This thread is privately moderated by bidule, who may elect to delete unwanted replies.
Old Feb 05, 2011, 01:39 PM
bidule is offline
Find More Posts by bidule
jean-claude Terrettaz
bidule's Avatar
Carp, Ontario, Canada
Joined Mar 2000
Build Log
Pavel Bosak Mig 15
Ok,
I got this half kit from a ezoner , directly from Germany. This was a IDF plane made around 10-15 years ago. I like the tick wing for big retract to land on grass. The intake will be ~ scale .
Fan is a TJ 100 , 10 S 5000 mah XPS , Springair retract , 4 servos in the wings
, 2 servos for the stabs i for steering and maybe 2 more for gear doors .
So far: a fix the fuse and wet sanded, glass the wing with .75 glass , and i'm presently making the plug for intake.
Ok : wing are glassed and mixture of red filler and acetone brushed to fill any pin holes.
Cut former for tail , finish glass -carbon intake for TJ100. Redo the front intake to have room for retract.
bidule is offline Find More Posts by bidule
Old Feb 12, 2011, 01:07 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Very nice JC !
I am red with envy that you were able to get a hold of this kit !!
So I suppose the kit does not come with any ducting ?
Looking forward to seeing lots of pictures of your build ... Have been lookimg forever for a nice MiG-15 kit ... the airworld one is just too big for edf.
Herb is offline Find More Posts by Herb
Old Feb 13, 2011, 04:36 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
Thank Herb,
No ducting. In a german forum Jet frank and Maho ( I got the Mig from him) did a great building thread:
http://www.rc-network.de/forum/showt...l-Bosak-Mig-15
Jet Frank did a split intake and I'm trying to do the same..not easy. So far so good. This way the model will look more scale and its room for the wheel in the front.
I'm not sure if i want to ad flap ,maybe.
Old Feb 15, 2011, 12:02 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
I made a simple spar with 1/16 plywood and hard mapple. The spar will be glue and I will ad carbon tow in the top.
The wing will be cut after @ the wing fence. The par will be cut @ the wing root.
Old Feb 17, 2011, 03:16 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
Not much today , I fill up the spar space with West Epoxy and laminate the gear mount with carbon fibre, and apply vacuum with my small CST pump.
Old Feb 18, 2011, 05:37 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Nice , where did you find those Eurokit struts ?
I like your iron weights, are they from the Titanic.
Old Feb 20, 2011, 08:57 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
You'r a funny guy Herb.... I have to admit I made a stupid mistake . I should cut the wing then make the spar
I will hide the mistake but to late.. I finish one wing with aileron , retract etc...
I will post more pic later.
The struts ..nice
Old Feb 20, 2011, 11:22 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
little more work today...yes I have a family also
aileron is done...
I will use two Hitec 5125 for stab in the tail . I reversed one tonight will Hitec little programer ( nice toys)
I'm scratching my head for the mechanisme to open front doors , simple cord or two servos with small wire.....
For the spar mistake I find a good solution yeahh
Old Feb 21, 2011, 01:17 AM
MaHö is offline
Find More Posts by MaHö
MaHö's Avatar
Germany, BW, Stuttgart
Joined Dec 2001
Hi JC,
just started and that fast, cool
Looks good!
regards Martin
MaHö is offline Find More Posts by MaHö
Old Feb 25, 2011, 10:21 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
Long process to do the wing. Finally I'm done with separation and all the whole for cables etc.
Finally I decide to ad the flaps, i have a feeling this Mig will land fast with out flap!. Thank you Maho for the left over!
I will use like the elevator two Hitec 5125 digital ( easy to reverse) no need to have more channel and matchbox.
I fitted the servos for elevator and I will ad the home made carbon spar in the rudder
Old Mar 01, 2011, 09:52 AM
bidule is offline
bidule's Avatar
Joined Mar 2000
a bit more
Slowly the wing are done with control and landing support.
I finally glue the tail carbon spar with Aeropoxy.
Next is attach the root portion to the fuse and match the contour with Bondo.
Because I have two left wing I will have the delicate operation to send the right one to correct angle
Old Mar 02, 2011, 09:48 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
Tonight is cutting the wheel bay and fitting the legs.
Later, when half wing is part of the fuselage I will ad two doors with small servos
Old Mar 03, 2011, 12:13 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Nice JC, how come you have two left wings ?
Springair ... the best ... So where did you get those struts if I may ask ?
Old Mar 03, 2011, 07:23 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
I thing this is the norm with this jet from Pavel. The strut: from a friend on RC Canada for $80 CA .
But let me check my bookmark and I will provide a link where to buy those in N.America.
Old Mar 05, 2011, 01:08 PM
bidule is offline
bidule's Avatar
Joined Mar 2000
Yesterday glue with carbon tow and Hysol the formers to support the fan: TJ 100. The fan is inserted from a hatch cut on the Mig belly. Will be to complicated from the front with the split intake
For Sale Freewing? 30amp ESC from HL Mig-15 $15 shipped jmrust Aircraft - Electric - Power Systems (FS/W) 2 Mar 26, 2011 10:56 AM
Sold NIB Pavel Bosak Mig 15 MaHö Aircraft - Electric - Jets (FS/W) 2 Aug 11, 2010 01:54 AM
For Sale NIB Pavel Bosak Mig 15 MaHö Aircraft - Electric - Jets (FS/W) 2 Jan 22, 2009 10:45 AM
Discussion Anyone know where I can get a Model Builder plan A5A Vigilante #12791 by Pavel Bosak byrocat Scale Fuel Planes 1 May 10, 2006 05:07 PM
RCM/Pavel Bosak F-4 FOShowNoClass Fuel Jet Talk 0 Nov 03, 2003 02:51 PM
