Old Nov 03, 2011, 01:55 AM
headlessagain is online now
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Adobe 10 and PosteRazor can tile full size pdf's and both are free. I didn't bother with either as it's all straight lines. I just drew the wing panel and fuse on some flip chart paper and cut through to the depron
Andy
headlessagain is online now Find More Posts by headlessagain
Old Nov 05, 2011, 05:00 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Swapped out the motor and now no high amp draw issues. Still need to test fly so whilst waiting for the opportunity I thought I'd tart her up a bit. Bat decal was a free clip art, in outline only, which I enlarged with PosteRazor and then transferred to the paper backing of sticky back plastic.
Andy
Old Nov 05, 2011, 08:13 AM
chris1379 is offline
Find More Posts by chris1379
chris1379's Avatar
United States, OH, Eaton
Joined May 2006
Andy
Nice! I don't quite understand how you did the bat I like it. Is it actually black plastic or is it printed?
Chris
chris1379 is offline Find More Posts by chris1379
Old Nov 05, 2011, 01:00 PM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Hi Chris
I just used the outline clip art from this site
http://www.clker.com/clipart-10053.html then drew around the scaled up image onto the paper backing on self adhesive plastic. For the eyes I just cut the slits and stuck red packing tape underneath
Fablon is the popular brand in the UK and it's sold on a roll & comes in lots of different patterns -woodgrain, pebbles, zebra etc . Here are some listings on the USA Ebay site but most seem to be UK based
http://www.ebay.com/sch/i.html?_from...All-Categories. Perhaps there is an American brand that's available through Home Depot etc
Andy
Old Nov 07, 2011, 05:23 PM
RedTwilight is offline
Find More Posts by RedTwilight
Cobra Driver
RedTwilight's Avatar
United States, NC, Hurdle Mills
Joined Dec 2005
Just thought I'd post a pic of my Funbat. All that is left is to install the radio gear and trim and fly!
RedTwilight is offline Find More Posts by RedTwilight
Old Nov 07, 2011, 09:59 PM
Tsavah is offline
Find More Posts by Tsavah
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Gungnir?
Looks nice. Now I will have to look up that name; Gungnir, and see what it means. I am thinking Japanese cartoon series.
Tsavah is offline Find More Posts by Tsavah
Old Nov 08, 2011, 07:15 AM
Cobra Driver
Joined Dec 2005
Gungnir is the name of the Norse god Odin's spear. It is said that it never misses it's target. So I thought that would be an appropriate name for a combat plane.
Old Nov 12, 2011, 02:04 AM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
WOW, I just received an order for a 6 pack !
It looks like the popularity is rising for these once again.
I received shippment of 80 sheets today so I'm ready to roll.
Thanks for the support :-)guys
Bob
Northwest Cutout Service
birdofplay is online now Find More Posts by birdofplay
Old Nov 12, 2011, 05:58 AM
jhtitan is offline
Find More Posts by jhtitan
jhtitan's Avatar
Washington MO
Joined Jul 2008
Bob
WOO HOO!!!!!
Jon
jhtitan is offline Find More Posts by jhtitan
Old Nov 12, 2011, 06:33 AM
THESANDMAN is offline
Find More Posts by THESANDMAN
THESANDMAN's Avatar
United States, NY, New York
Joined Oct 2010
Bob
its a great flying plane. its ugly as hell but flies great , im planing on building one out of coroplas and installing some landing gear
THESANDMAN is offline Find More Posts by THESANDMAN
Old Nov 13, 2011, 12:12 AM
glydr is offline
Find More Posts by glydr
Next time I'll ARTF...
glydr's Avatar
Canberra, Australia (Southside)
Joined Feb 2004
Another funbat takes flight!
(eventually)
Funbat RC Plane Vertical Take Off (0 min 36 sec)
glydr is offline Find More Posts by glydr
Old Nov 13, 2011, 01:28 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
"Ugly as hell" I should watch your language or my bigun' might just come over there to help you re-appraise your opinion
Andy
Old Nov 13, 2011, 12:32 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
Um ???
I just acquired some Interesting new Foam.
It has a Hard plastic (styrene) Skin on EACH side, NOT PAPER, with foam in the middle.
I have 7 sheets 40 x 16" for initial trial experimentation.
I've tested it's "Cut-ability" on the CNC machine, OK .
It cuts nice and clean with a hobby knife.
Of course it's a little heavier but stronger too.
No tape should be needed for span wise strength.
I would expect it to hold up on combat hits a bit better.
It's kinda like coroplast except that
1. it's without the ugly corrugations and one direction bending
2. it's all styrene
Unfortunately it also cost me a bit more ( ~ $1.50 more per sheet )
I thought it might be Perfect for doing a 39" sized Funbat experiment.
I will have to re-size all the TABS and SLOTS to accommodate it's 5mm thickness
before cutting a trial.
I'm thinking that a Hybrid of Depron and THIS stuff
might be optimal. New foam on the Wing parts only and depron on the rest.
I'll get some pix up of the stuff later.
L8r
bob
Thoughts
Old Nov 13, 2011, 05:46 PM
xheli_d is offline
Find More Posts by xheli_d
Joined Nov 2007
What is this new foam called and where did you get it? I haven't seen anything like that in alabama
xheli_d is offline Find More Posts by xheli_d
Old Nov 13, 2011, 06:09 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
It's NOT in the stores.
It's usually cut into smaller ieces and used for photo mounting or for screen printing.
I had to go 75 miles to Portland to a specialty plastics place to even get some
cuz unless it's 4'x8' it has a lot of cutting costs built in.
I'm only experimenting with it as it's heavier and possibly not the best for
ordinary foamys.
I looked at the cutting layout again and it turned out that the fuse would be best
when cut from the stuff as well. I adjusted the slots and tabs to suit while in there.
That led to moving other parts and leaving only the Fins in regular Depron.
Let me think about it for a bit longer.
bob
For Sale Ace Simple Corsair, GP combat Mustang, .40 trainer LoneRanger Aircraft - Fuel - Airplanes (FS/W) 4 Nov 07, 2010 12:27 PM
Discussion BoxFly Simple Foamboard plane good for windy days with video & plans propjobbill Foamies (Scratchbuilt) 16 Nov 01, 2010 10:18 AM
Discussion Simple 3D balsa plane chulian1819 3D Flying 0 Oct 13, 2010 10:26 AM
For Sale NIB J&C Funbat -combat aircraft kit - $15 shipped JBFergus Aircraft - Fuel - Airplanes (FS/W) 0 Dec 05, 2008 05:07 PM
Can I slope this kind of plane? WM combat plane or ACE simple 400?? Magna Slope 3 Oct 20, 2003 10:27 PM
