Old Jul 11, 2012, 05:23 PM
mvaller00 is offline
Find More Posts by mvaller00
mvaller00's Avatar
Joined Apr 2011
So quick question (if you don't mind).... it's a 1650kv motor, why so little thrust where other motors with less or similar kv put out more thrust? Just a bit confused?
mvaller00 is offline Find More Posts by mvaller00
Old Jul 12, 2012, 01:06 AM
headlessagain is online now
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Size matters The larger the motor, the more wire in the windings and the more amps it can pull. Think in terms of a 50cc scooter engine and 600cc motorbike engine both spinning at 5000 rpm. Much more power output from the larger unit.
Andy
headlessagain is online now Find More Posts by headlessagain
Old Jul 12, 2012, 02:09 PM
chris1379 is offline
Find More Posts by chris1379
chris1379's Avatar
United States, OH, Eaton
Joined May 2006
I'll try to find a link later but the kv rating of a motor is rpm per volt with no load. When you load the motor with a prop a bigger motor will be able to turn it faster, drawing more power and delivering more thrust. The kv rating is good for comparing motors of the same size. If 2 motors are the same size and type with different kv ratings, the lower one will deliver more thrust while the higher one will give more speed. You can think of it like gears in a car to an extent. As a matter of fact, a gearbox can make different kv motors nearly equal but it's usually not practical for our small planes. Maybe this will help.
http://www.brushlessrcmotor.com/brus...motor-ratings/
chris1379 is offline Find More Posts by chris1379
Old Jul 16, 2012, 06:22 PM
Mopower71 is offline
Find More Posts by Mopower71
Corsir Crasher
Mopower71's Avatar
United States, NY, Poughkeepsie
Joined Oct 2011
Can someone give me recommendations on motor,esc and props from headsuprc that will haul this around nicely? That are in stock, and not to expensive.
http://www.headsuprc.com
I did order stuff from another place, but it is shipping from Hong Kong, and I don't think it will be here in time for final assembly and a little practice before the combat at my club.
Heads up is in Fla, and ships same or next day.
Mopower71 is offline Find More Posts by Mopower71
Old Jul 16, 2012, 06:40 PM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
How many oz of thrust is required?
Old Jul 17, 2012, 01:10 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
How about these motors
http://www.headsuprc.com/servlet/the...h-16%29/Detail or for a bit more punch (and weight) http://www.headsuprc.com/servlet/the...h-19%29/Detail
Andy
Old Jul 22, 2012, 04:40 AM
1101 is offline
Find More Posts by 1101
New Zealand, Auckland
Joined Dec 2008
where & how to mount batt + esc
Hi guys, Ive finished my funbat, I'm a bit unsure of the best place to mount the lipo & esc.
And the best way to mound the Lipo, velcro ??. I allways have issues getting vecro to stick to foam
The build was a bit rough, being my 1st DIY depron build.
Can the funbat be scaled up in size?(bigger) Does everything just scale up proportionally or would say length or tail need to be scaled up more ??
Cheers
Steve
1101 is offline Find More Posts by 1101
Old Jul 22, 2012, 09:28 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Hi 1101
I prime depron with UHU Por and let the glue get tacky prior to slapping on the velcro. I find velcro is all I need to hold up to 1550 3s packs in place. When I built my Maxi Bat I just scaled everything up but I find the regular version much nicer to fly. I'm planning on something in the 700-750mm wingspan size so I can fit a spare HK Funfighter motor and run her on 4s. Should be good for 90 mph
Andy
Old Jul 22, 2012, 11:09 AM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
LowDePo both have INdustrial Strength Velcro - in Two Colors Black andf WHite
It's 2" wide and Sticks like crazy !
I think it was ~$8 for a meter of the stuff and I LIKE IT !
Cheapo Velcros from JoAnnes doesnt even come close to STICKING POWER !
Both on the back as well as the hook/loop side.
No extra or alternate glue necessary.
Bob
Northwest Cutout Service
birdofplay is online now Find More Posts by birdofplay
Old Jul 27, 2012, 03:55 AM
1101 is offline
Joined Dec 2008
Hi guys, I just weighed my bat, almost 500g without battery.Obviously too heavy
Is that going to be unflyable ??
I left all the paper on the foam, 6mm art-shop foam sheet (all I can get really)
If I make another, how do I get the paper off the foam, can I use thinner foam?? should I use EPP for some parts (the tail)??
cheers
Old Jul 27, 2012, 10:48 AM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Depron - RCFOAM.COM
Model Plane Foam - http://www.modelplanefoam.com/
Cut Kits - http://www.balsabuddies.com/cutouts/Listing.htm
Or soak the paper off with water or rubbing alchohol
Old Jul 29, 2012, 04:47 AM
lemuel is offline
Find More Posts by lemuel
Australia, QLD, Brighton
Joined Sep 2006
hello everyone, finally had a nice day where I got the chance to try a vertical take off. My tip for vertical take off is FULL THROTTLE INSTANTLY and everything else takes car of itself. Here is a video of the take off.
rc funbat vertical take off (0 min 31 sec)
regards
Matthew
lemuel is offline Find More Posts by lemuel
Old Jul 30, 2012, 05:49 AM
msev is offline
Find More Posts by msev
Joined Sep 2010
Someone should try building a pusher version just to see how would it fly
msev is offline Find More Posts by msev
Old Jul 30, 2012, 09:39 AM
OutcastZeroOne is offline
Find More Posts by OutcastZeroOne
"Fly, yes... Land, No"
OutcastZeroOne's Avatar
United States, CA, Santa Cruz
Joined May 2005
I came up with a pusher bassed off of the Funbat
Wind Fighter
Flys very smooth and easily too.
OutcastZeroOne is offline Find More Posts by OutcastZeroOne
Old Jul 30, 2012, 01:21 PM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
My FunBat is getting closer to being finished.
For Sale Ace Simple Corsair, GP combat Mustang, .40 trainer LoneRanger Aircraft - Fuel - Airplanes (FS/W) 4 Nov 07, 2010 12:27 PM
Discussion BoxFly Simple Foamboard plane good for windy days with video & plans propjobbill Foamies (Scratchbuilt) 16 Nov 01, 2010 10:18 AM
Discussion Simple 3D balsa plane chulian1819 3D Flying 0 Oct 13, 2010 10:26 AM
For Sale NIB J&C Funbat -combat aircraft kit - $15 shipped JBFergus Aircraft - Fuel - Airplanes (FS/W) 0 Dec 05, 2008 05:07 PM
Can I slope this kind of plane? WM combat plane or ACE simple 400?? Magna Slope 3 Oct 20, 2003 10:27 PM
