Old Feb 05, 2011, 02:39 PM
daneflyer is offline
Find More Posts by daneflyer
daneflyer's Avatar
Joined Jan 2010
binding spectrum receiver problem
I am trying to bind my spectrum ar500 receiver installed in a new aircraft to my dx6i which i have done many times before. When I plug the battery in to the ESC the led on the receiver only blinks once and the servos center but the led doesn't continue to blink and the receiver will not bind. Thought maybe it was the receiver since it came out of a wrecked plane, but had the same thing happen with another receiver. Any ideas?
Thanks for the help,
Dan
daneflyer is offline Find More Posts by daneflyer
Old Feb 05, 2011, 02:42 PM
Bad Karma is offline
Find More Posts by Bad Karma
Karma's Evil Twin Brother
USA, OH, Maineville
Joined Sep 2009
Is your transmitter off when you plug in the battery?
Do you have the bind plug in the right port on the rx?
Maybe dumb questions on my part, but it's a good place to start
Bad Karma is offline Find More Posts by Bad Karma
Old Feb 05, 2011, 03:05 PM
daneflyer's Avatar
Joined Jan 2010
Fixed the problem. After posting my problem I found a post that suggested trying a different bind plug,....that fixed the problem. Are bind plugs different for different receiver? I have a couple different receivers, but put all the bind plugs in one plastic bag. Thought maybe bind plugs are specific to the receiver model. All of them are Spectrum.
Old Feb 06, 2011, 06:35 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
Nope, all they are is a connector that has the two outer pins connected.
But I have heard of bad bind plugs, probably a missed crimp or a broen wire inside the insulation.
Pinecone is offline Find More Posts by Pinecone
Help! Spectrum DX7 Binding problem wilchar Fuel Plane Talk 0 Jul 05, 2010 11:23 AM
Discussion Spectrum DX6i memory loss and binding problem Derek_S Radios 4 Jun 20, 2009 11:35 AM
Help! Binding 2 JR 9 spectrum receiver at the same time? gouang Radios 1 Jan 24, 2009 09:55 AM
Discussion 2.4 G system from walkera - problem binding new receiver klausbub Radios 0 Feb 15, 2008 03:23 AM
