Old Feb 06, 2011, 06:15 PM
jhtitan's Avatar
Washington MO
Joined Jul 2008
Funbat, Simple KFm2 Combat plane
Heres a link to plans for my FunBat. This is based off the Blue Funder with changes made to incorporate my build style and laser cut motor mount.
I built mine with a Micro Park Jet from Grayson and fly it with 2 servos on a 6x4 APC prop and a 1300 mAh 3s LiPo.
its capable of VTO and flew great.
Plans can be gotten here as well as CNC cut kits of this and a few other airframes.
http://bloodymicks.com/Plans/plans.html
I will post some pics of my next build when I get it going, which should be soon.
Jon
jhtitan is offline Find More Posts by jhtitan
Old Feb 09, 2011, 07:10 AM
jclassic1
New Houghton, Derbyshire, UK
Joined May 2006
Hi Jon,
just printed off the plans for the FunBat and plan to build it from 6mm depron.
I want to use a BW rewound 1500kv motor and 3 cell 1000mah lipo.
Will probably just use my normal Kfm2 airfoil with the two bits of foam stuck together with double sided tape.This one fits right into my ideal size for the field I fly from.Might be a bit fast for me but with the BW I can always go to 2 cell and a big prop for a bit more relaxed style of flying.
Keep you posted on my progress.
jclassic1 is offline Find More Posts by jclassic1
Old Feb 09, 2011, 07:25 AM
jhtitan's Avatar
Washington MO
Joined Jul 2008
jclassic1
Cool, This plane flew great, I have been wanting to try it without the spar myself. The motor I used was more for the nose weight so be prepared for it to be tail heavy with the small BW motor. I am anxious to see your build and hear a flight report or see a flight video.
its such a simple build. good luck with it and post some pics if possible.
Jon
Old Feb 09, 2011, 07:48 AM
jclassic1
Joined May 2006
Hi Jon ,if it is likely to come out tail heavy I may look at extending the nose a bit.Do you have your electrics installed inside the fuselage.
Plan went together great so now I am off to check how much foam I have left.
John
Old Feb 09, 2011, 08:32 AM
jhtitan's Avatar
Washington MO
Joined Jul 2008
on my prototype I installed the ESC on one side and the RX on the other and the battery in between them. just to get everything as far forward as possible. I few of my flyin buddies have built theirs with a little further aft CG than I did and they still flew good, but too far and it was very uncontrollable.
Plane weighs 15oz as I built mine and can handle a bit of extra weight if you need to add a little lead or something to get CG right.
Heads Up rc had a motor that was really inexpensive compared to the Micro Park Jet that I want to try. seemed to spec out close to the Micro in weight and thrust. not sure if your interested but heres a link anyway I am going to try this one soon.
http://www.headsuprc.com/servlet/the...ushless/Detail
should be a bit slower and plenty of thrust for VTO's without going too big on a prop.
I have also considered adding a little length to the nose as well, if you go that route let me know how much you added and how it worked out.
Jon
Old Apr 27, 2011, 07:01 AM
It's just a plane.
ZackJones's Avatar
USA, SC, Goose Creek
Joined Aug 2010
Jon,
What do you think of this motor/esc combo: 2408-21-B Motor / ESC
ZackJones is offline Find More Posts by ZackJones
Old Apr 27, 2011, 07:38 AM
jhtitan's Avatar
Washington MO
Joined Jul 2008
that one should be fine, maybe not VTO but should fly great, My prototype (which I was flying til recently) had a micro park jet and I tested it with a 2212-06 both were way over kill on power.
post some pics of the build I would love to see them.
Jon
Old Apr 27, 2011, 07:58 AM
gatorlynch's Avatar
Coral Springs, FL
Joined Mar 2010
I plan on using a 2410-12D with a GWS 9X5.
http://www.headsuprc.com/servlet/the...lectric/Detail
Mine is being made out of 4mm coroplast - so it'll be heavier than its' foam brethren.
