This thread is privately moderated by bidule, who may elect to delete unwanted replies.
Old Mar 06, 2011, 01:35 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Looks nice JC ... intereresting design that split wing. MiG-15's re sweet fliers but don't make those turns too tight
Herb is offline Find More Posts by Herb
Old Mar 07, 2011, 10:17 PM
bidule is offline
Find More Posts by bidule
jean-claude Terrettaz
bidule's Avatar
Carp, Ontario, Canada
Joined Mar 2000
prepare duct tonight, I'm still waiting for nose retract
bidule is offline Find More Posts by bidule
Old Mar 09, 2011, 01:59 AM
MaHö is offline
Find More Posts by MaHö
MaHö's Avatar
Germany, BW, Stuttgart
Joined Dec 2001
Hi JC,
wou cool, looks good
Franks duct system and the flaps like mine perfect!!!!!
That will get a really nice plane you will love it.
regards Martin
MaHö is offline Find More Posts by MaHö
Old Mar 09, 2011, 03:46 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
Thank Martin,
I will use the split duct but I decide to make fiber glass ducts ( not balsa) . I already made two plugs for it.
Old Mar 11, 2011, 07:03 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
Frustration with front retract
I received my Spring Air reverse front retract, but I don't understand the reverse ?? look like regular. I was under the impression the retract Cylinder should be away fromthe strut After many try and hour of scratching my head I decide to do this way:http://www.jettechmodels.com/servlet...l-Metal/Detail
I will use the Spring Air in my F 35 project.
I finish the ducting and I 'm please with the result . This week end I will glue everything in place and ad carbon tow to the duct.
Old Mar 15, 2011, 10:09 AM
bidule is offline
bidule's Avatar
Joined Mar 2000
I'm not so happy because my duct and intake are not align , when I clamped the front I have to do some cosmetic "maquillage" EVERCOAT ...nothing change with my hobby
Old Mar 15, 2011, 04:05 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
few pictures, beautiful outside today, flew my little Mig 15 from hobby King and did play with big mig and prepare/filled Drakken for painting
Old Mar 20, 2011, 10:22 AM
bidule is offline
bidule's Avatar
Joined Mar 2000
Was busy this week with wood floor @ home but I did some work on the Mig.
I try to correct my alignment error on the intake but I have the feeling I have to live with that and more cautious next time
The wing half are glue solid and well align( yes) Check and recheck with incidence meter.
I fit the hatch , I reenforce the inside with more carbon fibre and a dowel in the front and next two BVM latch mechanism.
Old Mar 20, 2011, 09:37 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
Baking on the spring sun for the first time
Old Mar 25, 2011, 10:06 AM
bidule is offline
bidule's Avatar
Joined Mar 2000
Hello
Very happy with the electric retracts from Lander. They fit perfectly and I was able to solve the front retract . The strut for the main look scale and will make doors to cover the wheel, actuated with two small servos and a bell crank ...
I hope those retract will last , they look solid, so much more easy to install!
Next is the rudder, I connect the top and bottom with a carbon rod , a small tube in the tail to receive the rod , a clevisse in the middle and a hinge on the top. For control a pull pull cable , servo just above the fan
Old Mar 30, 2011, 07:18 AM
bidule is offline
bidule's Avatar
Joined Mar 2000
Ok, rudder is hooked and move very well with no force or hard point..very happy. I use direct rod instead of pull-pull.
I ad to made a balsa fairing for the non moving part in the middle. No finnish yet.
Next ix to fix the hatch with two pin at the front and two hatch latch ( BVM) @ the back.
Moving well . Next pilot cockpit and some panels lines on wing and primer.
I have to order decals .Chinese
Old Apr 02, 2011, 12:53 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Nice JC, I noticed you switched struts ... The split intake won't be visible when you paint it mat black.
You should have the MiG flying in no time Red tail chinese scheme ?
Old Apr 02, 2011, 01:05 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
Robbed the whole plane with wet sand paper # 400-800 .Ready for first coat of can tamya primer.
Old Apr 07, 2011, 12:13 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
Canopy is done, with pilot ... the front wheel is done with support for servo and Lander electric retract install. So far so good.
The plane will be painted with Chinese marking .
I still have to fit the main wheels doors. Two small servos for those and a cable/elastic for the front one.
Til next time
Old Apr 11, 2011, 06:48 AM
bidule is offline
bidule's Avatar
Joined Mar 2000
I spray the Mig with primer and find more spots to be fix and filled....
yesterday I burned rivets on top of the wing , stab and rudder.
hopfully today i will install the doors for main whells .i'm still waiting for doors sequencer and servos( HK)
I order the markings from Callie graphic ,very good price
For Sale Freewing? 30amp ESC from HL Mig-15 $15 shipped jmrust Aircraft - Electric - Power Systems (FS/W) 2 Mar 26, 2011 10:56 AM
Sold NIB Pavel Bosak Mig 15 MaHö Aircraft - Electric - Jets (FS/W) 2 Aug 11, 2010 01:54 AM
For Sale NIB Pavel Bosak Mig 15 MaHö Aircraft - Electric - Jets (FS/W) 2 Jan 22, 2009 10:45 AM
Discussion Anyone know where I can get a Model Builder plan A5A Vigilante #12791 by Pavel Bosak byrocat Scale Fuel Planes 1 May 10, 2006 05:07 PM
RCM/Pavel Bosak F-4 FOShowNoClass Fuel Jet Talk 0 Nov 03, 2003 02:51 PM
