http://www.youtube.com/watch?feature...&v=Mx9XBsZK2ys I used UHU Por (Creative) for my build but the cartwheel just prior to the video must have broken the bond sufficient to cause the structural failure. I have since inserted a 6mm depron piece between the fuse and wing to increase the surface area and ran a thin bead of hot glue between the fuse and wing. Andy |
That one caught me by surprise ! wow
You must not have enough rubberbands holding your wing on !!! Kidding :-) .... These plastics seem to hold the glue well MOST of the time but certain situations tend to loosen the stuff. Especially water based glues that tend to shrink after time. My original Sea Dart build literally fell apart. Bob |
1800kv Himodel + 7x5 prop + 1300mah 3S
Same set up as Wormboy ( well he did follow my recommendation
) on mine apart from a 3 cell 1000 mah pack. This is the newer version from my UK mail order supplier http://www.giantcod.co.uk/a220812-18...-p-405608.htmlI really rate this set up for the standard size version. It really rips and vertical is unlimited. Just look back over my Funbat/Clearview sim hybrid video posted earlier in this thread Andy |
Nico, that's a gorgeous plane!
Here's mine. I combined the Stingray wing from Ken with the standard FB wing so I have a 32" span and a longer nose on it. I'm using a 2212-10 with a 1300 3s and it balances right in front of the spar. I raised the motor a half inch and built in some 'down' and added a washer of 'right' under the motor x-mount. Hope to maiden it in a few days--it was 64 here this afternoon! Bob, you can see I just cut a half inch strip of Depron and glued it to the fromt of the fuse between the firewall and the leading edge of the wing and then put on a white Depron 'cap' over the top. My receiver is in the fuse under the wing. Don |
Chris |
Chris1379:
I've purchased from this guy ... http://www.rchotdeals.com/Products/r...otor_home.html Beemerdon: OK ~ 1/2" added to the top ! Then a cover on that. Plus the Angle down Any Right thrust ? Let me retouch the drawings and get back to you Bob |
Bob, for right thrust I just put a washer under the two legs of the left sides of the motor's x-mount. It's just enough that you can tell it's there but not as much as the PZ Corsair or T-28. Can't wait to see how it flies with this huge wing! Oh, one pound, 475 grams all up with a 1300 3s battery.
Don |
It took a lot of effort and CAD time, But I have it done.
The StingBat at 30" span fits on 1 1/2 sheets of 13 x 39 depron. So I can "DO" it for the same price as the original FunBat. Here are the Parts in pdf. I will add this to my web site tomorrow too. Hey Beemerdon ?? Would you Mind if I use one of YOUR pix for an example on my page ? Enjoy Bob |
Bob, sure, use the photos and I can send another if you need it. I am talking this up to my guys here in Charlotte. We have been looking for a combat plane and tried the one that's 48" span but it was just a large plank. I think this looks better and will be more fun.
I think by extending the leading edge forward, and then adding a little more for the nose, I was able to solve the tail-heavy problem some of the early versions seemed to have. Don |
Thank You !! I think I'll need to modify my FB.It need over an oz added to the noise to balance out.If thats the case I'll switch out the Little Screamer for a speed Microdan motor and go from 800mah lipo to a 1300mah lipo. I guess I'll be putting this airframe to it never exceed stress test.
| Thread Tools | |
| For Sale Ace Simple Corsair, GP combat Mustang, .40 trainer | LoneRanger | Aircraft - Fuel - Airplanes (FS/W) | 4 | Nov 07, 2010 12:27 PM |
| Discussion BoxFly Simple Foamboard plane good for windy days with video & plans | propjobbill | Foamies (Scratchbuilt) | 16 | Nov 01, 2010 10:18 AM |
| Discussion Simple 3D balsa plane | chulian1819 | 3D Flying | 0 | Oct 13, 2010 10:26 AM |
| For Sale NIB J&C Funbat -combat aircraft kit - $15 shipped | JBFergus | Aircraft - Fuel - Airplanes (FS/W) | 0 | Dec 05, 2008 05:07 PM |
| Can I slope this kind of plane? WM combat plane or ACE simple 400?? | Magna | Slope | 3 | Oct 20, 2003 10:27 PM |
