Old Jun 26, 2012, 09:17 AM
lemuel is offline
Find More Posts by lemuel
Australia, QLD, Brighton
Joined Sep 2006
Originally Posted by chris1379 View Post
No combat for me either. I like the plane too much. Lemuel, it sounds like your light version is a great flier. I do get the tail wobble you're talking about in crosswinds. It was a little scary the first time it happened.
I weighed my plane and it was 155 grams without battery. The 1000mah battery weighs 75grams so I guess the final weight is in the 230's? I really want to take some video of it but I don't have any helpers at the moment and it is raining cats and dogs here at the moment.
lemuel is offline Find More Posts by lemuel
Old Jun 28, 2012, 12:54 AM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
For solo video, you could try a #16 key cam mounted on a baseball hat peak. Here is the thread, just read the 1st 5 posts initially.
http://www.rcgroups.com/forums/showt...1556994&pp=100
Andy
headlessagain is offline Find More Posts by headlessagain
Old Jun 30, 2012, 12:11 AM
lemuel is offline
Joined Sep 2006
Andy
cheers for that. I had an opportunity to get some help to film me. Turns out he made need to find a new job other than a camera man..
funbat rc depron model Brisbane (1 min 20 sec)
not the best video but you get the idea.
Old Jul 02, 2012, 02:10 AM
1101 is offline
Find More Posts by 1101
New Zealand, Auckland
Joined Dec 2008
Hi guys
Ive downloaded the plan, started buying parts.
Ive a few questions
What thickness depron do I need.
Depron not EPP ??
I presume I need to use foam safe glue .
Are there any build vids for the funbat ??
Cheers
1101 is offline Find More Posts by 1101
Old Jul 02, 2012, 02:29 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
Originally Posted by 1101 View Post
Hi guys
Ive a few questions
Depron not EPP ??
Cheers
3mm depron or 5mm.I'm going to use 5mm.yes foam safe CA or UHU Por works well.
chop stiX is offline Find More Posts by chop stiX
Old Jul 02, 2012, 02:42 AM
lemuel is offline
Joined Sep 2006
I could only get 6mm depron. But mine seems to fly great. I also used Titebond on my depron models and it seems to hold up well. I also used extreme packing tape on the leading edge for protection..
Old Jul 02, 2012, 03:11 AM
chop stiX's Avatar
Joined May 2011
that's perfect
Old Jul 02, 2012, 12:57 PM
Mopower71 is offline
Find More Posts by Mopower71
Corsir Crasher
Mopower71's Avatar
United States, NY, Poughkeepsie
Joined Oct 2011
How do you fold the front of the wing over?
I cut the section out at an angle, but it only folds half way.
Should I flip it over and fold it with the cut side out?
Mopower71 is offline Find More Posts by Mopower71
Old Jul 02, 2012, 01:02 PM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
Or do I need to just take more foam out of the groove, so just the paper is in the section under the dotted lines?
I am using the Dollar Tree foam.
This is my first attempt at building a plane.
Old Jul 02, 2012, 02:37 PM
WombatControl is offline
Find More Posts by WombatControl
WombatControl's Avatar
Joined Jul 2011
What you want to do is cut from the dotted line towards the solid line at a 45-degree angle so that you form a V shaped cut in the foam. When you lift up the top step to 90 degress the foam should come together at a right angle. Then you fold the step past 90 degrees and you should get a nice curved edge.
It can be tricky to get right, especially if you cut through the paper or the paper tears. You might want to practice it with some extra scrap pieces to get the technique down.
The other way is to just cut the step out, glue it on and then sand both edges down to a rounded shape. Either way will work.
WombatControl is offline Find More Posts by WombatControl
Old Jul 02, 2012, 02:51 PM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
thanks Wombat.
I couldn't wait so i took the foam out under the lines and folded it over.
Slight curve to the nose.
I was afraid to force it past the 90deg spot, because I figured the paper would let go or the foam would break.
I'll cut another fuselage and give it a try.
Old Jul 02, 2012, 02:52 PM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
Another question.
Carbon fiber, or wood dowel for the spar, or does it matter?
Old Jul 02, 2012, 02:58 PM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
And for a motor, this wouldn't work would it? Probably way to big.
Park 480- KV1250
35 mm 36 mm
kv1250
Constant watts500,
Burst watts655
Wt 116g
Shaft Dia. 4mm
Voltage range 11.1-14.8V /
3-4S LiPo
40A Minimium esc
Prop.9x5 , 10x4, 11 x 4
I might strip the motor out of my ArtTech Corsair.
Old Jul 02, 2012, 03:08 PM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
For a LARGER version Maybe !
Thats is a serious motor !
Bob
birdofplay is online now Find More Posts by birdofplay
Old Jul 02, 2012, 03:20 PM
Corsir Crasher
Mopower71's Avatar
Joined Oct 2011
Quick picture of where it's at
For Sale Ace Simple Corsair, GP combat Mustang, .40 trainer LoneRanger Aircraft - Fuel - Airplanes (FS/W) 4 Nov 07, 2010 12:27 PM
Discussion BoxFly Simple Foamboard plane good for windy days with video & plans propjobbill Foamies (Scratchbuilt) 16 Nov 01, 2010 10:18 AM
Discussion Simple 3D balsa plane chulian1819 3D Flying 0 Oct 13, 2010 10:26 AM
For Sale NIB J&C Funbat -combat aircraft kit - $15 shipped JBFergus Aircraft - Fuel - Airplanes (FS/W) 0 Dec 05, 2008 05:07 PM
Can I slope this kind of plane? WM combat plane or ACE simple 400?? Magna Slope 3 Oct 20, 2003 10:27 PM
