Old Feb 05, 2011, 04:25 PM
Broken wing 31 is offline
Find More Posts by Broken wing 31
Crashing aircraft since 1975
Broken wing 31's Avatar
United States, PA, Hookstown
Joined Dec 2008
Harbor freight P-51 Mustang converted to P-82 twin Mustang
I have been flying the Harbor Freight P-51 Mustang for a couple years now and had always thought that this kit would make an excellent candidate for a kit bashed P-82/F-82 twin Mustang. I finally decided to do this build when I received some EPO foam used as packing material. I started buy web searching the P-82 in order to get a good 3 view, when I figured out the wing loading and realized that the wing for the P-51 that I was using for this application was flawed, it had way more wing loading than the outside wings of the P-82. Due to the famous shape of the P-51's LE, there was more wing area on the straight LE of the P-82. I had to make up for this shortcoming by adding wing area to the center section, the horizontal stabilizer area would fallow suit. Having figured out the proper load it was on to the build. I cut the wing in half right at the center of the servo pocket then I did a rough carving of the center section from the EPO foam block.
Broken wing 31 is offline Find More Posts by Broken wing 31
Old Feb 05, 2011, 04:33 PM
Joined Dec 2008
link to photos
here is the link to the build photos as this thread is under construction, http://www.rcgroups.com/forums/showt...1#post17027011
Discussion Harbor Freight EPO Foam 4 channel P-51 Mustang...RTF $79.99..Flight report and Video modfly Electric Warbirds 1342 Jan 06, 2016 08:28 AM
Discussion Harbor Freight 4 ch P-51 Mustang Foamie kenstogie Foamies (Kits) 83 Jul 27, 2012 03:25 PM
Sold Harbor freight P-51 Beginner kino-schmid Aircraft - Electric - Airplanes (FS/W) 1 Jan 08, 2011 05:16 PM
Wanted Harbor Freight P-51 Mustang Wing flyinwalenda Aircraft - Electric - Airplanes (FS/W) 1 Mar 17, 2010 09:25 PM
Video Harbor Freight P-51 Mustang modfly Electric Plane Talk 2 Dec 30, 2008 04:00 PM
