prop combo for this set up so would be good but not sure if enough power for this plane on a 1300mah 3s lipo.
Cheers.
STO is offline Find More Posts by STO
Old Aug 13, 2012, 03:28 PM
RWData is offline
Find More Posts by RWData
PowerTower
RWData's Avatar
United Kingdom, England, Bristol
Joined Aug 2009
Mo, that's a classy paint job Sure to turn heads when you fly her.
If you can, get some video too, shaping up to be the best looker I have seen
RWData is offline Find More Posts by RWData
Old Aug 13, 2012, 04:19 PM
Reap the wild wind
Bristol,UK
Joined Feb 2007
STO
I would imagine that motor would fly a Funbat but I prefer a higher kv motor so I can run something in the 6 - 7" prop size. At least it has a built in prop saver which should help prevent prop breakages on landing. All mine have had 1800 kv or higher motors.
Andy
Old Aug 13, 2012, 05:47 PM
STO is offline
STO
STO
STO's Avatar
Ontario, Canada
Joined Jul 2005
STO
Andy
Thanks, Headless. I will probably look at getting something from HK. A friend is using a 2408-21T brushless tower pro motor with a 40 amp speed control on 2200 mah 3s lipo.
Sure looks like a fun plane.
Old Aug 14, 2012, 03:24 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Well if you are shopping at HK then why not go for the Funfighter motor at $9.99 http://www.hobbyking.com/hobbyking/s...dProduct=24497. Similar weight to the 2408-21T and I'm getting over 10 mins of mixed flying on a 1300 nano-tech 45-90 c 3S pack http://www.hobbyking.com/hobbyking/s...dProduct=18207. Or you could go for the parkjet standard motor http://www.hobbyking.com/hobbyking/s...dProduct=24239 which is available from the US warehouse. Go for a 6x5 or maybe a 7x4 prop with this one along with a 40 amp esc to give you some headroom but as always check out the numbers by using a wattmeter.
My FB is using a 7x5 prop and this 1800kv motor on his Funbat http://www.targethobby.com/hb2822-rc...p-4161589.html from Target Hobby. A lighter set up with around 20 amp esc and 3S 1000 mAh pack
I doubt you would have enough room for a 2200 mAh pack and even if you did, the weight would hurt the performance.
Andy
Old Aug 18, 2012, 05:07 AM
RWData is offline
PowerTower
RWData's Avatar
Joined Aug 2009
Headless, a class act again I see
I can brag to all the RCG followers that you are my FB who got me into RC flying, and from where I get my model inspiration from
So, has the extra vertical stab worked for you ?
Aren't I the person you expect something 'whacky' from, then surprised how well it flies
I particularly like the underside cooling vent idea, nice touch
Old Aug 18, 2012, 06:44 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
She tracks well and roll very axially so, yes, the large central fin isn't hurting performance. Hey, don't blame me for you vivid model imagination. Who could forget your 3mm correx flying wing
Andy
Old Aug 18, 2012, 04:41 PM
RWData is offline
PowerTower
RWData's Avatar
Joined Aug 2009
Hmmm, yes..... put that one at the back then hehe !
Mo, are you in the air with yours yet ?
I'm hoping to get out myself very soon, funbat will need to go, but a number of other recent builds are up for maiden too
Old Aug 18, 2012, 06:44 PM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
Still not in the air. Picnic moved to tomorrow due to the weather and I have to work.
Old Aug 18, 2012, 08:31 PM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
WAAY OFF topic but since I was picked to help make kits available to you guys
I figure you should be appraised of my situation.
I got NEWS today !!! ( at least for me )
I got an acceptable OFFER for my home in the Northwest.
I will be moving in a month, to Indiana. ( near the Grand kids )
So, if you are on the fence about any of my stuff,
ya better make a decision NOW !
NOTICE:
Northwest Cutout Service is MOVING !
We will be moving to the Indianapolis area at the end of September,
close to the Grand Kids.
All orders received BEFORE September 7 will be honored
depending on stock availability.
However, all operations will be closed at that time.
We intend to reopen as soon as possible after relocation.
We very much appreciate all the business you have afforded us,
Thank you very much.
When we reopen we will make an announcement here as well as RCGroups.
Best regards
Bob
birdofplay is online now Find More Posts by birdofplay
For Sale Ace Simple Corsair, GP combat Mustang, .40 trainer LoneRanger Aircraft - Fuel - Airplanes (FS/W) 4 Nov 07, 2010 12:27 PM
Discussion BoxFly Simple Foamboard plane good for windy days with video & plans propjobbill Foamies (Scratchbuilt) 16 Nov 01, 2010 10:18 AM
Discussion Simple 3D balsa plane chulian1819 3D Flying 0 Oct 13, 2010 10:26 AM
For Sale NIB J&C Funbat -combat aircraft kit - $15 shipped JBFergus Aircraft - Fuel - Airplanes (FS/W) 0 Dec 05, 2008 05:07 PM
Can I slope this kind of plane? WM combat plane or ACE simple 400?? Magna Slope 3 Oct 20, 2003 10:27 PM
