Old Dec 17, 2011, 08:24 PM
Nicoflyer is offline
Find More Posts by Nicoflyer
Pushing the envelope
Nicoflyer's Avatar
Valatie, N.Y.
Joined Jan 2006
Originally Posted by headlessagain View Post
I'd expect a 2200 kv motor to run a 7x3,6x4 or 6x5 prop on 3 cells. What prop are you running & have you hooked up a watt meter to test your set up.
Andy
I'm running a 8X4DD GWS. I'm away for the weekend, that was a quick flight before I left.
I'll do some testing on it when I get back. I'm thinking to go with a hotter motor because it can use the extra noise weight anyway.
Nicoflyer is offline Find More Posts by Nicoflyer
Old Dec 18, 2011, 02:34 AM
headlessagain is offline
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Nice one Don
I noticed your Spitfire vid on YouTube. Was that built from a plan and if so, is there a build thread anywhere?
Andy
headlessagain is offline Find More Posts by headlessagain
Old Dec 18, 2011, 05:51 PM
beemerdon is offline
Find More Posts by beemerdon
beemerdon
beemerdon's Avatar
USA, NC, Charlotte
Joined Nov 2009
Andy, I got the plans for the Spitfire from this site;
http://www.rcgroups.com/forums/showthread.php?t=1012551
but I couldn't fly it and the last time it crashed it broke into three peices so it's in Depron Heaven right now. I have flown some of the profile planes he has and they did great but I didn't use dihedral on the Spitfire, plus it was tail heavy, and I just couldn't get it to fly so I abandoned it.
The Funbat, or in my case the Stingbat (the Stingray is from Ken who does all the plans on the above link) flies great right off the drawing board. SO much more fun than the Spit.
Don
beemerdon is offline Find More Posts by beemerdon
Old Dec 18, 2011, 07:23 PM
badharley99 is offline
Find More Posts by badharley99
Joined Mar 2011
Hi,
is there a tiled plan for the stingbat so we can build at home.
Nick
badharley99 is offline Find More Posts by badharley99
Old Dec 18, 2011, 07:30 PM
chris1379 is offline
Find More Posts by chris1379
chris1379's Avatar
United States, OH, Eaton
Joined May 2006
Just remember a bigger motor will demand a bigger battery. Then it's a matter of what will fit.
Chris
chris1379 is offline Find More Posts by chris1379
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Download the latest Adobe Reader X ! It's free
It has a print tiling feature so you can just print full sized pdf plans.
which are here ...
http://www.rcgroups.com/forums/showp...&postcount=358
Bob
birdofplay is offline Find More Posts by birdofplay
Old Dec 19, 2011, 01:06 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Thanks for the link Don. Perhaps I'll stick with the Funbat for now
Andy
Old Dec 19, 2011, 09:22 AM
Nicoflyer's Avatar
Valatie, N.Y.
Joined Jan 2006
I reconstructed the noise to accommodate a larger motor and lipo(2100mah).
I'm going from 100 watts to 250 watts!! Should be interesting,I should have a video on the V2 FunBat by tomorrow. I'll also post pics of the redo.
Old Dec 19, 2011, 07:21 PM
chris1379's Avatar
Joined May 2006
Is everyone else using blind nuts to mount the motor or will small wood screws work?
Old Dec 19, 2011, 09:28 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
For this small model I'd use those swell Caphead wood screws with the washer built in .
The guy that sells bulk has em. and lots of other hardware.
Bob
PS they have blind nuts too - lots of sizes !
Old Dec 19, 2011, 09:30 PM
beemerdon
beemerdon's Avatar
USA, NC, Charlotte
Joined Nov 2009
Small wood screws, or even some servo screws, will do just fine. I am using the blind nuts that came with Jon's firewall mount and I like them. Either is good.
Don
Old Dec 19, 2011, 11:43 PM
Wormboy is online now
Find More Posts by Wormboy
Wormboy's Avatar
Australia, WA, Madeley
Joined Jul 2011
Servo screws are working well enough for me as well. No sign of movement yet.
Wormboy is online now Find More Posts by Wormboy
Old Dec 20, 2011, 02:35 AM
mysteroius is offline
Find More Posts by mysteroius
Australia, QLD, Brisbane
Joined Dec 2011
Thanks Mic
Great Model. I have only flown it in +15knot winds so far and it flies great.
Flying Weight - 16 oz
CG - approx 2' 1/4" aft of LE.
5mm Foam Board
Carbon/Aluminum arrow shaft leading edge spar.
HXT900 servos
Turnigy 2209 1130kv swinging a 8x6 sport prop
25A ESC 2A BEC.
1300Mah 3S.
Not to quick and extremely maneuverable. Perfect for cutting streamers.
Very docile stall but does not glide to well.
A fantastic result for 2 evenings work. Thanks Mick
mysteroius is offline Find More Posts by mysteroius
Old Dec 20, 2011, 08:19 AM
Nicoflyer's Avatar
Valatie, N.Y.
Joined Jan 2006
Well I flew it this morning and all did not go well.
The motor quit and I had no control and the plane went in and it went in hard! As bad as it may seam I was lucky because it crashed about 15' from me.
When I would go to full throttle the motor seamed to only get upto 3/4 throttle and pulse on and off?
When I bench tested the motor it was at about 23 amps and I had a C.C 25 amp ESC.
The only thing I did different from the bench to the flight was that I had new Nano Tech lipos 25-50 c and there were higher c rating which could of put it over the 25 amps limit of the ESC and also it didn't have good air flow over the ESC.
I'll build a new one this weekend with a 45 amp ESC and that should fix things!
I can't get over how well the plane took the impact! It was all intact just had stress cracks.I just find it easier to build a new one.
Will post a video later have to go to work.
For Sale Ace Simple Corsair, GP combat Mustang, .40 trainer LoneRanger Aircraft - Fuel - Airplanes (FS/W) 4 Nov 07, 2010 12:27 PM
Discussion BoxFly Simple Foamboard plane good for windy days with video & plans propjobbill Foamies (Scratchbuilt) 16 Nov 01, 2010 10:18 AM
Discussion Simple 3D balsa plane chulian1819 3D Flying 0 Oct 13, 2010 10:26 AM
For Sale NIB J&C Funbat -combat aircraft kit - $15 shipped JBFergus Aircraft - Fuel - Airplanes (FS/W) 0 Dec 05, 2008 05:07 PM
Can I slope this kind of plane? WM combat plane or ACE simple 400?? Magna Slope 3 Oct 20, 2003 10:27 PM