Tim
gatorlynch is offline Find More Posts by gatorlynch
Old Apr 27, 2011, 08:00 AM
jhtitan's Avatar
Washington MO
Joined Jul 2008
I have seen the foam version weigh anywhere from 9oz all the way up to over 17oz and they all flew great. I can't wait to see a coroplast version. which is funny cause I was just trying to figure out if I have enough signage laying around to make one
Jon
Old Apr 27, 2011, 04:01 PM
Team Ozo Parkflyers
rayrz's Avatar
Netherlands
Joined Nov 2010
Cg
hi there,
I build the funbat also....but i don't gettit how the CG is placed...
Where do you leave the battery? all the way in the front?
normaly the cg is 1/3 off the wing??? at the front.
please somebody...i do not get it right.
greeting ray
rayrz is offline Find More Posts by rayrz
Old Apr 27, 2011, 04:05 PM
jhtitan's Avatar
Washington MO
Joined Jul 2008
Originally Posted by rayrz View Post
hi there,
greeting ray
yea I mounted the battery in the nose although I will say the CG is pretty forgiving on this plane. still not sure how Chad, from Flight Test, got his battery that far back on his.
I have not played around with the CG much but one of the guys I fly with has his back about .5" or maybe a bit more than that from where I have it marked. His flew great as well.
Jon
Old Apr 28, 2011, 07:48 AM
Team Ozo Parkflyers
rayrz's Avatar
Netherlands
Joined Nov 2010
If you see the video from Flite-test good, then you see that the orange plane from Josh has a landing gear. I think then that the cg is in the back, instead the front.
De Green one is the normal one. 2 Servo's on the top. And i think also that the battery has to be in the front. i use 800mah 3s lipo. but my plane is still not good CG. is hanging backwards.
Somebody more idea??
greeting rAY
Picture's are following
Jon
Old Apr 28, 2011, 07:57 AM
jhtitan's Avatar
Washington MO
Joined Jul 2008
greeting rAY
How far back is your CG? I listed CG at 1.75" back from leading edge, this is right at the spar location marked on the plans. I do know it will fly at a little over 2" back, one of my test builders has a tendency to build tail heavy. he mounted both servos behind the step in the wing. With a 1300mAh 3s in the nose compartment his all fly great. It is a pretty forgiving plane.
The builds in the Flight test video did use lighter servos than I used as well as a smaller LiPo, 3s 500 mAh I use a 3s 1300-2200 mAh. At 27" WS it can handle a bit of extra weight so don't be afraid to add a little if you feel you need it to get CG.
I can't wait to see pics
Jon
Old Apr 28, 2011, 10:23 PM
John 3:16 Still Applies
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Very cool, simple plane Jon!
Did you ever try the EMAX CF2822 motor? I may build a couple of these and would like to keep the power system cost low, so that little Emax looks great if it's heavy/powerful enough...
Sammy70 is online now Find More Posts by Sammy70
Old Apr 28, 2011, 11:51 PM
The Ottoman Flyer
USA, TX, Galveston
Joined May 2010
After seeing the plane on Flight Test I decided to give it a try.
She looks nice given that this is my first ever plane build
Im using a 1780kv motor with a 7x3.5 prop build using dollar tree foam i will add a wooden dowel to reduce the wing droop when i get a chance and im waiting on my batts to come in to maiden her
Yall think the 7x3.5 prop will work on this plane ? as soon as i maiden her i will build a 2nd one and do some combat flying with a friend
Ottomite is offline Find More Posts by Ottomite
For Sale Ace Simple Corsair, GP combat Mustang, .40 trainer LoneRanger Aircraft - Fuel - Airplanes (FS/W) 4 Nov 07, 2010 12:27 PM
Discussion BoxFly Simple Foamboard plane good for windy days with video & plans propjobbill Foamies (Scratchbuilt) 16 Nov 01, 2010 10:18 AM
Discussion Simple 3D balsa plane chulian1819 3D Flying 0 Oct 13, 2010 10:26 AM
For Sale NIB J&C Funbat -combat aircraft kit - $15 shipped JBFergus Aircraft - Fuel - Airplanes (FS/W) 0 Dec 05, 2008 05:07 PM
Can I slope this kind of plane? WM combat plane or ACE simple 400?? Magna Slope 3 Oct 20, 2003 10:27 PM
