Old Feb 06, 2011, 10:28 AM
basha53 is offline
Find More Posts by basha53
basha53's Avatar
Bethlehem, Pa
Joined Jun 2004
Build Log
Profile B-58 Hustler from "burkefj plans"
I was looking thru the "pusher plans" thread and came accross the B-58. This has always been on of my favorite planes. I got to see 2 of them in person, one a Chanut AFB and the other at the AF museum at W-P AFB.
So I had to do one. Down loaded the plans from POST #158 and set down to piece them together. Next sit down and start cutting out plams. I found some 10 mm depron at Hobby Lobby store and the plans called for 6 mm for the fuse and wings. I figured I go with the 10mm for everything.
basha53 is offline Find More Posts by basha53
Old Feb 06, 2011, 07:41 PM
basha53 is offline
basha53's Avatar
Bethlehem, Pa
Joined Jun 2004
More work done
I was able to get all the parts cut up and together. I ran a bunch more carbon rod in the fuselage than what was on the plans. Weighed up all the foam parts and came out to about 14 oz.. I plan to us a LSSPJ and 3s/2200mah battery. I dont know the scale for this plane, I want to get decals from CALI GRAPHICS to dress her up.
Gary
Old Feb 06, 2011, 11:24 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
One of my favorite jets as well. I'll get to see the one at W/P AFB again in a couple of weeks--can't wait
Best of luck on your jet...
Sammy70 is offline Find More Posts by Sammy70
Old Feb 08, 2011, 09:28 PM
basha53 is offline
basha53's Avatar
Bethlehem, Pa
Joined Jun 2004
In holding pattern
No more building for a little while. Mother in law in Hospice and have to take care of family for now.
Gary
Old Feb 08, 2011, 10:52 PM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Gary
Very sorry to hear that Gary.
Take care during this difficult time....
Old Feb 11, 2011, 07:50 AM
basha53 is offline
basha53's Avatar
Bethlehem, Pa
Joined Jun 2004
Thanks Sammy, She passed on yesterday. Very hard on wife, we have her dad staying with us for now.
I got the decals ordered from Callie. I will try to get down to the basement today to get her all put together.
Gary
Old Feb 11, 2011, 11:57 AM
byrocat is offline
Find More Posts by byrocat
byrocat's Avatar
Aurora, Ontario, Canada
Joined Mar 2002
Family's a priority, period. If it takes a couple/three weeks to get everything related to your Mom taken care of, no one is going to complain about lack of progress.
byrocat is offline Find More Posts by byrocat
Old Feb 12, 2011, 07:46 AM
basha53 is offline
basha53's Avatar
Bethlehem, Pa
Joined Jun 2004
Some progress
Thanks byrocat, your right, family first.
I was able to get some time to work on the B-58. Wife spent some time with her daughters.
Glued the wing to the body using white Gorilla glue and a little CA. I got sloppy and didn't look at the verticle stab and when I did finally check I saw that it is a tad out. I my try a little heat at the stab to get it closer to perpendicular. Next i glued the engines onto the wing. Love that shape.
Thats all the time that I had to play. Next I will cut out the control surfaces and due up the motor mount. With the wing at 10mm I was wondering if I should taper the trailing edge or just leave it at 10mm. Any thoughts?
Gary
Old Feb 14, 2011, 04:24 PM
basha53 is offline
basha53's Avatar
Bethlehem, Pa
Joined Jun 2004
A little more progress
Was able to get some time on the B-58 today. Got the motor mount glued up. Cut out the control surfaces and got one side mounted up. I added a couple of details that I saw on one of the B-58 pic's, adds a litted detail.
Old Feb 14, 2011, 07:56 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Leave flat.
At our speeds, flat 10 mm is stronger. Less nicks also.
cyclops2 is offline Find More Posts by cyclops2
Old Feb 15, 2011, 02:02 PM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
For a trailing edge, there is really no great risk of nicks. I'd taper it and only taper the bottom so that you are adding a little bit of reflex in the wing (the way Convair did the real B-58).
alexandermh is offline Find More Posts by alexandermh
Old Feb 23, 2011, 07:51 PM
basha53 is offline
basha53's Avatar
Bethlehem, Pa
Joined Jun 2004
I was able to paint the '58 yesterday, My paint booth is my 1/2 bath with exhaust fan. I used Testors Metalic Silver for overall and have some Craft paint Gun metal gray which I used on the nacells and elevons. I will get to do some more painting tomorrow. I need to finish up the windscreens. I have my decals in from CALIE Graphics, so all I have to do is finish painting.
Gary
Old Feb 26, 2011, 11:06 PM
basha53 is offline
basha53's Avatar
Bethlehem, Pa
Joined Jun 2004
Paint and Decals
I got a little more painting and some decals applied. The decals are from CALIE Graphics. I want to spray the plane with Minwax WBPU clear to seal off the decals and paint.
Gary
Cool New B-58 Hustler Profile SGTalon Foamies (Scratchbuilt) 56 Nov 14, 2013 01:22 PM
Discussion 49" profile B-58 hustler burkefj Pusher Prop Jet Models 69 Oct 30, 2013 05:29 PM
Discussion B-58 hustler plans???? maverick pro Electric Ducted Fan Jet Talk 7 May 06, 2009 12:14 AM
B-58 Hustler plans? vise101 Electric Ducted Fan Jet Talk 2 Oct 01, 2004 10:55 PM
B-58 Hustler project gutboy17 Electric Ducted Fan Jet Talk 34 Feb 19, 2004 06:03 PM
